Hardware & Machines
Milling Machines
Suitable encoder upgrade options
Thank you received: 567
05 Apr 2024 11:41 #297638
by spumco
Well done on your score.
I think you'll find that if the encoder works at all, you don't need to be concerned with it being a little dodgy or imprecise. Mill spindles generally don't need to be positioned quite as accurately as rotary axes for useable rigid tapping or ATC alignment.
Another thing... shaft encoders come in fairly 'standard' sizes, so it's not too hard to find pre-fabricated mounts. Have a look around if you find you need something fiddly to mount to the head and you might find something online that'll save you some time.
Hardware & Machines
Milling Machines
