Forum Header
Error during setup Z to run Blacktooth laser
30 Nov 2015 16:57 #66114
by cncbasher
Replied by cncbasher on topic Error during setup Z to run Blacktooth laser
i presume your wanting to rasterize images ? , rather than cutting
if you want to do both , then the best way is to have 2 configurations .
07 Dec 2015 02:41 #66538
by ubergeek
Replied by ubergeek on topic Error during setup Z to run Blacktooth laser
Thank you for the suggested changes. Unfortunately, the changes did not solve the problem. I also moved the wire to pin 6 and changed the step config and the HAL file as mentioned and still nothing. I did learn how to modify the HAL file. I know it's easy but you don't know until you try. Any other ideas out there for this? I realize it has to be something i need to change in the HAL file. I just can't find the fix for it.
Thanks in advance for the help.
07 Dec 2015 10:16 #66547
I just remembered something... LinuxCNC doesn't toggle the spindle-on pins unless the spindle speed is > 0.
You may need a dummy S1000 command at the beginning of the code
If that works, then we can try to find a neater way.
Replied by andypugh on topic Error during setup Z to run Blacktooth laser
07 Dec 2015 12:07 - 07 Dec 2015 12:10 #66549
by ubergeek
How would i set the dummy S1000 command?
Last edit: 07 Dec 2015 12:10 by ubergeek.
07 Dec 2015 12:12 #66550
For a test, with a text editor, just add it to the G-code file.
If that works then we can start to look for a more general solution.
07 Dec 2015 12:41 #66553
by ubergeek
I guess i don't follow what you mean by adding it to the gcode. Could you provide an example or show where to add it? Here is the gcode i am using as a test.
07 Dec 2015 13:25 #66556
G90
G21
G0 X90.8226 Y25.7543
S1000
M03
G1 F500.000000
G1 X92.7505 Y25.7543
M05
Time to create page: 0.123 seconds
