configuring lathe problem stepconfig
- Clive S
- Thank you received: 486
Would somebody care to look at my configs attached.
Problem is the Z axis is not working (DRO goes round but the motor does not).
I have had my lathe working ok under axis and I have been trying to set an encoder up to have a go at screw cutting.
I set the encoder index ,A and B up in stepconfig and its added lines in the hal ini.
I have noticed that in the ini file it show 3 axis but I have only set it to X and Z.
In the hal ini it seem to show U step and U dir (should this not be Z step etc)
The encoder appears to work as it is giving me the rpm on the axis screen.
I don't see the wood for the trees. Thanks. Clive
- ArcEye
- Thank you received: 240
It shows 3 axes because it counts X Y Z etc, that is normal, does not mean you have to use all of them and you have the correct coordinates set as X Z
It looks like you just need to change udir and ustep to zdir, zstep.
Do it in gedit not stepconf or you risk messing up an otherwise OK config
No idea how the names got that way to start with
EDIT
Attached is an altered copy, try that, can't immediately see anything else wrong with it
- Clive S
Hi
EDIT
Ok update It was the ustep and udir that I had to change (I had done it before but I use caps Z) it seems to like only lower case.
What I did notice was that I ran a new stepconfig with lathe and again it put in ustep and udir for the pins in the HAL strange!!
I have now tried a G76 line and as expected it runs the thread cycle if you stop the spindle you can turn it by hand and the thread Z moves
if you reverse the spindle say 10 revs the go forward again the thread does not start again until the 10revs have been done.
if you turn the spindle backwards the Z does not move is that correct?
Would you mind giving me a sample G76 line of code for say a M10 x 50mm so I can do further tests then I can learn how to program it. I use mm for the lathe.
I still need to calibrate the z move it seem to move about half what is required.
Many thanks for the help. Clive
- Thank you received: 2182
U and V axes were added recently and there may be a bug.
Chris M
- Clive S
What version of linuxcnc are you using? master?
Chris M
I installed the 2.6 hybrid iso then ran the update which brought it up to 2.7 (so a complete new install)
my ini files are attached in #57021
edit I don't remember having the same problem on the mill just had it on the lathe profile
I have been playing with gmocappy (only saying this for completeness)
Clive
- ArcEye
This is a template so will cover whatever thread size
(ignore the M code, that is just a local one to set the pulley number for correcting the speed)
;; Threading with G76
;; Speed of 300 is stable and only requires F450 to cut 1.5mm thread
;; P[itch]
;; Z[FinalExtent] - Ensure there is an overrun element so that deceleration happens beyond end of thread, 3 mm sufficient in this example
;; I[ThreadPeakOffset - cant be 0, neg for external pos for internal, if diameter is critical you can add PeakOffset to Diameter to negate this value]
;; J[FirstCutDepth - positive offset]
;; R[DepthDegression 1.0 is constant depth 2.0 is constant area 1-2 depth decreases & area increases 2> area decreases]
;; K[FullThreadDepth positive offset beyond I for root of thread]- Q[CompoundSlideAngle eg 29.5]
;; H[SpringPasses at full thread depth] E[TaperAmount in units - normally 0] L[Taper- L0 None L1 entry L2 Exit L3 Both]
#<_Diameter>=40
#<_Z_LeadIn>=15
#<_Pitch>=1.5
#<_Z_Finish>=-15
#<_PeakOffset>=-0.001
#<_First_Cut_Depth>=0.01
#<_Depth_Regression>=1.0
#<_ThreadDepth>=1.5
#<_CompoundSlideAngle>=0
#<_Spring_Passes>=2
#<_TaperAmount>=0
#<_TaperType>=0
#<_Feed>=1.5
#<_Speed>=300
G18 G21 G40 G49 G54 G80 G95
G90 G7
M101 P3 (SET PULLEY SETTING 3 FOR GOOD TORQUE)
F#<_Feed> S#<_Speed>
M3
G4 P10
M7
(GO TO OS DIA AND Z LEAD IN
G0 X#<_Diameter> Z#<_Z_LeadIn>
G76 P#<_Pitch> Z#<_Z_Finish> I#<_PeakOffset> J#<_First_Cut_Depth> R#<_Depth_Regression> K#<_ThreadDepth> Q#<_CompoundSlideAngle> H#<_Spring_Passes> L#<_TaperType>
G00 X45
M9
M5
G28
M2The Z lead in figure is quite important, because that is what enables everything to be aligned and at the right speed before cutting commences
I normally allow 10x the thread pitch roughly, so 15mm for a 1.5mm pitch
I am not sure why anyone would ever do that, but I suspect it is because you have both A and B channels on your encoder,
so it knows you have moved away from position in reverse and is bringing you back to where you were, before starting.
- Clive S
I will have a play with the code and see what happens.
Regarding the 10 revs back I was seeing if reversing the chuck (by hand) would reverse the Z, but I did not know if it should do that (I do have B set up)
So I don't know if B pulse is working yet as it should.
I will try a tapping cycle as that should reverse it.
Would I be better off with a 100 slot disc (mine is 64 slot)?
Clive
- ArcEye
You might well be.
I have a 120 hole disc on mine, which was the limit of the number of 3mm holes with 3mm spacing I could get on the disc.
I prevoiusly had a 60 hole version and this is much smoother.
I just have an A and a Z, no B. I don't want to do rigid tapping and as all threading is done in the same direction, B was no advantage.
- Clive S
You might well be.
Ok I will cut a 100 slot and test it out.
I have read some ware "The advantages of using both A and B are increased noise immunity and increased resolution"
thanks Clive
- ArcEye
That is true, but the disadvantage to me was having to fit another reading head and wire it in
