Forum Header
problems with stepcon
30 Sep 2013 23:28 #39410
by BigJohnT
Replied by BigJohnT on topic problems with stepcon
Click on Reply (not quick reply) and add the file to your message.
JT
JT
30 Sep 2013 23:39 #39411
by dsb1
Replied by dsb1 on topic problems with stepcon
I hope you get this
30 Sep 2013 23:41 #39412
by dsb1
30 Sep 2013 23:49 #39413
by dsb1
thank you guys for your help
I tried to send the file,Ihope you get it
I will have to get with you tomorrow
I have to go to work now
01 Oct 2013 00:05 #39414
by ArcEye
Replied by ArcEye on topic problems with stepcon
Yes that attached fine
One of these is the port address and the other the register
The port address tends to be the lower number, so try 0xa800 as you port first, if that fails use 0xac00
Region 0: I/O ports at ac00
Region 1: I/O ports at a800
01 Oct 2013 22:48 #39445
by dsb1
THANK YOU
You guys did it, port address was 0xac00
my machine moves good but x axis moves in wrong direction for + and -
and I cant remember how to change it back
I am very thankful for your help
I dont know what I could have done if you guys didnt help
01 Oct 2013 23:23 #39451
by dsb1
I reran stepcon so now all axis work properly
Thank you again for all your help
How would I make a image of my computer with all my current settings in ubuntu and linuxcnc
so if I have computer problems in the future I can just plug a flashdrive in and reload everything the way it is now
I made a startup disk for ubuntu and linuxcnc and it works good
but if I could image my harddrive now it would save a lot of trouble
Thank You Guys for this forum
01 Oct 2013 23:38 #39453
by BigJohnT
Invert the direction pin in the parallel port setup page for the X axis.
JT
THANK YOU
JT
02 Oct 2013 00:28 #39458
by dsb1
the machine jogs fine and does mdi commands good as well
but when I try to run a program it will make one z move and then the machine doesnt move but the program is still running and the DRO is moving as well
and now when I boot up the cnc I get a message about manual tool change and my computer freezes up,the mouse even freezes up HELP AGAIN
02 Oct 2013 02:03 #39467
by dsb1
well I think my CNC is working properly now
I just ran a simple spotting program (aggravation board) it worked good
I know the scale is not right yet but I will modify steps per inch to dial it in
I will make a mill program for a 6 inch x 6 inch box and adjust steps per inch untill it checks 6.000 square
is there a better way to get the correct scale
in any case Thank You
Time to create page: 0.137 seconds
