Forum Header
SOLVED: one axis not working for newbie
18 Dec 2013 07:13 #41718
by BigJohnT
Replied by BigJohnT on topic SOLVED: one axis not working for newbie
You can only have one so pick the 201 timing.
JT
JT
- JoeHildreth
- Thank you received: 14
18 Dec 2013 07:37 #41720
by JoeHildreth
Replied by JoeHildreth on topic SOLVED: one axis not working for newbie
My guess is that you will need to configure it to run with the slower of the two controllers. I don't recall seeing anywhere in the config files you could specify different timings. I believe, the timing is calculated as a system value and applied to the drivers that way. I say this because I see only one entry in the EMCMOT section of the machine.ini file. But, being an amatuer, I may have this worng.
Joe
Joe
- JoeHildreth
18 Dec 2013 07:39 #41721
by JoeHildreth
Guess I was a little slow Big John.
Joe
Joe
21 Dec 2013 05:21 #41888
by mtngun
Replied by mtngun on topic SOLVED: one axis not working for newbie
UPDATE: switching from 10.04 to 8.04 solved all my problems. Now pins 14 & 16 work, and now the 201 purrs like a kitten.
Apparently there is either a bug in 10.04 or else it just didn't like my box (a HP DC5000 P4).
Time to create page: 0.120 seconds
