Retrofitting Maho MH500C
- THS-Quantum
07 Nov 2023 19:45 #284815
by THS-Quantum
Replied by THS-Quantum on topic Retrofitting Maho MH500C
connected to internet with only available port:rj45, no wifi available. 8.8.8.8 ping 20-35ms
- THS-Quantum
07 Dec 2023 15:27 #287453
by THS-Quantum
I made a fresh install using ´linuxcnc_2.9.1-amd64.hybrid.iso´ image and managed then to get mesaflash working. now i have the following questions
1. I managed to flash the firmware "7i92t_7i85x2d.bin" to the 7I92TH card, Is this the correct firmware for my board setup?
2. Next step to setup/test the outputs and inputs?
when i try to run pnfcconf and set the board name to "Source" it does not seem to recognize the card name("Pncconf doesnt recognize the board name") and no firmware is available in the firmware drop down menu.
- Thank you received: 5929
07 Dec 2023 15:43 #287456
Replied by tommylight on topic Retrofitting Maho MH500C
Choose 7i92 in PncConf, make a simple config and run it.
- THS-Quantum
01 Jan 2024 14:49 #289472
by THS-Quantum
Using Mesa CT to create base config. works fine and can communicate with 7i92th.
Since Mesa CT does not support 7i83 analog servo mode configuration, i need some help configuring this servo loop, reading encoders at 7i85 and putting out analog signals at 7i73.
Support documents available?
If i remove the lines containing "stepgen" in main.hal, i can run the config in linuxCNC, but not been able to get any signals to 7i84 yet..
01 Jan 2024 15:33 - 01 Jan 2024 15:34 #289476
Replied by PCW on topic Retrofitting Maho MH500C
You could create a 7I92 configuration for a 7I77 and the change the references to
the analog 7I77 outputs to 7I83. The 7I83 enables also have different names than
on the 7I77, so those would need to be changed also. The sserial channel number
will also likely need to be changed.
To get all the actual hardware pin and parameter names, start a LinuxCNC configuration
with the 7I83 connected and powered and run this command in a terminal:
halcmd show all hm2
halcmd show all hm2
Last edit: 01 Jan 2024 15:34 by PCW.
- THS-Quantum
03 Jan 2024 15:06 #289665
by THS-Quantum
Thänks PCW, this helped a lot. I can see both SS cards now, and signal names, and copy paste from 7i77 HAL. Also i can read digital inputs from 7i84 with hal-meter, so this is great news. Need to order EXE converters now for linear encoders, and carry on with some installation work on the machine.
Cheers!
Cheers!
- THS-Quantum
14 Jan 2024 15:48 #290659
by THS-Quantum
Have installed the Mesa cards and tested the general I/Os on the machine now. I just now realized i have the philips 2480/10 encoders for which it is hard to find adapting electronics to TTL, i found this anyway and looks decent: www.bulgarianindustry.bg/assets/cms/File...verter_datasheet.pdf
Awaiting response from them..
Another option would be new cheap import linear TTL encoders, but would be nice to keep the original Philips, which probably have even better accuracy than new Chinese ones..
Any other ideas for reading the linear motion on this machine?
22 Jan 2024 11:21 #291335
by reckks
Replied by reckks on topic Retrofitting Maho MH500C
If there is a solution for Maho 500 C I Would be pleasured to have a description.
Moderators: piasdom
Time to create page: 0.153 seconds
