Forum Header
Reversing X Axis?
14 Jan 2016 03:14 #68342
by spinnaker
Reversing X Axis? was created by spinnaker
I am a total newbie to CNC and Linux. I was able to get everything working under Mach3 and I am considering moving to Linux CNC.
One problem I had in Mach 3 was that text was being mirrored. I was able to fix it by setting Config/Homing Limits and checking "reversed" for the X - Axis. I am having the same issue with mirrored text in Linux CNC. How can I reverse the x axis in linux CNC StepConf?
By the way I tried importing my Mach 3 configuration file and I got errors.
14 Jan 2016 11:53 #68354
In step-conf you can do this by inverting the DIR pin of the axis in the parport setup.
Or you can set a negative scale by making one of the numbers in the scale setup negative.
You may also need to make the home velocities negative.
Replied by andypugh on topic Reversing X Axis?
The following user(s) said Thank You: spinnaker
14 Jan 2016 16:24 #68388
by spinnaker
Thanks Andy. I did see how to invert the dir pin. I do not think that is the answer since there is a similar setting in mach3 that did not work.
I am at work right now and can't get in front of my pc. Perhaps it is obvious but in case not and since I am a newb, could you please expand on the negative velocity suggestion?
Replied by spinnaker on topic Reversing X Axis?
14 Jan 2016 16:27 #68389
Homing velocities only matter if you have configured homing. But if you have then some of the numbers may need to change sign.
Time to create page: 0.132 seconds
