Forum Header
Customizing StepConf Wizard
10 Sep 2015 16:25 #62373
by viktan
Customizing StepConf Wizard was created by viktan
I trying to write own configuration wizard based on StepConf. I went over all gui tutorial on gnipsel.com/linuxcnc/gui/ but after all I'm not successful with build StepConf from source codes. Can anyone help me with the basic steps how to build this configuration wizard without any changes in code? (what tools is needed, locations, etc.. ) I using linuxcnc Ubuntu 10.04 LTS, Glade 3.6.7, Python 2.6.5
Thanks,
Viktor
Thanks,
Viktor
10 Sep 2015 18:26 #62377
by ArcEye
src/emc/usr_intf/stepconf.py
lib/python/stepconf/*.py
You don't need to build it, it is just a python script. Change whatever you want and run it to test
PS Glade 3 won't help you, everything in Linuxcnc is still Glade 2
Replied by ArcEye on topic Customizing StepConf Wizard
Thanks,
Viktor
10 Sep 2015 20:29 #62392
by viktan
Replied by viktan on topic Customizing StepConf Wizard
It is possible to run script anywhere or it need to be on specific location? I trying it to run on /home/cnc/linuxcnc-dev/src/emc/usr_intf/stepconf
How can I run it? I tried by ./stepconf.py and answer was:
"cannot find linuxcnc-wizard.gif, looked in /home/cnc/linuxcnc-dev/src/emc/usr_intf/stepconf/../share/linuxcnc/stepconf and /home/cnc/linuxcnc-dev/src/emc/usr_intf/stepconf/../share/linuxcnc"
also when I added missing file to same directory where is other files
Now I running on Debian, image was from www.linuxcnc.org/index.php/english/download
thanks
Viktor
thanks
Viktor
10 Sep 2015 20:42 #62394
by ArcEye
You are making things too difficult for yourself.
Build the RIP, run . ./scripts/rip-environment and the PYTHON path will be set up
Run stepconf from the root dir of the RIP
When you want to change something edit the /src/emc/usr_intf/stepconf/stepconf.py file and the run make again
You could just edit the copy of stepconf in /bin directly, but you would have to copy any changes back to the source file or they would be deleted next build
The gif file is in the root dir of the rip, the 'compiled' stepconf will find it
11 Sep 2015 15:19 #62435
by viktan
First of all Thank you for your help and patience.
We work on control board for RaspberryPi, based on FPGA for stepper motors and system is from Machinekit. We are done with HAL componets and all other configurations, but now we need to write any configuration wizard. First I trying do it on linuxcnc x86 because there is bigger community for support. Until now we don't have any experience with linux system and python.
If it possible can you or somebody write me the exact step by step how to run stepconf from linuxcnc-dev destination? I tried but I can't repeat the last steps from ArcEye (rip-environment..)
Thanks,
Viktor
Thanks,
Viktor
11 Sep 2015 20:49 - 11 Sep 2015 21:19 #62460
by ArcEye
Open a terminal and STAY in it.
cd /home/cnc/linuxcnc-dev/src
make clean && ./autogen.sh && ./configure && make && sudo make setuid
cd ../
stepconf
Now edit /home/cnc/linuxcnc-dev/src/emc/usr_intf/stepconf/stepconf.py with your changes
(or home/cnc/linuxcnc-dev/lib/python/stepconf/*.py - but save the original first because they are not regenerated)
then go back to src
make
and you will be running the edited version of stepconf next time you start it.
It is important to realise that . ./scripts/rip-environment sets the environment for THAT terminal shell session only
If you open another terminal or use the menu, you will be using the system installed version of stepconf, not the one from the RIP
cd ../
stepconf
then go back to src
make
Last edit: 11 Sep 2015 21:19 by ArcEye.
11 Sep 2015 21:22 #62469
Replied by cmorley on topic Customizing StepConf Wizard
If you are using machinekit then you might want to check how to compile machinekit instead of linuccnc.
machinekit is a fork of linuxcnc and has diverged enough the build system may be slightly different.
Chris M
Chris M
11 Sep 2015 22:29 #62472
by ArcEye
It is exactly the same, except that the Machinekit build will detect the kernel type(s) and build for that kernel(s).
Chris M
The following user(s) said Thank You: viktan
14 Sep 2015 17:48 #62555
by viktan
It works!
Now I have to learn Python
Viktor
Viktor
Time to create page: 0.165 seconds
