Forum Header
SOLVED: one axis not working for newbie
16 Dec 2013 07:25 - 18 Dec 2013 05:06 #41636
by mtngun
SOLVED: one axis not working for newbie was created by mtngun
I'm trying to convert a lathe from TurboCnc to LinuxCNC. I'm new to LinuxCNC.
I ran the stepconfig wizard and the X axis tested OK inside the wizard, but not the Z axis. Likewise, the X axis works inside LinuxCNC but not the Z axis.
The X axis is driven by a Gecko 203V, pins 2 & 3
The Z axis is driven by a Gecko 201, pins 14 & 16
The 203V runs on active hi, while the 201 runs on active lo.
Both axis work fine in TurboCNC, so I'm confident there is no hardware problem.
The X axis & 203V run no matter whether I configure the pins to "invert" or not.
The Z axis does not run whether I configure the pins to "invert or not.
I'm guessing there is something wrong with the HAL file?
My ini and hal files are attached.
Last edit: 18 Dec 2013 05:06 by mtngun. Reason: solved problem
16 Dec 2013 16:36 #41639
by cncbasher
Replied by cncbasher on topic Help, one axis not working for newbie
you need to reconfigure the z to active hi ,
The following user(s) said Thank You: mtngun
17 Dec 2013 03:30 #41645
by mtngun
Replied by mtngun on topic Help, one axis not working for newbie
I don't understand why I should set the Z's 201 to run on active high since it runs active lo in TurboCNC?
Nonetheless I edited the hal file as follows to turn off "invert" for pins 14 & 16? I changed the "invert" command for 14 & 16 from "1" to "0." It didn't make any difference -- still no Z response.
net xstep => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
net xdir => parport.0.pin-03-out
setp parport.0.pin-14-out-invert 0
net zstep => parport.0.pin-14-out
setp parport.0.pin-14-out-reset 1
setp parport.0.pin-16-out-invert 0
net zdir => parport.0.pin-16-out
17 Dec 2013 03:36 #41646
by mtngun
I have a newbie question about the HAL file that may or may not be related to my Z problem.
LinuxCNC refers to the lathe's X as axis "0" and the lathe's Z as axis "2." Yet some of the HAL commands generated by StepConfig refer to Z as a "1" not a "2" . Is it supposed to be that way, or is that a bug?
This is what I am referring to:
setp stepgen.1.position-scale [AXIS_2]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 46000
setp stepgen.1.dirsetup 27000
setp stepgen.1.maxaccel [AXIS_2]STEPGEN_MAXACCEL
net zpos-cmd axis.2.motor-pos-cmd => stepgen.1.position-cmd
net zpos-fb stepgen.1.position-fb => axis.2.motor-pos-fb
net zstep <= stepgen.1.step
net zdir <= stepgen.1.dir
net zenable axis.2.amp-enable-out => stepgen.1.enable
Why is it using "stepgen.1." instead of "stepgen.2" ?
17 Dec 2013 08:07 #41664
by BigJohnT
Replied by BigJohnT on topic Help, one axis not working for newbie
For a lathe that has no Y axis I assume the Stepconf Wizard skips the Y axis and assigns stepgen 1 to axis 2 (z).
Does Z hold firm when power is applied?
If you change directions does Z move one step?
Stepper diagnostics linuxcnc.org/docs/html/common/Stepper_Diagnostics.html
JT
JT
17 Dec 2013 08:17 #41667
by mtngun
I'll try to check later this eveningDoes Z hold firm when power is applied?
No. There is zero response from the Z axis.If you change directions does Z move one step?
17 Dec 2013 08:19 #41668
by BigJohnT
One step might be hard to see... if your step and direction pins are reversed you will get one step each time you change direction.
JT
JT
17 Dec 2013 09:45 #41677
by mtngun
I re-verified that pin 14 goes to the 201's step terminal and that pin 16 goes to the 201's direction terminal.
Z holds firm as soon as power is applied to the drives.Does Z hold firm when power is applied?
I put my hand on the motor while changing directions, couldn't feel anything or hear anything.If you change directions does Z move one step?
17 Dec 2013 19:45 #41691
by BigJohnT
My next guess is that you picked 203 from the dropdown for timing and the 201 has much longer time requirements.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Stepper_Drive_Timing
The 201 would not run on the 203's step and direction timing.
JT
JT
18 Dec 2013 04:55 #41711
by mtngun
Replied by mtngun on topic SOLVED: one axis not working for newbie
Fixed it. Reconfigured the wiring to run Z on pins 6 & 7 instead of 14 & 16. Then reran StepConf, now Z works, though rough as a cob.
I vaguely remember reading somewhere that the high pins on some parallel ports do not work in LinuxCNC unless a certain switch is set? But for now I am content to use pins 6 & 7.
As BigJohnT suggested, the 201 and the 203 drivers require different timing, and StepConf does not give us the option of specifying two different timing settings, so the Z is probably running rough for that reason.
I presume I have to edit something or another to specify different timing for the 201, so exactly where and how do I do that?
Time to create page: 0.258 seconds
