Configuring LinuxCNC
StepConf Wizard
My system working with Mach3- Not working linuxcnc
Thank you received: 0
18 Sep 2014 02:42 #51283
by krcmak
Hi everyone my names Furkan Karaca from turkey. i have a some problem about PIN number.. i want to move Linuxcnc our machine. i use to mach3 but ı dnt want to use it. so transfer linux... my system working with mach3 when i try stepcong linux never run motor.. weird. LPT pin number : LPT pin2 : X axis Step---Pin3 X DIR PİN4 Y step pin5 y dir pin6 z step pin7 z dır. pin 10 xyza home sensor pin 11 xyza limit sensor pin 12 auto tool zero probe pin 13 emergency. i dnt connect emergency snd limit etc. i only want to see motor working. what my problem i use to linux 2.6.3. why doesnt working ? where i wrong my card is working 220v and have a PWN..
18 Sep 2014 02:52 #51284
by krcmak
i upload mach3 xml file. pls preapre for us dear admin. but i use to gantry system Y and A working witg ganty..
Thank you received: 306
18 Sep 2014 14:16 #51302
by cncbasher
please be specific on any error shown , and where possible please state which version and OS you are using
and attach your hal configuration as an attachment will help
but the common problems are ., Estop not connected, this is required to be a normaly closed switch , stepper enable is required.
19 Sep 2014 03:25 - 19 Sep 2014 03:26 #51323
by krcmak
os: ubuntu 10 latest version. ı never used before. okey ı connect estop and swıch but is it posible or not deactıve e stop and swich etc. also how to i can stepper enable ? where is it ? thanks. sorry if my english
i send to HAL files tomorrow dear..
Last edit: 19 Sep 2014 03:26 by
krcmak.
Thank you received: 158
19 Sep 2014 14:30 #51330
by Rick G
From here...
www.linuxcnc.org/hardy/docs/html/config/stepconf.html
Test this axis is a basic tester that only outputs step and direction signals to try different values for acceleration and velocity.
Important
In order to use test this axis you have to manually enable the axis if this is required. If your driver has a charge pump you will have to bypass it. Test this axis does not react to limit switch inputs. Use with caution.
In stepconfig you want to look at
Amplifier enable
You could also complete the Stepconfig without testing the motors and see if your configuration works.
John can also translate your Mach configuration to a Linuxcnc configuration.
Rick G
19 Sep 2014 20:05 #51344
by krcmak
i install estop but i try chnage pin etc. but i cnt run motor.
i upluad my linux cnc screen and hal document. really i almost die with confirigation ya
i close all pim only open Z axis also cnnott workinh ya. pls help me. if posible remote my deskstop.
20 Sep 2014 03:40 - 20 Sep 2014 03:43 #51366
by Rick G
O.K.
You need to run the Latency test, then use those numbers to run Stepconf.
Application,
CNC,
Latency Test
Also post the results of your latency test.
Rick G
Last edit: 20 Sep 2014 03:43 by
Rick G.
20 Sep 2014 03:52 #51367
by krcmak
i know ur mens friend but my first problem i cnt set pin number i try but i cnt ya. maybe i wrong do it. so i upload my hal and mach3 xml. maybe admin solve my problem. but i say again. i only use Z axis im not use another axis. and install estop and home sensor. and i found Amplifier enable pin. maybe i dnt complate all system so doesnt run my motor.i need solve first my pin number second level after ya
dnt know yrs time zone. our time is 23:51 right now. if u help me remote desktop i can early wake up dear
20 Sep 2014 15:22 #51374
by cncbasher
in your screenshot you show error ... this must be fixed before anything else ..
this error will stop motor from running
you need to run latency test and post your answer
21 Sep 2014 01:41 - 21 Sep 2014 01:43 #51383
by krcmak
dear cncbasher im online right now. but i dnt run motor ya.. i upload my mach3 cart shema and pin port number.. also i want to ask something how to i check my lpt port with linux ?.. if posible pls contactt with me remote dear...
Last edit: 21 Sep 2014 01:43 by
krcmak.
StepConf Wizard
Time to create page: 0.092 seconds
