Forum Header
Lathe step config question
09 Dec 2015 15:58 #66689
by Davenc
Lathe step config question was created by Davenc
I'm in the process of converting a Grizzly G0602 to cnc and plan on using the hardware kit from BDtools. I want work with inch units in AXIS but his ball screws are metric with 5mm & 4mm leads on the Z and X axis.
Is this going to be a problem with me running the lathe in inch mode exclusively ?
Can I add anything in my ini file so that even though the lathe is configured in metric mode using step config, it will come up in inch mode on my axis screen and calculate everything in inch mode properly.
Thanks,
Dave
Thanks,
Dave
09 Dec 2015 16:35 #66690
Just use 5.08 TPI and 6.35 TPI
Replied by andypugh on topic Lathe step config question
09 Dec 2015 16:53 #66691
by Davenc
Replied by Davenc on topic Lathe step config question
Thank you sir, a much easier way to do the same thing.
Time to create page: 0.066 seconds
