Retrofitting Maho MH500C
- THS-Quantum
14 Aug 2023 08:53 #277930
by THS-Quantum
Retrofitting Maho MH500C was created by THS-Quantum
Initial thread starter, as well as my first thread on the forum.
Long story short, I have a MH500C year 1984, 4speed gearbox, have not managed to fully get the Philips 432-control to play along with me, so i plan a retrofit trying to use as much of the original HW as possible. I plan to using a Dell PC & Mesa card(s)...
Some info regarding the machine
- X-Y-Z & spindle drives are analog +-10V, TRK6(spindle) & 3TRM2(x,y,z)
- X-Y-Z-Encoders are linear("glass scale") analog 11uAPP, will be converted to TTL with eg. EXE 602 to TTL signal
- MPG is present and gives TTL signals
- Spindle feedback - I have not figured out about the existing sensing system for spindle angle(if any) for tapping cycles.
I´m thinking about using ethernet based MESA hardware, but seem like they are usually out of stock everywhere.
Some options i have been considering:
-7I97(1+ month waiting time), should handle all of the nesesary signals with ethernet connection to PC
-7I77(no stock)+5I25(is in the process of being replaced)...
-7I83 + 7I95T +7I74 (should be available "soon")
-7I83 + 7I95T + additional PCI based NIC
-Other suggestions?
Some questions:
-Will 7I74 work connected to my standard parallel port, or do i need something like the 5I25 ?
-Will the additional PCI based NIC card work with Debian/LinuxCNC to communicate with the second I/O card?
Rotary SMP, who did an exellent job with his conversion on the MH400, inspired me to go in this direction. Main difference is that i have a 4 speed gearbox and Indramat 5kW spindle motor. for the first stage i will not make the gear change logic and I/O, just do manual gear change.
-Other suggestions?
Some questions:
14 Aug 2023 09:29 #277934
Replied by rodw on topic Retrofitting Maho MH500C
Don't rule out the gearbox just yet. You will have plenty to do but when you get to it, it might be quite simple. I have 8 speeds programmed which RotarySMP is looking at for inspiration..
- Thank you received: 5929
14 Aug 2023 09:33 #277935
Replied by tommylight on topic Retrofitting Maho MH500C
7i96S+7i85+7i83
can usually be found without much fuss.
Hmmm just checked, no 7i96S in Europe another 20 days, so 7i92+7i85+7i83+7i84
or 7i70 (inputs), 7i71 or 7i72 both outputs sourcing or sinking.
check
www.eusurplus.com
www.welectron.com
check
www.eusurplus.com
www.welectron.com
- THS-Quantum
14 Aug 2023 17:28 #277982
by THS-Quantum
Replied by THS-Quantum on topic Retrofitting Maho MH500C
Thanks for your keen replies!
The "7i92+7i85+7i83+7i84" seems available in EU and the I/Os seem to be there, but im not sure about the best way to run the communication between cards and the PC!?
To clarify, i have a PC with one parallel and one ethernet port available, installed Debian10 LinuxCNC and latency seems decent.
I have some experience around Windows and Mach3 and GRBL etc. on mills and plasma, LinuxCNC is new, but lets keep the learning curve steep...
14 Aug 2023 18:03 #277986
PC>7i92>7i85>7i83+7iXX or whatever you need.
In general, Mesa has 25 pin boards (above), 50 pin boards (way to much options and IO for most of us) and Smart Serial boards that connect to FPGA boards through a CAT5 or CAT6 cable.
PC connects to 7i92 with a single CAT5 cable, uses the network card on the PC
7i92 has two of 25 pin headers, one goes to 7i85
7i85 has 4 encoder inputs (A/B/Z differential or single ended) and 5 SSerial ports
7i83 has 6 analog +-10V outputs for Velocity mode servo drives, it connects to 7i85 with a "cut in half" CAT5 cable
7i84 has 32 inputs and 16 outputs, it connects to 7i85 with a "cut in half" CAT5 cable
If it turns out the inputs and outputs are not enough, go for 7i70, 7i71, 7i72 depending on what you end up needing, there is place for 4 of those in any combination.
It is absolutely worth it! The amount of possibilities it opens is... well hard to put into words...... LinuxCNC is new, but lets keep the learning curve steep...
- THS-Quantum
15 Aug 2023 08:42 #278034
by THS-Quantum
Thx! Now i see the picture. I am ordering these four cards and will try to find three EXE602 converters next.
- THS-Quantum
07 Nov 2023 10:03 #284763
by THS-Quantum
After some off-time from this project I will try to get forward some again. I received my Mesa 7I92TH 7I83, 84 & 85. Now i think i should get the correct firmware loaded to the 7I92 (at least?) so it can communicate forward. Could anyone point me to the correct firmware and "way of working", also is Mesaflash in linux the only way to flash the cards? Did some attempts getting Mesaflash working earlier but encountered issues and got stuck, then i went travelling for work..
Im getting following response when trying to start the installation of Mesaflash according to instructions at github.com/LinuxCNC/mesaflash:
$ sudo apt install libpci-dev libmd-dev pkg-config build-essential git
[sudo] password for cnc:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package pkg-config is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
Package git is not available, but is referred to by another package.
E: Unable to locate package libpci-dev
E: Unable to locate package libmd-dev
E: Package 'pkg-config' has no installation candidate
E: Package 'git' has no installation candidate
(Start to remember now why i have never continued using Linux ever)
07 Nov 2023 13:12 #284769
Did you do
sudo apt update
before trying to install?
sudo apt update
- THS-Quantum
07 Nov 2023 15:18 #284785
by THS-Quantum
thx for the tip. no, but same result after doing this as well
07 Nov 2023 17:05 #284798
OK, that means there is something wrong with the sources list as git is on all repos for all distros, making it impossible not to find.
It the PC connected to internet?
Is the PC used to control the machine through Mesa card?
Does the PC have a wifi connection?
Moderators: piasdom
Time to create page: 0.272 seconds
