Forum Header
Z Stepper won't run
22 Oct 2015 21:20 #64141
Replied by andypugh on topic Z Stepper won't run
It might be worth tracing the actual tracks on the PCB to the stepper driver chips.
22 Oct 2015 21:31 #64143
by bwg
Replied by bwg on topic Z Stepper won't run
I have been reading some other threads and notice that the "amplifier enable" might have a lot to do with this situation. I am beginning to think that since there is only the amplifier enable switch that doesn't appear to be tied to any specific channel that maybe "amp enable" needs to change state before moving from one axis to another. I don't know if that makes any sense.
This all leads me to believe that the answer will lie somewhere in HAL config. If thats the case I think I'll need a year or two to learn that language before I'm able to do anything with it.
In the meantime I will try ringing out the leads and see what I can discover
Tks again
Bruce
Tks again
Bruce
22 Oct 2015 22:38 #64146
by ArcEye
Replied by ArcEye on topic Z Stepper won't run
You need to post your .ini and .hal files.
Without them we are all just fumbling in the dark.
If you have an amp-enable connected to pin 6 and X-Enable to pin 14, your config is wrong
You don't have any servo amplifiers, so I suspect you have connected Amp-Enable to Y, X-enable to X and nothing to Z
All you need is just one enable output and wire all the driver enables to it.
But then I am guessing as well, because you have not given us much information.
Here is how I configured the board via Stepconf.
Pin:
1 X Step
2 Y Enable
3 Y Direction
4 Z Direction
5 Z Step
6 Amp Enable
7 X Dirction
8 Y Step
9 Spindle Motor
10 Input 0
11 Input 1
12 Input 2
13 Input 3
14 X Enable
15 Unused
16 Out 1
17 Out 2
23 Oct 2015 02:00 #64157
by bwg
I have attached my hal and ini files. I hope it will help
26 Oct 2015 21:18 #64298
by bwg
If anyone is still here, I believe I found the problem. There appears to have been a 'cold' solder joint on the circuit board. I repaired the joint and now the z stepper is turning just fine.
So much for Chinese quality control
26 Oct 2015 23:07 - 26 Oct 2015 23:13 #64306
by cncbasher
Replied by cncbasher on topic Z Stepper won't run
great at least you found it , i have heard of others with bad joints too
if those files work for you , then all i can say is thats yet another config variant i didnt know of ( makes about 7 up to now )
Last edit: 26 Oct 2015 23:13 by cncbasher.
Time to create page: 0.148 seconds
