Forum Header
configuring lathe problem stepconfig
23 Mar 2015 10:09 #57100
Replied by cmorley on topic configuring lathe problem stepconfig
Clive
You are using master if you have U or V in a stepconf config.
But I just pushed fixes to that problem.
Chris M
Chris M
23 Mar 2015 16:30 - 03 Apr 2015 23:42 #57102
by Clive S
Chris
I have never used the git and don't really understand the master. I had used the 2.6 hybrid cd iso and then updated from the apt get thing within Linux which seemed to bring it to 2.7 ish
But at least a bug was found. Thank you for your help. ..Clive
Edit as of the 3/4/15 I have redone an update and the u - v bug has been cleared
Replied by Clive S on topic configuring lathe problem stepconfig
Clive
Chris M
Chris
Last edit: 03 Apr 2015 23:42 by Clive S. Reason: Added text
- Trispectiv
28 Apr 2016 04:29 - 28 Apr 2016 04:30 #73983
by Trispectiv
Replied by Trispectiv on topic configuring lathe problem stepconfig
I tried the posted code, but it complains about feed being a read-only variable. Changing the variable name fixed it, I guess some internal things changed in LinuxCNC since back then in 2015.This is a template so will cover whatever thread size
(ignore the M code, that is just a local one to set the pulley number for correcting the speed)
;; Threading with G76
Last edit: 28 Apr 2016 04:30 by Trispectiv.
Time to create page: 0.069 seconds
