Forum Header
My system working with Mach3- Not working linuxcnc
21 Sep 2014 16:00 #51395
by Rick G
Replied by Rick G on topic My system working with Mach3- Not working linuxcnc
Take a look here...
www.linuxcnc.org/docs/2.4/html/examples_pci_parallel_port.html
and
www.linuxcnc.org/index.php/english/forum...to-emc2?limitstart=0
Rick G
and
Rick G
21 Sep 2014 16:22 #51396
by cncbasher
Replied by cncbasher on topic My system working with Mach3- Not working linuxcnc
i notice this breakout board does not use an enable
But the board has opto's ..so this may mean inverting the output on the direction pins .
but first we need to get the motors moving
i will post a hal file shortly
21 Sep 2014 16:38 #51397
by cncbasher
information so far given in your xml are :
X step 2
X dir 3
Y step 4
Y dir 5
Z step 6
Z dir 7
home 10
limits 11
Probe in 12
Estop 13
Spindle PWM 1
Spindle dir 14
Charge Pump 16
output #3 17
I notice from above that the Charge Pump is Active , are you using Geko Stepper drives ?
also this breakout board also seems to have optos's fitted this will mean the possibility of some inputs , needing to be inverted
the main 2 points that would stop the drives is the charge pump and the Estop
X step 2
X dir 3
Y step 4
Y dir 5
Z step 6
Z dir 7
home 10
limits 11
Probe in 12
Estop 13
Spindle PWM 1
Spindle dir 14
Charge Pump 16
output #3 17
21 Sep 2014 17:05 #51398
by krcmak
Replied by krcmak on topic My system working with Mach3- Not working linuxcnc
i use leadshine stepper drivers.
21 Sep 2014 17:10 #51399
by cncbasher
find attached Hal file
this is set as per the pins in the hal file , but beware , you may find the input or output pins may need reversing to suit your configuration
it has the charge pump connected to pin 16 , again this may or may not be needed , as i do not know the full connection details .
the soft limits will need to be adjusted
did you run the latency test and solve the rtai error ?
21 Sep 2014 17:16 #51400
by cncbasher
have you connected the enable on the leadshine drives , if you have then disconnect it for now
ok if your using standard drives then their is no reason for it not to work
apart from the rtapi error ..
attached modified hal file replace the origional
this removes the charge pump
21 Sep 2014 17:23 #51401
by krcmak
i try right now.. but dear basher when i start latecy test never stop.. maybe 15min. but values is high i check internet my values. but i only install estop and home sensor and than i ask something about paralel port mode i use now epp 1.7 ( BİOS)
21 Sep 2014 17:32 #51403
by cncbasher
the latency test will run until you stop it ...
if the latency is High , then this means either your graphics card is not suitable or the pc is not
this needs to be solved , as it will stop linuxcnc from working
contact me via email or skype if you wish
21 Sep 2014 17:34 #51404
by krcmak
okey i şinstall skype now. my skype id efm.teknik
Time to create page: 0.233 seconds
