Forum Header
broken pipe error in stepconf
21 Apr 2014 01:09 #46144
by punitor1
broken pipe error in stepconf was created by punitor1
I am getting the "broken pipe" error in stepconf when I try to test run the axes. I have seen several people reference a troubleshooting manual, or else running the commands in the terminal to get more helpful error messages. I haven't been able to find either of these things; can someone point me in the right direction please?
21 Apr 2014 06:55 #46156
Replied by andypugh on topic broken pipe error in stepconf
First of all, try rebooting the PC. The realtime system kernel modules can occasionally get in a tangle where they can't quit exit bit can't quite load either.
21 Apr 2014 10:43 #46160
Replied by cmorley on topic broken pipe error in stepconf
open a terminal (applications / accessories / terminal )
and type stepconf <return>
if it errors again, this will show the true error.
After getting the error, as Andy pointed out it sometimes needs to be reset.
in the terminal try halrun -U <return>
that's a capital U
What version of linuxcnc are you using?
that's a capital U
21 Apr 2014 16:53 #46167
I have never actually known that to work.
that's a capital U
22 Apr 2014 02:47 #46195
almost always does for me - particularly for stepconf - weird
Chris M
Chris M
Time to create page: 0.108 seconds
