Forum Header
Z Stepper won't run
21 Oct 2015 04:09 #64019
by bwg
Z Stepper won't run was created by bwg
Have new setup with tb6560. I thought I had everything going after finding the pin outs for the TB 6560, but at the time I only had X and Y hooked up. They work fine but Z won't work. When I try to test the Z axis, the X stepper is apparantly energized it sits there and buzzes. When I text X and Y they appear to be fine. I tried to add a zenable line in hal custom file but that only generates an error.
Does anyone have any guidance. I'm losing my mind
21 Oct 2015 13:54 #64031
by Rick G
Replied by Rick G on topic Z Stepper won't run
21 Oct 2015 16:49 #64038
by cncbasher
Replied by cncbasher on topic Z Stepper won't run
it's noting more than finding the variant of the parallel port that works ,
make a list of the pins that work ,and are correct , and it should be easy to relate the others , beware of amp enable some boards wont work if that is not connected , but it seems you have some movement
so just leave that pin till last . post what you have and it should not take long to figure the rest
is their any version numbers on the pcb also , they use the colour of the pcb to denote versions in some , so post a picture of the board , or if you have a connection sheet as a pdf attach that here
look through the posts you'll find more than one version of configs .
21 Oct 2015 19:20 #64049
by bwg
Replied by bwg on topic Z Stepper won't run
I have a feeling that Amplifier Enable switch is contributing to this situation. But I need to learn more about this software to iron it out. For instance, I have seen these configuration files before. But I don't really know how to use them. Should I just plug them into the folder for my linuxcnc configuration and bypass stepconf program? Also, I notice that this rf-30 does not mention amplifier enable at all.
I guess it mainly boils down to my studying up on hal configs. The documentation seems a little sparse but I probably am just looking in the wrong place.
21 Oct 2015 20:58 #64060
The right place is here, the problem is rather the reverse of sparseness, there is so much documentation it can be hard to find the right parts.
www.linuxcnc.org/docs/html/
Replied by andypugh on topic Z Stepper won't run
I would suggest keeping the stepconf-produced configuration and trying to see in what way the Z axis parts differs from the others.Should I just plug them into the folder for my linuxcnc configuration and bypass stepconf program?
21 Oct 2015 22:47 #64077
by cncbasher
rather then fumble in the dark , give me information on the controller you have , and any detaills that came with it
and i'll help sort the weeds
and let me know what config you have tried , and what works or not , will help
22 Oct 2015 03:04 #64108
by bwg
The board is 3 axis Blue Board. The only id is "30695S" I have attached a picture.
Here is how I configured the board via Stepconf.
Pin:
1 X Step
2 Y Enable
3 Y Direction
4 Z Direction
5 Z Step
6 Amp Enable
7 X Dirction
8 Y Step
9 Spindle Motor
10 Input 0
11 Input 1
12 Input 2
13 Input 3
14 X Enable
15 Unused
16 Out 1
17 Out 2
This config allows X and Y axis to work both in Stepconf and Axis. When I try Z in Stepconf the only that happens is that the motors on X and Y are buzzing (shaking) but the Z motor does not. Nothing else moves when testing Z.
btw I changed the motors around and they all work if used in X or Y.
Pin:
1 X Step
2 Y Enable
3 Y Direction
4 Z Direction
5 Z Step
6 Amp Enable
7 X Dirction
8 Y Step
9 Spindle Motor
10 Input 0
11 Input 1
12 Input 2
13 Input 3
14 X Enable
15 Unused
16 Out 1
17 Out 2
22 Oct 2015 04:24 #64113
by cncbasher
try a new config with the following
pin2 xstep
pin3 xdir
pin4 ystep
pin5 ydir
pin6 zstep
pin7 zdir
just in case
it's trying a few combinations that we know were used on these boards
pin2 xstep
pin3 xdir
pin4 ystep
pin5 ydir
pin6 zstep
pin7 zdir
just in case
22 Oct 2015 04:26 #64114
by bwg
I will try those, but what about the other pins. Should I config them as unused? Or should I set those up by hand?
22 Oct 2015 04:54 #64115
by bwg
pin2 xstep
pin3 xdir
pin4 ystep
pin5 ydir
pin6 zstep
pin7 zdir
No good. Nothing works.
pin3 xdir
pin4 ystep
pin5 ydir
pin6 zstep
pin7 zdir
Time to create page: 0.131 seconds
