Forum Header
Roland EGX 600 Stepconfigs
- album.digital.ficheiros
28 Feb 2013 19:03 #30673
by album.digital.ficheiros
Roland EGX 600 Stepconfigs was created by album.digital.ficheiros
Hellooo!!
I've been trying to config a Roland EGX-600 on pncconfig but i'm not managing to do it... Are there any configuration files i can download or can anyone help me with this?
For getting info on this model you may check at www.rolanddga.com/products/engravers/egx400/
I also added the pdf manual if it is helpfull.
Thanks in advance!
Thanks in advance!
28 Feb 2013 20:34 #30676
That appears to be a servo machine.
Can you describe the rest of the system? What interface are you using between the engraver and the PC?
Replied by andypugh on topic Roland EGX 600 Stepconfigs
Hellooo!!
28 Feb 2013 22:07 #30683
Replied by album.digital.ficheiros on topic Roland EGX 600 Stepconfigs
I'm using the LPT port to connect to the machine if that is what you mean. I checked the machine manual but it does not have the information i need to place on pncconfig :
28 Feb 2013 23:37 #30687
If you are using the LPT port then PNCConf is not the right software, that is purely for Mesa cards.
The machine can run standalone from memory cards, I am pretty sure that the port you are trying to use is only for transferring image/program data.
LinuxCNC is a machine controller. it is not a system for transferring program data to a machine controller.
It is almost certainly possible to control the machine with LinuxCNC, but you would need to remove the installed controller and connect directly to the servo motor drives.
Time to create page: 0.345 seconds
