Forum Header
Linux CNC just stopped working!
- parishwolfe
22 Mar 2017 01:39 #90042
by parishwolfe
Linux CNC just stopped working! was created by parishwolfe
I used my mill just the other day and it just stopped working. I don't know what happened if i updated it or what I did. Linux comes up just fine but when I launch the config it crashes with the error below. Someone please help me fix this, I'm loosing money every day that the mill is down!!
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.8.0-pre1-2263-gf13afe1
Machine configuration directory is '/home/parish/linuxcnc/configs/TaigMill'
Machine configuration file is 'TaigMill.ini'
INIFILE=/home/parish/linuxcnc/configs/TaigMill/TaigMill.ini
VERSION=1.0
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./TaigMill.hal
Found file(REL): ./custom.hal
Starting DISPLAY program: axis
Killing task linuxcncsvr, PID=4903
Killing task milltask, PID=4952
task: 61 cycles, min=0.000005, max=0.010094, avg=0.005191, 0 latency excursions (> 10x expected cycle time of 0.010000s)
Debug file information:
note: MAXV max: 1.000 units/sec 60.000 units/min
note: LJOG max: 1.000 units/sec 60.000 units/min
note: LJOG default: 0.100 units/sec 6.000 units/min
note: jog_order='XYZ'
note: jog_invert=set([])
Xlib: extension "GLX" missing on display ":0.0".
File "/usr/bin/axis", line 3502, in <module>
o = MyOpengl(widgets.preview_frame, width=400, height=300, double=1, depth=1)
File "/usr/bin/axis", line 377, in __init__
Opengl.__init__(self, *args, **kw)
File "/usr/lib/pymodules/python2.7/rs274/OpenGLTk.py", line 164, in __init__
apply(RawOpengl.__init__, (self, master, cnf), kw)
File "/usr/lib/pymodules/python2.7/rs274/OpenGLTk.py", line 112, in __init__
Togl.__init__(self, master, cnf, **kw)
File "/usr/lib/pymodules/python2.7/rs274/OpenGLTk.py", line 38, in __init__
Widget.__init__(self, master, 'togl', cnf, kw)
File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 2001, in __init__
(widgetName, self._w) + extra + self._options(cnf))
_tkinter.TclError: Togl: X server has no OpenGL GLX extension
4903
PID TTY STAT TIME COMMAND
4952
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009d800 (usable)
[ 0.000000] BIOS-e820: 000000000009d800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 0000000020000000 (usable)
[ 0.000000] BIOS-e820: 0000000020000000 - 0000000020200000 (reserved)
[ 0.000000] BIOS-e820: 0000000020200000 - 0000000040004000 (usable)
[ 0.000000] BIOS-e820: 0000000040004000 - 0000000040005000 (reserved)
[ 0.000000] BIOS-e820: 0000000040005000 - 00000000b90c0000 (usable)
[ 0.000000] BIOS-e820: 00000000b90c0000 - 00000000b983d000 (reserved)
[ 0.000000] BIOS-e820: 00000000b983d000 - 00000000b98c7000 (usable)
[ 0.000000] BIOS-e820: 00000000b98c7000 - 00000000b9967000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000b9967000 - 00000000ba154000 (reserved)
[ 0.000000] BIOS-e820: 00000000ba154000 - 00000000ba155000 (usable)
[ 0.000000] BIOS-e820: 00000000ba155000 - 00000000ba198000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000ba198000 - 00000000babe4000 (usable)
[ 0.000000] BIOS-e820: 00000000babe4000 - 00000000baff2000 (reserved)
[ 0.000000] BIOS-e820: 00000000baff2000 - 00000000bb000000 (usable)
[ 0.000000] BIOS-e820: 00000000bb800000 - 00000000bfa00000 (reserved)
[ 0.000000] BIOS-e820: 00000000f8000000 - 00000000fc000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed00000 - 00000000fed04000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed1c000 - 00000000fed20000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff000000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 000000023f600000 (usable)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.7 present.
[ 0.000000] DMI: To Be Filled By O.E.M. To Be Filled By O.E.M./Z75 Pro3, BIOS P2.00 10/01/2013
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0xbb000 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-E7FFF uncachable
[ 0.000000] E8000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask E00000000 write-back
[ 0.000000] 1 base 200000000 mask FC0000000 write-back
[ 0.000000] 2 base 0C0000000 mask FC0000000 uncachable
[ 0.000000] 3 base 0BC000000 mask FFC000000 uncachable
[ 0.000000] 4 base 0BB800000 mask FFF800000 uncachable
[ 0.000000] 5 base 23F800000 mask FFF800000 uncachable
[ 0.000000] 6 base 23F600000 mask FFFE00000 uncachable
[ 0.000000] 7 disabled
[ 0.000000] 8 disabled
[ 0.000000] 9 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 00000000bb800000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] found SMP MP-table at [c00fd880] fd880
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c0099000] 99000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 3652a000 - 3728d000
[ 0.000000] ACPI: RSDP 000f0490 00024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT b994b080 0007C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP b9954d40 0010C (v05 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT b994b190 09BAD (v02 ALASKA A M I 00000022 INTL 20051117)
[ 0.000000] ACPI: FACS b9965080 00040
[ 0.000000] ACPI: APIC b9954e50 00072 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT b9954ec8 00044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: MCFG b9954f10 0003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.000000] ACPI: SSDT b9954f50 007E1 (v01 Intel_ AoacTabl 00001000 INTL 20091112)
[ 0.000000] ACPI: AAFT b9955738 000EA (v01 ALASKA OEMAAFT 01072009 MSFT 00000097)
[ 0.000000] ACPI: HPET b9955828 00038 (v01 ALASKA A M I 01072009 AMI. 00000005)
[ 0.000000] ACPI: SSDT b9955860 0036D (v01 SataRe SataTabl 00001000 INTL 20091112)
[ 0.000000] ACPI: SSDT b9955bd0 009AA (v01 PmRef Cpu0Ist 00003000 INTL 20051117)
[ 0.000000] ACPI: SSDT b9956580 00A92 (v01 PmRef CpuPm 00003000 INTL 20051117)
[ 0.000000] ACPI: BGRT b9957018 00038 (v00 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 2104MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x000bb000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009d
[ 0.000000] 0: 0x00000100 -> 0x00020000
[ 0.000000] 0: 0x00020200 -> 0x00040004
[ 0.000000] 0: 0x00040005 -> 0x000b90c0
[ 0.000000] 0: 0x000b983d -> 0x000b98c7
[ 0.000000] 0: 0x000ba154 -> 0x000ba155
[ 0.000000] 0: 0x000ba198 -> 0x000babe4
[ 0.000000] 0: 0x000baff2 -> 0x000bb000
[ 0.000000] On node 0 totalpages: 760113
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f4dca200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3949 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 220974 pages, LIFO batch:31
[ 0.000000] HighMem zone: 4209 pages used for memmap
[ 0.000000] HighMem zone: 529205 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009d000 - 000000000009e000
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] PM: Registered nosave memory: 0000000020000000 - 0000000020200000
[ 0.000000] Allocating PCI resources starting at bfa00000 (gap: bfa00000:38600000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77a7000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 754128
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=35a8ce2c-4a0a-4758-83ac-6bd05d7bd0fb ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] xsave/xrstor: enabled xstate_bv 0x7, cntxt size 0x340
[ 0.000000] allocated 6127488 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:000bb000)
[ 0.000000] Memory: 2989812k/3063808k available (3495k kernel code, 50640k reserved, 1237k data, 416k init, 2133656k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=f4006000 soft=f4008000
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.004000] Detected 3300.142 MHz processor.
[ 0.000001] Calibrating delay loop (skipped), value calculated using timer frequency.. 6600.28 BogoMIPS (lpj=13200568)
[ 0.000003] pid_max: default: 32768 minimum: 301
[ 0.000028] Security Framework initialized
[ 0.000030] AppArmor: AppArmor disabled by boot time parameter
[ 0.000041] Mount-cache hash table entries: 512
[ 0.000153] Initializing cgroup subsys cpuacct
[ 0.000155] Initializing cgroup subsys memory
[ 0.000159] Initializing cgroup subsys devices
[ 0.000160] Initializing cgroup subsys freezer
[ 0.000161] Initializing cgroup subsys net_cls
[ 0.000163] Initializing cgroup subsys blkio
[ 0.000166] Initializing cgroup subsys perf_event
[ 0.000183] CPU: Physical Processor ID: 0
[ 0.000184] CPU: Processor Core ID: 0
[ 0.000188] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.000188] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[ 0.000190] mce: CPU supports 7 MCE banks
[ 0.000198] CPU0: Thermal monitoring enabled (TM1)
[ 0.000267] ACPI: Core revision 20120320
[ 0.007200] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.007614] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.047263] CPU0: Intel(R) Core(TM) i3-3220 CPU @ 3.30GHz stepping 09
[ 0.152440] Performance Events: PEBS fmt1+, generic architected perfmon, Intel PMU driver.
[ 0.152445] ... version: 3
[ 0.152446] ... bit width: 48
[ 0.152447] ... generic registers: 4
[ 0.152448] ... value mask: 0000ffffffffffff
[ 0.152449] ... max period: 000000007fffffff
[ 0.152451] ... fixed-purpose events: 3
[ 0.152452] ... event mask: 000000070000000f
[ 0.164480] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.176435] CPU 1 irqstacks, hard=f40f6000 soft=f40f8000
[ 0.176437] Booting Node 0, Processors #1
[ 0.186620] Initializing CPU#1
[ 0.189572] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.196418] CPU 2 irqstacks, hard=f4108000 soft=f410a000
[ 0.196420] #2
[ 0.206514] Initializing CPU#2
[ 0.209454] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.216399] CPU 3 irqstacks, hard=f411c000 soft=f411e000
[ 0.216402] #3 Ok.
[ 0.226580] Initializing CPU#3
[ 0.229531] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.229554] Brought up 4 CPUs
[ 0.229556] Total of 4 processors activated (26401.13 BogoMIPS).
[ 0.231713] devtmpfs: initialized
[ 0.231861] PM: Registering ACPI NVS region [mem 0xb98c7000-0xb9966fff] (655360 bytes)
[ 0.231875] PM: Registering ACPI NVS region [mem 0xba155000-0xba197fff] (274432 bytes)
[ 0.231942] dummy:
[ 0.231979] NET: Registered protocol family 16
[ 0.232055] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.232057] ACPI: bus type pci registered
[ 0.232092] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.232094] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.232096] PCI: Using MMCONFIG for extended config space
[ 0.232097] PCI: Using configuration type 1 for base access
[ 0.232500] bio: create slab <bio-0> at 0
[ 0.232565] ACPI: Added _OSI(Module Device)
[ 0.232566] ACPI: Added _OSI(Processor Device)
[ 0.232568] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.232569] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.234075] ACPI: EC: Look up EC in DSDT
[ 0.235703] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.238978] ACPI: SSDT b97ea018 0083B (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.239373] ACPI: Dynamic OEM Table Load:
[ 0.239375] ACPI: SSDT (null) 0083B (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.239599] ACPI: SSDT b97eba98 00303 (v01 PmRef ApIst 00003000 INTL 20051117)
[ 0.240024] ACPI: Dynamic OEM Table Load:
[ 0.240026] ACPI: SSDT (null) 00303 (v01 PmRef ApIst 00003000 INTL 20051117)
[ 0.240117] ACPI: SSDT b97ecc18 00119 (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.240504] ACPI: Dynamic OEM Table Load:
[ 0.240506] ACPI: SSDT (null) 00119 (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.241026] ACPI: Interpreter enabled
[ 0.241035] ACPI: (supports S0 S3 S4 S5)
[ 0.241052] ACPI: Using IOAPIC for interrupt routing
[ 0.246305] ACPI: No dock devices found.
[ 0.246309] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.246589] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[ 0.246967] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
[ 0.246969] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.246971] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.246973] pci_root PNP0A08:00: host bridge window [mem 0x000d0000-0x000d3fff]
[ 0.246974] pci_root PNP0A08:00: host bridge window [mem 0x000d4000-0x000d7fff]
[ 0.246976] pci_root PNP0A08:00: host bridge window [mem 0x000d8000-0x000dbfff]
[ 0.246977] pci_root PNP0A08:00: host bridge window [mem 0x000dc000-0x000dffff]
[ 0.246979] pci_root PNP0A08:00: host bridge window [mem 0x000e0000-0x000e3fff]
[ 0.246980] pci_root PNP0A08:00: host bridge window [mem 0x000e4000-0x000e7fff]
[ 0.246982] pci_root PNP0A08:00: host bridge window [mem 0xbfa00000-0xfeafffff]
[ 0.247001] PCI host bridge to bus 0000:00
[ 0.247003] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.247005] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.247006] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.247008] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff]
[ 0.247009] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff]
[ 0.247011] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff]
[ 0.247012] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff]
[ 0.247014] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff]
[ 0.247015] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff]
[ 0.247017] pci_bus 0000:00: root bus resource [mem 0xbfa00000-0xfeafffff]
[ 0.247024] pci 0000:00:00.0: [8086:0150] type 00 class 0x060000
[ 0.247052] pci 0000:00:01.0: [8086:0151] type 01 class 0x060400
[ 0.247072] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.247089] pci 0000:00:02.0: [8086:0152] type 00 class 0x038000
[ 0.247098] pci 0000:00:02.0: reg 10: [mem 0xf7400000-0xf77fffff 64bit]
[ 0.247103] pci 0000:00:02.0: reg 18: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.247107] pci 0000:00:02.0: reg 20: [io 0xf000-0xf03f]
[ 0.247148] pci 0000:00:14.0: [8086:1e31] type 00 class 0x0c0330
[ 0.247169] pci 0000:00:14.0: reg 10: [mem 0xf7900000-0xf790ffff 64bit]
[ 0.247225] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.247247] pci 0000:00:16.0: [8086:1e3a] type 00 class 0x078000
[ 0.247269] pci 0000:00:16.0: reg 10: [mem 0xf791a000-0xf791a00f 64bit]
[ 0.247329] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.247359] pci 0000:00:1a.0: [8086:1e2d] type 00 class 0x0c0320
[ 0.247379] pci 0000:00:1a.0: reg 10: [mem 0xf7918000-0xf79183ff]
[ 0.247450] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.247475] pci 0000:00:1b.0: [8086:1e20] type 00 class 0x040300
[ 0.247489] pci 0000:00:1b.0: reg 10: [mem 0xf7910000-0xf7913fff 64bit]
[ 0.247540] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.247560] pci 0000:00:1c.0: [8086:1e10] type 01 class 0x060400
[ 0.247620] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.247647] pci 0000:00:1c.4: [8086:244e] type 01 class 0x060401
[ 0.247706] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.247729] pci 0000:00:1c.5: [8086:1e1a] type 01 class 0x060400
[ 0.247789] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[ 0.247813] pci 0000:00:1c.6: [8086:1e1c] type 01 class 0x060400
[ 0.247872] pci 0000:00:1c.6: PME# supported from D0 D3hot D3cold
[ 0.247900] pci 0000:00:1d.0: [8086:1e26] type 00 class 0x0c0320
[ 0.247920] pci 0000:00:1d.0: reg 10: [mem 0xf7917000-0xf79173ff]
[ 0.247990] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.248014] pci 0000:00:1f.0: [8086:1e46] type 00 class 0x060100
[ 0.248123] pci 0000:00:1f.2: [8086:1e02] type 00 class 0x010601
[ 0.248140] pci 0000:00:1f.2: reg 10: [io 0xf0b0-0xf0b7]
[ 0.248148] pci 0000:00:1f.2: reg 14: [io 0xf0a0-0xf0a3]
[ 0.248155] pci 0000:00:1f.2: reg 18: [io 0xf090-0xf097]
[ 0.248163] pci 0000:00:1f.2: reg 1c: [io 0xf080-0xf083]
[ 0.248170] pci 0000:00:1f.2: reg 20: [io 0xf060-0xf07f]
[ 0.248178] pci 0000:00:1f.2: reg 24: [mem 0xf7916000-0xf79167ff]
[ 0.248208] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.248225] pci 0000:00:1f.3: [8086:1e22] type 00 class 0x0c0500
[ 0.248239] pci 0000:00:1f.3: reg 10: [mem 0xf7915000-0xf79150ff 64bit]
[ 0.248259] pci 0000:00:1f.3: reg 20: [io 0xf040-0xf05f]
[ 0.248305] pci 0000:01:00.0: [10de:0611] type 00 class 0x030000
[ 0.248312] pci 0000:01:00.0: reg 10: [mem 0xf6000000-0xf6ffffff]
[ 0.248318] pci 0000:01:00.0: reg 14: [mem 0xc0000000-0xdfffffff 64bit pref]
[ 0.248325] pci 0000:01:00.0: reg 1c: [mem 0xf4000000-0xf5ffffff 64bit]
[ 0.248330] pci 0000:01:00.0: reg 24: [io 0xe000-0xe07f]
[ 0.248335] pci 0000:01:00.0: reg 30: [mem 0xf7000000-0xf701ffff pref]
[ 0.256349] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.256353] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.256358] pci 0000:00:01.0: bridge window [mem 0xf4000000-0xf70fffff]
[ 0.256363] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xdfffffff 64bit pref]
[ 0.256449] pci 0000:02:00.0: [168c:0032] type 00 class 0x028000
[ 0.256475] pci 0000:02:00.0: reg 10: [mem 0xf7800000-0xf787ffff 64bit]
[ 0.256538] pci 0000:02:00.0: reg 30: [mem 0xf7880000-0xf788ffff pref]
[ 0.256576] pci 0000:02:00.0: supports D1 D2
[ 0.256577] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.264345] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.264353] pci 0000:00:1c.0: bridge window [mem 0xf7800000-0xf78fffff]
[ 0.264440] pci 0000:03:00.0: [1b21:1080] type 01 class 0x060401
[ 0.264572] pci 0000:00:1c.4: PCI bridge to [bus 03-04] (subtractive decode)
[ 0.264583] pci 0000:00:1c.4: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.264584] pci 0000:00:1c.4: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.264586] pci 0000:00:1c.4: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.264588] pci 0000:00:1c.4: bridge window [mem 0x000d0000-0x000d3fff] (subtractive decode)
[ 0.264589] pci 0000:00:1c.4: bridge window [mem 0x000d4000-0x000d7fff] (subtractive decode)
[ 0.264591] pci 0000:00:1c.4: bridge window [mem 0x000d8000-0x000dbfff] (subtractive decode)
[ 0.264592] pci 0000:00:1c.4: bridge window [mem 0x000dc000-0x000dffff] (subtractive decode)
[ 0.264594] pci 0000:00:1c.4: bridge window [mem 0x000e0000-0x000e3fff] (subtractive decode)
[ 0.264596] pci 0000:00:1c.4: bridge window [mem 0x000e4000-0x000e7fff] (subtractive decode)
[ 0.264597] pci 0000:00:1c.4: bridge window [mem 0xbfa00000-0xfeafffff] (subtractive decode)
[ 0.264742] pci 0000:03:00.0: PCI bridge to [bus 04-04] (subtractive decode)
[ 0.264768] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.264770] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.264771] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.264773] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.264774] pci 0000:03:00.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.264776] pci 0000:03:00.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.264778] pci 0000:03:00.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.264779] pci 0000:03:00.0: bridge window [mem 0x000d0000-0x000d3fff] (subtractive decode)
[ 0.264781] pci 0000:03:00.0: bridge window [mem 0x000d4000-0x000d7fff] (subtractive decode)
[ 0.264783] pci 0000:03:00.0: bridge window [mem 0x000d8000-0x000dbfff] (subtractive decode)
[ 0.264784] pci 0000:03:00.0: bridge window [mem 0x000dc000-0x000dffff] (subtractive decode)
[ 0.264786] pci 0000:03:00.0: bridge window [mem 0x000e0000-0x000e3fff] (subtractive decode)
[ 0.264787] pci 0000:03:00.0: bridge window [mem 0x000e4000-0x000e7fff] (subtractive decode)
[ 0.264789] pci 0000:03:00.0: bridge window [mem 0xbfa00000-0xfeafffff] (subtractive decode)
[ 0.264865] pci 0000:05:00.0: [10ec:8168] type 00 class 0x020000
[ 0.264884] pci 0000:05:00.0: reg 10: [io 0xd000-0xd0ff]
[ 0.264917] pci 0000:05:00.0: reg 18: [mem 0xf0004000-0xf0004fff 64bit pref]
[ 0.264938] pci 0000:05:00.0: reg 20: [mem 0xf0000000-0xf0003fff 64bit pref]
[ 0.264995] pci 0000:05:00.0: supports D1 D2
[ 0.264997] pci 0000:05:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.272339] pci 0000:00:1c.5: PCI bridge to [bus 05-05]
[ 0.272345] pci 0000:00:1c.5: bridge window [io 0xd000-0xdfff]
[ 0.272356] pci 0000:00:1c.5: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.272439] pci 0000:06:00.0: [1415:c110] type 00 class 0x070102
[ 0.272459] pci 0000:06:00.0: reg 10: [io 0xc010-0xc017]
[ 0.272473] pci 0000:06:00.0: reg 14: [io 0xc000-0xc003]
[ 0.272575] pci 0000:06:00.0: supports D1 D2
[ 0.272576] pci 0000:06:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.280331] pci 0000:00:1c.6: PCI bridge to [bus 06-06]
[ 0.280336] pci 0000:00:1c.6: bridge window [io 0xc000-0xcfff]
[ 0.280373] pci_bus 0000:00: on NUMA node 0
[ 0.280377] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.280579] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[ 0.280615] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP05._PRT]
[ 0.280647] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP05.PE2P._PRT]
[ 0.280693] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP06._PRT]
[ 0.280724] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP07._PRT]
[ 0.280756] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEG0._PRT]
[ 0.280881] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.285665] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.285705] ACPI: PCI Interrupt Link [LNKB] (IRQs *3 4 5 6 10 11 12 14 15)
[ 0.285744] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.285781] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.285819] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.285858] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.285896] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 10 11 12 14 15)
[ 0.285934] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.285986] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.285989] vgaarb: loaded
[ 0.285990] vgaarb: bridge control possible 0000:01:00.0
[ 0.286005] PCI: Using ACPI for IRQ routing
[ 0.287431] PCI: pci_cache_line_size set to 64 bytes
[ 0.287495] reserve RAM buffer: 000000000009d800 - 000000000009ffff
[ 0.287497] reserve RAM buffer: 0000000040004000 - 0000000043ffffff
[ 0.287499] reserve RAM buffer: 00000000b90c0000 - 00000000bbffffff
[ 0.287500] reserve RAM buffer: 00000000b98c7000 - 00000000bbffffff
[ 0.287502] reserve RAM buffer: 00000000ba155000 - 00000000bbffffff
[ 0.287504] reserve RAM buffer: 00000000babe4000 - 00000000bbffffff
[ 0.287505] reserve RAM buffer: 00000000bb000000 - 00000000bbffffff
[ 0.287587] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.287593] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.289608] Switching to clocksource hpet
[ 0.289649] pnp: PnP ACPI init
[ 0.289655] ACPI: bus type pnp registered
[ 0.289864] pnp 00:00: [bus 00-3e]
[ 0.289866] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.289868] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.289869] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.289871] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.289872] pnp 00:00: [mem 0x000c0000-0x000c3fff window]
[ 0.289874] pnp 00:00: [mem 0x000c4000-0x000c7fff window]
[ 0.289875] pnp 00:00: [mem 0x000c8000-0x000cbfff window]
[ 0.289877] pnp 00:00: [mem 0x000cc000-0x000cffff window]
[ 0.289878] pnp 00:00: [mem 0x000d0000-0x000d3fff window]
[ 0.289879] pnp 00:00: [mem 0x000d4000-0x000d7fff window]
[ 0.289881] pnp 00:00: [mem 0x000d8000-0x000dbfff window]
[ 0.289882] pnp 00:00: [mem 0x000dc000-0x000dffff window]
[ 0.289884] pnp 00:00: [mem 0x000e0000-0x000e3fff window]
[ 0.289885] pnp 00:00: [mem 0x000e4000-0x000e7fff window]
[ 0.289886] pnp 00:00: [mem 0x000e8000-0x000ebfff window]
[ 0.289888] pnp 00:00: [mem 0x000ec000-0x000effff window]
[ 0.289889] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 0.289891] pnp 00:00: [mem 0xbfa00000-0xfeafffff window]
[ 0.289892] pnp 00:00: [mem 0x00010000-0x0001ffff window]
[ 0.289923] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.289940] pnp 00:01: [mem 0xfed40000-0xfed44fff]
[ 0.289963] system 00:01: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.289965] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.289973] pnp 00:02: [io 0x0000-0x001f]
[ 0.289975] pnp 00:02: [io 0x0081-0x0091]
[ 0.289976] pnp 00:02: [io 0x0093-0x009f]
[ 0.289977] pnp 00:02: [io 0x00c0-0x00df]
[ 0.289979] pnp 00:02: [dma 4]
[ 0.289992] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.289997] pnp 00:03: [mem 0xff000000-0xffffffff]
[ 0.290010] pnp 00:03: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.290062] pnp 00:04: [mem 0xfed00000-0xfed003ff]
[ 0.290076] pnp 00:04: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.290084] pnp 00:05: [io 0x002e-0x002f]
[ 0.290086] pnp 00:05: [io 0x004e-0x004f]
[ 0.290087] pnp 00:05: [io 0x0061]
[ 0.290088] pnp 00:05: [io 0x0063]
[ 0.290089] pnp 00:05: [io 0x0065]
[ 0.290090] pnp 00:05: [io 0x0067]
[ 0.290092] pnp 00:05: [io 0x0070]
[ 0.290093] pnp 00:05: [io 0x0080]
[ 0.290094] pnp 00:05: [io 0x0092]
[ 0.290095] pnp 00:05: [io 0x00b2-0x00b3]
[ 0.290097] pnp 00:05: [io 0x0680-0x069f]
[ 0.290098] pnp 00:05: [io 0x1000-0x100f]
[ 0.290099] pnp 00:05: [io 0xffff]
[ 0.290100] pnp 00:05: [io 0xffff]
[ 0.290102] pnp 00:05: [io 0x0400-0x0453]
[ 0.290103] pnp 00:05: [io 0x0458-0x047f]
[ 0.290104] pnp 00:05: [io 0x0500-0x057f]
[ 0.290105] pnp 00:05: [io 0x164e-0x164f]
[ 0.290133] system 00:05: [io 0x0680-0x069f] has been reserved
[ 0.290135] system 00:05: [io 0x1000-0x100f] has been reserved
[ 0.290136] system 00:05: [io 0xffff] has been reserved
[ 0.290138] system 00:05: [io 0xffff] has been reserved
[ 0.290140] system 00:05: [io 0x0400-0x0453] has been reserved
[ 0.290141] system 00:05: [io 0x0458-0x047f] has been reserved
[ 0.290143] system 00:05: [io 0x0500-0x057f] has been reserved
[ 0.290145] system 00:05: [io 0x164e-0x164f] has been reserved
[ 0.290147] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.290152] pnp 00:06: [io 0x0070-0x0077]
[ 0.290158] pnp 00:06: [irq 8]
[ 0.290171] pnp 00:06: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.290190] pnp 00:07: [io 0x0454-0x0457]
[ 0.290213] system 00:07: [io 0x0454-0x0457] has been reserved
[ 0.290214] system 00:07: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.290254] pnp 00:08: [io 0x0000-0xffffffff disabled]
[ 0.290257] pnp 00:08: [io 0x0290-0x029f]
[ 0.290258] pnp 00:08: [io 0x0000-0xffffffff disabled]
[ 0.290282] system 00:08: [io 0x0290-0x029f] has been reserved
[ 0.290284] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.290459] pnp 00:09: [io 0x0010-0x001f]
[ 0.290460] pnp 00:09: [io 0x0022-0x003f]
[ 0.290461] pnp 00:09: [io 0x0044-0x005f]
[ 0.290463] pnp 00:09: [io 0x0062-0x0063]
[ 0.290464] pnp 00:09: [io 0x0065-0x006f]
[ 0.290465] pnp 00:09: [io 0x0072-0x007f]
[ 0.290466] pnp 00:09: [io 0x0080]
[ 0.290468] pnp 00:09: [io 0x0084-0x0086]
[ 0.290469] pnp 00:09: [io 0x0088]
[ 0.290470] pnp 00:09: [io 0x008c-0x008e]
[ 0.290471] pnp 00:09: [io 0x0090-0x009f]
[ 0.290472] pnp 00:09: [io 0x00a2-0x00bf]
[ 0.290474] pnp 00:09: [io 0x00e0-0x00ef]
[ 0.290475] pnp 00:09: [io 0x04d0-0x04d1]
[ 0.290501] system 00:09: [io 0x04d0-0x04d1] has been reserved
[ 0.290503] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.290509] pnp 00:0a: [io 0x00f0-0x00ff]
[ 0.290513] pnp 00:0a: [irq 13]
[ 0.290527] pnp 00:0a: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.290666] pnp 00:0b: [io 0x03f8-0x03ff]
[ 0.290669] pnp 00:0b: [irq 4]
[ 0.290671] pnp 00:0b: [dma 0 disabled]
[ 0.290707] pnp 00:0b: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.290892] pnp 00:0c: [mem 0xfed1c000-0xfed1ffff]
[ 0.290893] pnp 00:0c: [mem 0xfed10000-0xfed17fff]
[ 0.290895] pnp 00:0c: [mem 0xfed18000-0xfed18fff]
[ 0.290896] pnp 00:0c: [mem 0xfed19000-0xfed19fff]
[ 0.290897] pnp 00:0c: [mem 0xf8000000-0xfbffffff]
[ 0.290899] pnp 00:0c: [mem 0xfed20000-0xfed3ffff]
[ 0.290900] pnp 00:0c: [mem 0xfed90000-0xfed93fff]
[ 0.290901] pnp 00:0c: [mem 0xfed45000-0xfed8ffff]
[ 0.290903] pnp 00:0c: [mem 0xff000000-0xffffffff]
[ 0.290904] pnp 00:0c: [mem 0xfee00000-0xfeefffff]
[ 0.290905] pnp 00:0c: [mem 0xbfa00000-0xbfa00fff]
[ 0.290945] system 00:0c: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.290947] system 00:0c: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.290948] system 00:0c: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.290950] system 00:0c: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.290952] system 00:0c: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.290954] system 00:0c: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.290956] system 00:0c: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.290958] system 00:0c: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.290960] system 00:0c: [mem 0xff000000-0xffffffff] has been reserved
[ 0.290962] system 00:0c: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.290964] system 00:0c: [mem 0xbfa00000-0xbfa00fff] has been reserved
[ 0.290966] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.291085] pnp 00:0d: [mem 0x20000000-0x201fffff]
[ 0.291086] pnp 00:0d: [mem 0x40004000-0x40004fff]
[ 0.291126] system 00:0d: [mem 0x20000000-0x201fffff] has been reserved
[ 0.291127] system 00:0d: [mem 0x40004000-0x40004fff] has been reserved
[ 0.291129] system 00:0d: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.291151] pnp: PnP ACPI: found 14 devices
[ 0.291152] ACPI: ACPI bus type pnp unregistered
[ 0.291154] PnPBIOS: Disabled by ACPI PNP
[ 0.326985] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.326987] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.326990] pci 0000:00:01.0: bridge window [mem 0xf4000000-0xf70fffff]
[ 0.326992] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xdfffffff 64bit pref]
[ 0.326995] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.327000] pci 0000:00:1c.0: bridge window [mem 0xf7800000-0xf78fffff]
[ 0.327008] pci 0000:03:00.0: PCI bridge to [bus 04-04]
[ 0.327030] pci 0000:00:1c.4: PCI bridge to [bus 03-04]
[ 0.327041] pci 0000:00:1c.5: PCI bridge to [bus 05-05]
[ 0.327044] pci 0000:00:1c.5: bridge window [io 0xd000-0xdfff]
[ 0.327051] pci 0000:00:1c.5: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.327056] pci 0000:00:1c.6: PCI bridge to [bus 06-06]
[ 0.327059] pci 0000:00:1c.6: bridge window [io 0xc000-0xcfff]
[ 0.327101] pci 0000:03:00.0: setting latency timer to 64
[ 0.327119] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.327121] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.327122] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.327124] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff]
[ 0.327125] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff]
[ 0.327126] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff]
[ 0.327128] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff]
[ 0.327129] pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff]
[ 0.327131] pci_bus 0000:00: resource 12 [mem 0x000e4000-0x000e7fff]
[ 0.327132] pci_bus 0000:00: resource 13 [mem 0xbfa00000-0xfeafffff]
[ 0.327134] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.327135] pci_bus 0000:01: resource 1 [mem 0xf4000000-0xf70fffff]
[ 0.327137] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xdfffffff 64bit pref]
[ 0.327139] pci_bus 0000:02: resource 1 [mem 0xf7800000-0xf78fffff]
[ 0.327140] pci_bus 0000:03: resource 4 [io 0x0000-0x0cf7]
[ 0.327142] pci_bus 0000:03: resource 5 [io 0x0d00-0xffff]
[ 0.327143] pci_bus 0000:03: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.327144] pci_bus 0000:03: resource 7 [mem 0x000d0000-0x000d3fff]
[ 0.327146] pci_bus 0000:03: resource 8 [mem 0x000d4000-0x000d7fff]
[ 0.327147] pci_bus 0000:03: resource 9 [mem 0x000d8000-0x000dbfff]
[ 0.327149] pci_bus 0000:03: resource 10 [mem 0x000dc000-0x000dffff]
[ 0.327150] pci_bus 0000:03: resource 11 [mem 0x000e0000-0x000e3fff]
[ 0.327152] pci_bus 0000:03: resource 12 [mem 0x000e4000-0x000e7fff]
[ 0.327153] pci_bus 0000:03: resource 13 [mem 0xbfa00000-0xfeafffff]
[ 0.327155] pci_bus 0000:04: resource 8 [io 0x0000-0x0cf7]
[ 0.327156] pci_bus 0000:04: resource 9 [io 0x0d00-0xffff]
[ 0.327158] pci_bus 0000:04: resource 10 [mem 0x000a0000-0x000bffff]
[ 0.327159] pci_bus 0000:04: resource 11 [mem 0x000d0000-0x000d3fff]
[ 0.327161] pci_bus 0000:04: resource 12 [mem 0x000d4000-0x000d7fff]
[ 0.327162] pci_bus 0000:04: resource 13 [mem 0x000d8000-0x000dbfff]
[ 0.327164] pci_bus 0000:04: resource 14 [mem 0x000dc000-0x000dffff]
[ 0.327165] pci_bus 0000:04: resource 15 [mem 0x000e0000-0x000e3fff]
[ 0.327167] pci_bus 0000:04: resource 16 [mem 0x000e4000-0x000e7fff]
[ 0.327168] pci_bus 0000:04: resource 17 [mem 0xbfa00000-0xfeafffff]
[ 0.327170] pci_bus 0000:05: resource 0 [io 0xd000-0xdfff]
[ 0.327171] pci_bus 0000:05: resource 2 [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.327173] pci_bus 0000:06: resource 0 [io 0xc000-0xcfff]
[ 0.327234] NET: Registered protocol family 2
[ 0.327270] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.327380] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.327510] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.327569] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.327571] TCP: reno registered
[ 0.327574] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.327577] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.327634] NET: Registered protocol family 1
[ 0.365567] pci 0000:01:00.0: Boot video device
[ 0.365585] PCI: CLS 64 bytes, default 64
[ 0.365635] Unpacking initramfs...
[ 0.553117] Freeing initrd memory: 13708k freed
[ 0.554717] audit: initializing netlink socket (disabled)
[ 0.554729] type=2000 audit(1490131603.448:1): initialized
[ 0.563313] highmem bounce pool size: 64 pages
[ 0.563317] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.563486] VFS: Disk quotas dquot_6.5.2
[ 0.563505] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.563551] msgmni has been set to 1698
[ 0.563667] alg: No test for stdrng (krng)
[ 0.563689] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.563691] io scheduler noop registered
[ 0.563692] io scheduler deadline registered
[ 0.563710] io scheduler cfq registered (default)
[ 0.563910] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.563920] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.563921] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.564249] GHES: HEST is not enabled!
[ 0.564257] isapnp: Scanning for PnP cards...
[ 0.918675] isapnp: No Plug & Play device found
[ 0.918705] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.939104] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.959764] 00:0b: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.959917] Linux agpgart interface v0.103
[ 0.959992] agpgart-intel 0000:00:00.0: Intel Ivybridge Chipset
[ 0.960042] agpgart-intel 0000:00:00.0: detected gtt size: 2097152K total, 262144K mappable
[ 0.960723] agpgart-intel 0000:00:00.0: detected 65536K stolen memory
[ 0.960801] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xe0000000
[ 0.960886] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 0.963775] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.963784] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.963861] mousedev: PS/2 mouse device common for all mice
[ 0.963893] rtc_cmos 00:06: RTC can wake from S4
[ 0.964016] rtc_cmos 00:06: rtc core: registered rtc_cmos as rtc0
[ 0.964042] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 0.964126] TCP: cubic registered
[ 0.964178] NET: Registered protocol family 10
[ 0.964313] Mobile IPv6
[ 0.964315] NET: Registered protocol family 17
[ 0.964318] Registering the dns_resolver key type
[ 0.964353] Using IPI No-Shortcut mode
[ 0.964420] PM: Hibernation image not present or could not be loaded.
[ 0.964428] registered taskstats version 1
[ 0.964807] rtc_cmos 00:06: setting system clock to 2017-03-21 21:26:44 UTC (1490131604)
[ 0.964882] Freeing unused kernel memory: 416k freed
[ 0.964978] Write protecting the kernel text: 3496k
[ 0.964994] Write protecting the kernel read-only data: 984k
[ 0.971839] udevd[58]: starting version 175
[ 0.981702] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 0.981706] usbcore: registered new interface driver usbfs
[ 0.981724] usbcore: registered new interface driver hub
[ 0.982010] r8169 0000:05:00.0: eth0: RTL8168evl/8111evl at 0xf801a000, bc:5f:f4:6a:38:c3, XID 0c900800 IRQ 17
[ 0.982013] r8169 0000:05:00.0: eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 0.982401] usbcore: registered new device driver usb
[ 0.982695] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.982742] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[ 0.982746] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[ 0.982764] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 0.982787] ehci_hcd 0000:00:1a.0: debug port 2
[ 0.986681] ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported
[ 0.986703] ehci_hcd 0000:00:1a.0: irq 16, io mem 0xf7918000
[ 0.989731] microcode: CPU0 sig=0x306a9, pf=0x2, revision=0x12
[ 0.992338] SCSI subsystem initialized
[ 0.996975] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 0.996998] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.997001] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.997004] usb usb1: Product: EHCI Host Controller
[ 0.997006] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 0.997008] usb usb1: SerialNumber: 0000:00:1a.0
[ 0.997705] hub 1-0:1.0: USB hub found
[ 0.997710] hub 1-0:1.0: 2 ports detected
[ 0.997824] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 0.997828] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[ 0.997836] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.997859] ehci_hcd 0000:00:1d.0: debug port 2
[ 1.002161] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
[ 1.002182] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xf7917000
[ 1.005012] libata version 3.00 loaded.
[ 1.013177] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 1.013201] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.013203] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.013206] usb usb2: Product: EHCI Host Controller
[ 1.013207] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.013210] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.014105] hub 2-0:1.0: USB hub found
[ 1.014111] hub 2-0:1.0: 2 ports detected
[ 1.014240] xhci_hcd 0000:00:14.0: setting latency timer to 64
[ 1.014244] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.014253] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 1.014343] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 1.014376] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.014379] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.014381] usb usb3: Product: xHCI Host Controller
[ 1.014383] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.014385] usb usb3: SerialNumber: 0000:00:14.0
[ 1.014462] xHCI xhci_add_endpoint called for root hub
[ 1.014464] xHCI xhci_check_bandwidth called for root hub
[ 1.014491] hub 3-0:1.0: USB hub found
[ 1.014499] hub 3-0:1.0: 4 ports detected
[ 1.014563] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.014569] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[ 1.014591] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.014593] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.014595] usb usb4: Product: xHCI Host Controller
[ 1.014597] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.014599] usb usb4: SerialNumber: 0000:00:14.0
[ 1.014664] xHCI xhci_add_endpoint called for root hub
[ 1.014666] xHCI xhci_check_bandwidth called for root hub
[ 1.014692] hub 4-0:1.0: USB hub found
[ 1.014699] hub 4-0:1.0: 4 ports detected
[ 1.023930] microcode: CPU0 updated to revision 0x1b, date = 2014-05-29
[ 1.023941] microcode: CPU1 sig=0x306a9, pf=0x2, revision=0x12
[ 1.024992] ahci 0000:00:1f.2: version 3.0
[ 1.025730] microcode: CPU1 updated to revision 0x1b, date = 2014-05-29
[ 1.025738] microcode: CPU2 sig=0x306a9, pf=0x2, revision=0x12
[ 1.027518] microcode: CPU2 updated to revision 0x1b, date = 2014-05-29
[ 1.027529] microcode: CPU3 sig=0x306a9, pf=0x2, revision=0x12
[ 1.029072] microcode: CPU3 updated to revision 0x1b, date = 2014-05-29
[ 1.029129] microcode: Microcode Update Driver: v2.00 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba
[ 1.040925] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x3f impl SATA mode
[ 1.040930] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo pio slum part ems apst
[ 1.040938] ahci 0000:00:1f.2: setting latency timer to 64
[ 1.081217] scsi0 : ahci
[ 1.081299] scsi1 : ahci
[ 1.081349] scsi2 : ahci
[ 1.081398] scsi3 : ahci
[ 1.081449] scsi4 : ahci
[ 1.081495] scsi5 : ahci
[ 1.081777] ata1: SATA max UDMA/133 abar m2048@0xf7916000 port 0xf7916100 irq 19
[ 1.081780] ata2: SATA max UDMA/133 abar m2048@0xf7916000 port 0xf7916180 irq 19
[ 1.081783] ata3: SATA max UDMA/133 abar m2048@0xf7916000 port 0xf7916200 irq 19
[ 1.081785] ata4: SATA max UDMA/133 abar m2048@0xf7916000 port 0xf7916280 irq 19
[ 1.081788] ata5: SATA max UDMA/133 abar m2048@0xf7916000 port 0xf7916300 irq 19
[ 1.081790] ata6: SATA max UDMA/133 abar m2048@0xf7916000 port 0xf7916380 irq 19
[ 1.308634] usb 1-1: new high-speed USB device number 2 using ehci_hcd
[ 1.400564] ata2: SATA link down (SStatus 0 SControl 300)
[ 1.400592] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.400622] ata5: SATA link down (SStatus 0 SControl 300)
[ 1.400640] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.400656] ata4: SATA link down (SStatus 0 SControl 300)
[ 1.400678] ata6: SATA link down (SStatus 0 SControl 300)
[ 1.401628] ata3.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.401633] ata3.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.401638] ata3.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.439742] ata3.00: ATA-7: ST3320620AS, 3.AAK, max UDMA/133
[ 1.439746] ata3.00: 625142448 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 1.440812] usb 1-1: New USB device found, idVendor=8087, idProduct=0024
[ 1.440815] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.441080] hub 1-1:1.0: USB hub found
[ 1.441180] hub 1-1:1.0: 6 ports detected
[ 1.465284] ata3.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.465289] ata3.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.465294] ata3.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.497991] ata3.00: configured for UDMA/133
[ 1.498094] scsi 2:0:0:0: Direct-Access ATA ST3320620AS 3.AA PQ: 0 ANSI: 5
[ 1.500733] sd 2:0:0:0: [sda] 625142448 512-byte logical blocks: (320 GB/298 GiB)
[ 1.500797] sd 2:0:0:0: [sda] Write Protect is off
[ 1.500800] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.500821] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.552407] Refined TSC clocksource calibration: 3300.022 MHz.
[ 1.552412] usb 2-1: new high-speed USB device number 2 using ehci_hcd
[ 1.552420] Switching to clocksource tsc
[ 1.563140] sda: sda1 sda2 sda3 sda4 < sda5 sda6 >
[ 1.563445] sd 2:0:0:0: [sda] Attached SCSI disk
[ 1.564392] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 1.684697] usb 2-1: New USB device found, idVendor=8087, idProduct=0024
[ 1.684702] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.684969] hub 2-1:1.0: USB hub found
[ 1.685067] hub 2-1:1.0: 8 ports detected
[ 1.852105] usb 3-3: new low-speed USB device number 2 using xhci_hcd
[ 1.872493] usb 3-3: New USB device found, idVendor=046d, idProduct=c016
[ 1.872498] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.872501] usb 3-3: Product: Optical USB Mouse
[ 1.872504] usb 3-3: Manufacturer: Logitech
[ 1.872589] usb 3-3: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 1.876059] input: Logitech Optical USB Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.0/input/input0
[ 1.876129] generic-usb 0003:046D:C016.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-0000:00:14.0-3/input0
[ 1.876143] usbcore: registered new interface driver usbhid
[ 1.876144] usbhid: USB HID core driver
[ 1.944077] usb 1-1.5: new full-speed USB device number 3 using ehci_hcd
[ 2.038851] usb 1-1.5: New USB device found, idVendor=046d, idProduct=c52b
[ 2.038856] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.038860] usb 1-1.5: Product: USB Receiver
[ 2.038863] usb 1-1.5: Manufacturer: Logitech
[ 2.044342] logitech-djreceiver 0003:046D:C52B.0004: hiddev0,hidraw1: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:1a.0-1.5/input2
[ 2.048184] input: Logitech Unifying Device. Wireless PID:400e as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.5/1-1.5:1.2/0003:046D:C52B.0004/input/input1
[ 2.048237] logitech-djdevice 0003:046D:C52B.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:400e] on usb-0000:00:1a.0-1.5:1
[ 2.112036] usb 2-1.5: new full-speed USB device number 3 using ehci_hcd
[ 2.209435] usb 2-1.5: New USB device found, idVendor=2687, idProduct=fb01
[ 2.209440] usb 2-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.209444] usb 2-1.5: Product: Fitbit Base Station
[ 2.209447] usb 2-1.5: Manufacturer: Fitbit Inc.
[ 2.209449] usb 2-1.5: SerialNumber: \xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf
[ 2.212272] generic-usb 0003:2687:FB01.0006: hiddev0,hidraw3: USB HID v1.11 Device [Fitbit Inc. Fitbit Base Station] on usb-0000:00:1d.0-1.5/input0
[ 2.214768] generic-usb 0003:2687:FB01.0007: hiddev0,hidraw4: USB HID v1.11 Device [Fitbit Inc. Fitbit Base Station] on usb-0000:00:1d.0-1.5/input1
[ 2.283862] usb 2-1.6: new full-speed USB device number 4 using ehci_hcd
[ 2.438091] usb 2-1.6: New USB device found, idVendor=0a12, idProduct=0001
[ 2.438095] usb 2-1.6: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 7.205384] PM: Starting manual resume from disk
[ 7.205386] PM: Hibernation image partition 8:6 present
[ 7.205388] PM: Looking for hibernation image.
[ 7.205561] PM: Image not found (code -22)
[ 7.205564] PM: Hibernation image not present or could not be loaded.
[ 7.236837] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
[ 8.765306] udevd[440]: starting version 175
[ 9.033353] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 9.033358] ACPI: Power Button [PWRB]
[ 9.033405] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 9.033409] ACPI: Power Button [PWRF]
[ 9.289261] acpi device:42: registered as cooling_device0
[ 9.289406] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input4
[ 9.289410] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 9.600576] [drm] Initialized drm 1.1.0 20060810
[ 9.642661] iTCO_vendor_support: vendor-support=0
[ 9.643338] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 9.643401] iTCO_wdt: Found a Panther Point TCO device (Version=2, TCOBASE=0x0460)
[ 9.643629] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 9.683219] PCI parallel port detected: 1415:c000, I/O at 0xc010(0xc000), IRQ 18
[ 9.683367] parport0: PC-style at 0xc010 (0xc000), irq 18 [PCSPP,TRISTATE,EPP]
[ 9.716554] Bluetooth: Core ver 2.16
[ 9.716565] NET: Registered protocol family 31
[ 9.716566] Bluetooth: HCI device and connection manager initialized
[ 9.716568] Bluetooth: HCI socket layer initialized
[ 9.716569] Bluetooth: L2CAP socket layer initialized
[ 9.716573] Bluetooth: SCO socket layer initialized
[ 9.759193] cfg80211: Calling CRDA to update world regulatory domain
[ 9.806670] usbcore: registered new interface driver btusb
[ 9.937116] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5
[ 9.937181] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[ 9.937223] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 9.937294] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 9.937335] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 9.937374] input: HDA Intel PCH Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 9.937414] input: HDA Intel PCH Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 9.937456] input: HDA Intel PCH Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 9.937495] input: HDA Intel PCH Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[ 9.937782] ACPI Warning: 0x0000f040-0x0000f05f SystemIO conflicts with Region \_SB_.PCI0.SBUS.SMBI 1 (20120320/utaddress-251)
[ 9.937790] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 9.938175] i915 0000:00:02.0: setting latency timer to 64
[ 9.953258] mtrr: type mismatch for e0000000,10000000 old: write-back new: write-combining
[ 9.953260] [drm] MTRR allocation failed. Graphics performance may suffer.
[ 9.953377] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 9.953379] [drm] Driver supports precise vblank timestamp query.
[ 9.967883] [drm] Enabling RC6 states: RC6 on, RC6p on, RC6pp off
[ 10.146208] ath: EEPROM regdomain: 0x3a
[ 10.146210] ath: EEPROM indicates we should expect a direct regpair map
[ 10.146212] ath: Country alpha2 being used: CA
[ 10.146214] ath: Regpair used: 0x3a
[ 10.192000] No connectors reported connected with modes
[ 10.192007] [drm] Cannot find any crtc or sizes - going 1024x768
[ 10.196055] Console: switching to colour frame buffer device 128x48
[ 10.197337] fb0: inteldrmfb frame buffer device
[ 10.197338] drm: registered panic notifier
[ 10.197342] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 10.208367] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 10.208541] Registered led device: ath9k-phy0
[ 10.208547] ieee80211 phy0: Atheros AR9485 Rev:1 mem=0xf8c80000, irq=16
[ 10.216117] udevd[491]: renamed network interface wlan0 to wlan1
[ 10.963252] cfg80211: World regulatory domain updated:
[ 10.963256] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 10.963258] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 10.963259] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 10.963261] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 10.963262] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 10.963263] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 10.963265] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[ 10.963266] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 10.963268] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[ 10.963275] cfg80211: Calling CRDA for country: CA
[ 10.975709] cfg80211: Regulatory domain changed to country: CA
[ 10.975711] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 10.975713] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[ 10.975715] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 1700 mBm)
[ 10.975716] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2400 mBm)
[ 10.975718] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2400 mBm)
[ 10.975719] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[ 12.155724] Adding 1922044k swap on /dev/sda6. Priority:-1 extents:1 across:1922044k
[ 12.163468] EXT4-fs (sda5): re-mounted. Opts: (null)
[ 12.326016] EXT4-fs (sda5): re-mounted. Opts: errors=remount-ro
[ 12.375548] loop: module loaded
[ 13.146852] RPC: Registered named UNIX socket transport module.
[ 13.146855] RPC: Registered udp transport module.
[ 13.146856] RPC: Registered tcp transport module.
[ 13.146857] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 13.174528] FS-Cache: Loaded
[ 13.194946] NFS: Registering the id_resolver key type
[ 13.194957] FS-Cache: Netfs 'nfs' registered for caching
[ 13.198920] Installing knfsd (copyright (C) 1996 This email address is being protected from spambots. You need JavaScript enabled to view it.).
[ 15.003832] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input14
[ 15.525073] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 15.525076] Bluetooth: BNEP filters: protocol multicast
[ 15.551690] Bluetooth: RFCOMM TTY layer initialized
[ 15.551694] Bluetooth: RFCOMM socket layer initialized
[ 15.551696] Bluetooth: RFCOMM ver 1.11
[ 16.096508] lp0: using parport0 (interrupt-driven).
[ 16.182385] ppdev: user-space parallel port driver
[ 17.793520] ADDRCONF(NETDEV_UP): wlan1: link is not ready
[ 18.137235] r8169 0000:05:00.0: eth0: link down
[ 18.137319] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 19.673612] usb 2-1.6: USB disconnect, device number 4
[ 19.879831] mtrr: base(0xf5000000) is not aligned on a size(0xe00000) boundary
[ 19.934614] usb 2-1.6: new full-speed USB device number 5 using ehci_hcd
[ 20.333105] usb 2-1.6: New USB device found, idVendor=0a12, idProduct=0001
[ 20.333111] usb 2-1.6: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 20.566460] wlan1: authenticate with 00:ac:e0:94:54:d0
[ 20.574516] wlan1: send auth to 00:ac:e0:94:54:d0 (try 1/3)
[ 20.581141] wlan1: authenticated
[ 20.585526] wlan1: associating with AP with corrupt probe response
[ 20.585925] wlan1: associate with 00:ac:e0:94:54:d0 (try 1/3)
[ 20.591519] wlan1: RX AssocResp from 00:ac:e0:94:54:d0 (capab=0xc31 status=0 aid=6)
[ 20.595955] ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[ 20.595988] wlan1: associated
[ 20.596006] cfg80211: Calling CRDA for country: US
[ 20.598574] cfg80211: Regulatory domain changed to country: US
[ 20.598576] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 20.598578] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[ 20.598580] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 1700 mBm)
[ 20.598581] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[ 20.598582] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[ 20.598584] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[ 26.824625] wlan1: deauthenticated from 00:ac:e0:94:54:d0 (Reason: 15)
[ 26.832328] cfg80211: Calling CRDA to update world regulatory domain
[ 26.834742] cfg80211: World regulatory domain updated:
[ 26.834745] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 26.834747] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 26.834748] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 26.834750] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 26.834751] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 26.834752] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 26.834754] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[ 26.834755] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 26.834757] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[ 27.551565] wlan1: authenticate with 00:ac:e0:94:54:d0
[ 27.555879] wlan1: send auth to 00:ac:e0:94:54:d0 (try 1/3)
[ 27.560096] wlan1: authenticated
[ 27.564516] wlan1: associating with AP with corrupt probe response
[ 27.567145] wlan1: associate with 00:ac:e0:94:54:d0 (try 1/3)
[ 27.582025] wlan1: RX AssocResp from 00:ac:e0:94:54:d0 (capab=0xc31 status=0 aid=6)
[ 27.586497] wlan1: associated
[ 27.586515] cfg80211: Calling CRDA for country: US
[ 27.588966] cfg80211: Regulatory domain changed to country: US
[ 27.588969] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 27.588971] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[ 27.588972] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 1700 mBm)
[ 27.588974] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[ 27.588975] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[ 27.588977] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[ 120.492240] I-pipe: head domain RTAI registered.
[ 120.492244] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 120.492288] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 120.492290] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6249599, CLK_FREQ 3300142000, CPU_FREQ 3300142000
[ 120.492292] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 120.492294] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6249599, 6249599, 2087000
[ 121.401266] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 121.401294] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 121.401297] RTAI[sched]: hard timer type/freq = APIC/6249599(Hz); default timing: oneshot; linear timed lists.
[ 121.401299] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3300142000 hz.
[ 121.401300] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 121.454302] RTAI[math]: loaded.
[ 121.917033] config string 'c010 out'
[ 127.350174] RTAI[math]: unloaded.
[ 127.351168] SCHED releases registered named ALIEN PEDV$D
[ 127.354176] RTAI[malloc]: unloaded.
[ 127.450174] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 127.451322] I-pipe: head domain RTAI unregistered.
[ 127.451374] RTAI[hal]: unmounted.
[ 233.524590] I-pipe: head domain RTAI registered.
[ 233.524594] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 233.524637] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 233.524639] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6249599, CLK_FREQ 3300142000, CPU_FREQ 3300142000
[ 233.524641] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 233.524643] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6249599, 6249599, 6180000
[ 233.528082] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 233.528103] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 233.528105] RTAI[sched]: hard timer type/freq = APIC/6249599(Hz); default timing: oneshot; linear timed lists.
[ 233.528108] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3300142000 hz.
[ 233.528109] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 233.532104] RTAI[math]: loaded.
[ 233.659978] config string 'c010 out'
[ 236.255256] RTAI[math]: unloaded.
[ 236.256203] SCHED releases registered named ALIEN PEDV$D
[ 236.258652] RTAI[malloc]: unloaded.
[ 236.356427] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 236.357724] I-pipe: head domain RTAI unregistered.
[ 236.357773] RTAI[hal]: unmounted.
[ 605.704915] I-pipe: head domain RTAI registered.
[ 605.704919] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 605.704962] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 605.704965] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6249599, CLK_FREQ 3300142000, CPU_FREQ 3300142000
[ 605.704967] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 605.704970] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6249599, 6249599, 5649500
[ 605.708411] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 605.708433] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 605.708436] RTAI[sched]: hard timer type/freq = APIC/6249599(Hz); default timing: oneshot; linear timed lists.
[ 605.708439] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3300142000 hz.
[ 605.708441] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 605.714741] RTAI[math]: loaded.
[ 605.742287] config string 'c010 out'
[ 608.321477] RTAI[math]: unloaded.
[ 608.322422] SCHED releases registered named ALIEN PEDV$D
[ 608.325160] RTAI[malloc]: unloaded.
[ 608.423216] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 608.424431] I-pipe: head domain RTAI unregistered.
[ 608.424482] RTAI[hal]: unmounted.
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.8.0-pre1-2263-gf13afe1
Machine configuration directory is '/home/parish/linuxcnc/configs/TaigMill'
Machine configuration file is 'TaigMill.ini'
INIFILE=/home/parish/linuxcnc/configs/TaigMill/TaigMill.ini
VERSION=1.0
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./TaigMill.hal
Found file(REL): ./custom.hal
Starting DISPLAY program: axis
Killing task linuxcncsvr, PID=4903
Killing task milltask, PID=4952
task: 61 cycles, min=0.000005, max=0.010094, avg=0.005191, 0 latency excursions (> 10x expected cycle time of 0.010000s)
Debug file information:
note: MAXV max: 1.000 units/sec 60.000 units/min
note: LJOG max: 1.000 units/sec 60.000 units/min
note: LJOG default: 0.100 units/sec 6.000 units/min
note: jog_order='XYZ'
note: jog_invert=set([])
Xlib: extension "GLX" missing on display ":0.0".
File "/usr/bin/axis", line 3502, in <module>
o = MyOpengl(widgets.preview_frame, width=400, height=300, double=1, depth=1)
File "/usr/bin/axis", line 377, in __init__
Opengl.__init__(self, *args, **kw)
File "/usr/lib/pymodules/python2.7/rs274/OpenGLTk.py", line 164, in __init__
apply(RawOpengl.__init__, (self, master, cnf), kw)
File "/usr/lib/pymodules/python2.7/rs274/OpenGLTk.py", line 112, in __init__
Togl.__init__(self, master, cnf, **kw)
File "/usr/lib/pymodules/python2.7/rs274/OpenGLTk.py", line 38, in __init__
Widget.__init__(self, master, 'togl', cnf, kw)
File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 2001, in __init__
(widgetName, self._w) + extra + self._options(cnf))
_tkinter.TclError: Togl: X server has no OpenGL GLX extension
4903
PID TTY STAT TIME COMMAND
4952
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009d800 (usable)
[ 0.000000] BIOS-e820: 000000000009d800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 0000000020000000 (usable)
[ 0.000000] BIOS-e820: 0000000020000000 - 0000000020200000 (reserved)
[ 0.000000] BIOS-e820: 0000000020200000 - 0000000040004000 (usable)
[ 0.000000] BIOS-e820: 0000000040004000 - 0000000040005000 (reserved)
[ 0.000000] BIOS-e820: 0000000040005000 - 00000000b90c0000 (usable)
[ 0.000000] BIOS-e820: 00000000b90c0000 - 00000000b983d000 (reserved)
[ 0.000000] BIOS-e820: 00000000b983d000 - 00000000b98c7000 (usable)
[ 0.000000] BIOS-e820: 00000000b98c7000 - 00000000b9967000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000b9967000 - 00000000ba154000 (reserved)
[ 0.000000] BIOS-e820: 00000000ba154000 - 00000000ba155000 (usable)
[ 0.000000] BIOS-e820: 00000000ba155000 - 00000000ba198000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000ba198000 - 00000000babe4000 (usable)
[ 0.000000] BIOS-e820: 00000000babe4000 - 00000000baff2000 (reserved)
[ 0.000000] BIOS-e820: 00000000baff2000 - 00000000bb000000 (usable)
[ 0.000000] BIOS-e820: 00000000bb800000 - 00000000bfa00000 (reserved)
[ 0.000000] BIOS-e820: 00000000f8000000 - 00000000fc000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed00000 - 00000000fed04000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed1c000 - 00000000fed20000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff000000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 000000023f600000 (usable)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.7 present.
[ 0.000000] DMI: To Be Filled By O.E.M. To Be Filled By O.E.M./Z75 Pro3, BIOS P2.00 10/01/2013
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0xbb000 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-E7FFF uncachable
[ 0.000000] E8000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask E00000000 write-back
[ 0.000000] 1 base 200000000 mask FC0000000 write-back
[ 0.000000] 2 base 0C0000000 mask FC0000000 uncachable
[ 0.000000] 3 base 0BC000000 mask FFC000000 uncachable
[ 0.000000] 4 base 0BB800000 mask FFF800000 uncachable
[ 0.000000] 5 base 23F800000 mask FFF800000 uncachable
[ 0.000000] 6 base 23F600000 mask FFFE00000 uncachable
[ 0.000000] 7 disabled
[ 0.000000] 8 disabled
[ 0.000000] 9 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 00000000bb800000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] found SMP MP-table at [c00fd880] fd880
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c0099000] 99000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 3652a000 - 3728d000
[ 0.000000] ACPI: RSDP 000f0490 00024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT b994b080 0007C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP b9954d40 0010C (v05 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT b994b190 09BAD (v02 ALASKA A M I 00000022 INTL 20051117)
[ 0.000000] ACPI: FACS b9965080 00040
[ 0.000000] ACPI: APIC b9954e50 00072 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT b9954ec8 00044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: MCFG b9954f10 0003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.000000] ACPI: SSDT b9954f50 007E1 (v01 Intel_ AoacTabl 00001000 INTL 20091112)
[ 0.000000] ACPI: AAFT b9955738 000EA (v01 ALASKA OEMAAFT 01072009 MSFT 00000097)
[ 0.000000] ACPI: HPET b9955828 00038 (v01 ALASKA A M I 01072009 AMI. 00000005)
[ 0.000000] ACPI: SSDT b9955860 0036D (v01 SataRe SataTabl 00001000 INTL 20091112)
[ 0.000000] ACPI: SSDT b9955bd0 009AA (v01 PmRef Cpu0Ist 00003000 INTL 20051117)
[ 0.000000] ACPI: SSDT b9956580 00A92 (v01 PmRef CpuPm 00003000 INTL 20051117)
[ 0.000000] ACPI: BGRT b9957018 00038 (v00 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 2104MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x000bb000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009d
[ 0.000000] 0: 0x00000100 -> 0x00020000
[ 0.000000] 0: 0x00020200 -> 0x00040004
[ 0.000000] 0: 0x00040005 -> 0x000b90c0
[ 0.000000] 0: 0x000b983d -> 0x000b98c7
[ 0.000000] 0: 0x000ba154 -> 0x000ba155
[ 0.000000] 0: 0x000ba198 -> 0x000babe4
[ 0.000000] 0: 0x000baff2 -> 0x000bb000
[ 0.000000] On node 0 totalpages: 760113
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f4dca200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3949 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 220974 pages, LIFO batch:31
[ 0.000000] HighMem zone: 4209 pages used for memmap
[ 0.000000] HighMem zone: 529205 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009d000 - 000000000009e000
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] PM: Registered nosave memory: 0000000020000000 - 0000000020200000
[ 0.000000] Allocating PCI resources starting at bfa00000 (gap: bfa00000:38600000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77a7000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 754128
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=35a8ce2c-4a0a-4758-83ac-6bd05d7bd0fb ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] xsave/xrstor: enabled xstate_bv 0x7, cntxt size 0x340
[ 0.000000] allocated 6127488 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:000bb000)
[ 0.000000] Memory: 2989812k/3063808k available (3495k kernel code, 50640k reserved, 1237k data, 416k init, 2133656k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=f4006000 soft=f4008000
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.004000] Detected 3300.142 MHz processor.
[ 0.000001] Calibrating delay loop (skipped), value calculated using timer frequency.. 6600.28 BogoMIPS (lpj=13200568)
[ 0.000003] pid_max: default: 32768 minimum: 301
[ 0.000028] Security Framework initialized
[ 0.000030] AppArmor: AppArmor disabled by boot time parameter
[ 0.000041] Mount-cache hash table entries: 512
[ 0.000153] Initializing cgroup subsys cpuacct
[ 0.000155] Initializing cgroup subsys memory
[ 0.000159] Initializing cgroup subsys devices
[ 0.000160] Initializing cgroup subsys freezer
[ 0.000161] Initializing cgroup subsys net_cls
[ 0.000163] Initializing cgroup subsys blkio
[ 0.000166] Initializing cgroup subsys perf_event
[ 0.000183] CPU: Physical Processor ID: 0
[ 0.000184] CPU: Processor Core ID: 0
[ 0.000188] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.000188] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[ 0.000190] mce: CPU supports 7 MCE banks
[ 0.000198] CPU0: Thermal monitoring enabled (TM1)
[ 0.000267] ACPI: Core revision 20120320
[ 0.007200] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.007614] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.047263] CPU0: Intel(R) Core(TM) i3-3220 CPU @ 3.30GHz stepping 09
[ 0.152440] Performance Events: PEBS fmt1+, generic architected perfmon, Intel PMU driver.
[ 0.152445] ... version: 3
[ 0.152446] ... bit width: 48
[ 0.152447] ... generic registers: 4
[ 0.152448] ... value mask: 0000ffffffffffff
[ 0.152449] ... max period: 000000007fffffff
[ 0.152451] ... fixed-purpose events: 3
[ 0.152452] ... event mask: 000000070000000f
[ 0.164480] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.176435] CPU 1 irqstacks, hard=f40f6000 soft=f40f8000
[ 0.176437] Booting Node 0, Processors #1
[ 0.186620] Initializing CPU#1
[ 0.189572] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.196418] CPU 2 irqstacks, hard=f4108000 soft=f410a000
[ 0.196420] #2
[ 0.206514] Initializing CPU#2
[ 0.209454] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.216399] CPU 3 irqstacks, hard=f411c000 soft=f411e000
[ 0.216402] #3 Ok.
[ 0.226580] Initializing CPU#3
[ 0.229531] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.229554] Brought up 4 CPUs
[ 0.229556] Total of 4 processors activated (26401.13 BogoMIPS).
[ 0.231713] devtmpfs: initialized
[ 0.231861] PM: Registering ACPI NVS region [mem 0xb98c7000-0xb9966fff] (655360 bytes)
[ 0.231875] PM: Registering ACPI NVS region [mem 0xba155000-0xba197fff] (274432 bytes)
[ 0.231942] dummy:
[ 0.231979] NET: Registered protocol family 16
[ 0.232055] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.232057] ACPI: bus type pci registered
[ 0.232092] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.232094] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.232096] PCI: Using MMCONFIG for extended config space
[ 0.232097] PCI: Using configuration type 1 for base access
[ 0.232500] bio: create slab <bio-0> at 0
[ 0.232565] ACPI: Added _OSI(Module Device)
[ 0.232566] ACPI: Added _OSI(Processor Device)
[ 0.232568] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.232569] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.234075] ACPI: EC: Look up EC in DSDT
[ 0.235703] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.238978] ACPI: SSDT b97ea018 0083B (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.239373] ACPI: Dynamic OEM Table Load:
[ 0.239375] ACPI: SSDT (null) 0083B (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.239599] ACPI: SSDT b97eba98 00303 (v01 PmRef ApIst 00003000 INTL 20051117)
[ 0.240024] ACPI: Dynamic OEM Table Load:
[ 0.240026] ACPI: SSDT (null) 00303 (v01 PmRef ApIst 00003000 INTL 20051117)
[ 0.240117] ACPI: SSDT b97ecc18 00119 (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.240504] ACPI: Dynamic OEM Table Load:
[ 0.240506] ACPI: SSDT (null) 00119 (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.241026] ACPI: Interpreter enabled
[ 0.241035] ACPI: (supports S0 S3 S4 S5)
[ 0.241052] ACPI: Using IOAPIC for interrupt routing
[ 0.246305] ACPI: No dock devices found.
[ 0.246309] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.246589] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[ 0.246967] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
[ 0.246969] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.246971] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.246973] pci_root PNP0A08:00: host bridge window [mem 0x000d0000-0x000d3fff]
[ 0.246974] pci_root PNP0A08:00: host bridge window [mem 0x000d4000-0x000d7fff]
[ 0.246976] pci_root PNP0A08:00: host bridge window [mem 0x000d8000-0x000dbfff]
[ 0.246977] pci_root PNP0A08:00: host bridge window [mem 0x000dc000-0x000dffff]
[ 0.246979] pci_root PNP0A08:00: host bridge window [mem 0x000e0000-0x000e3fff]
[ 0.246980] pci_root PNP0A08:00: host bridge window [mem 0x000e4000-0x000e7fff]
[ 0.246982] pci_root PNP0A08:00: host bridge window [mem 0xbfa00000-0xfeafffff]
[ 0.247001] PCI host bridge to bus 0000:00
[ 0.247003] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.247005] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.247006] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.247008] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff]
[ 0.247009] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff]
[ 0.247011] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff]
[ 0.247012] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff]
[ 0.247014] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff]
[ 0.247015] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff]
[ 0.247017] pci_bus 0000:00: root bus resource [mem 0xbfa00000-0xfeafffff]
[ 0.247024] pci 0000:00:00.0: [8086:0150] type 00 class 0x060000
[ 0.247052] pci 0000:00:01.0: [8086:0151] type 01 class 0x060400
[ 0.247072] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.247089] pci 0000:00:02.0: [8086:0152] type 00 class 0x038000
[ 0.247098] pci 0000:00:02.0: reg 10: [mem 0xf7400000-0xf77fffff 64bit]
[ 0.247103] pci 0000:00:02.0: reg 18: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.247107] pci 0000:00:02.0: reg 20: [io 0xf000-0xf03f]
[ 0.247148] pci 0000:00:14.0: [8086:1e31] type 00 class 0x0c0330
[ 0.247169] pci 0000:00:14.0: reg 10: [mem 0xf7900000-0xf790ffff 64bit]
[ 0.247225] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.247247] pci 0000:00:16.0: [8086:1e3a] type 00 class 0x078000
[ 0.247269] pci 0000:00:16.0: reg 10: [mem 0xf791a000-0xf791a00f 64bit]
[ 0.247329] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.247359] pci 0000:00:1a.0: [8086:1e2d] type 00 class 0x0c0320
[ 0.247379] pci 0000:00:1a.0: reg 10: [mem 0xf7918000-0xf79183ff]
[ 0.247450] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.247475] pci 0000:00:1b.0: [8086:1e20] type 00 class 0x040300
[ 0.247489] pci 0000:00:1b.0: reg 10: [mem 0xf7910000-0xf7913fff 64bit]
[ 0.247540] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.247560] pci 0000:00:1c.0: [8086:1e10] type 01 class 0x060400
[ 0.247620] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.247647] pci 0000:00:1c.4: [8086:244e] type 01 class 0x060401
[ 0.247706] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.247729] pci 0000:00:1c.5: [8086:1e1a] type 01 class 0x060400
[ 0.247789] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[ 0.247813] pci 0000:00:1c.6: [8086:1e1c] type 01 class 0x060400
[ 0.247872] pci 0000:00:1c.6: PME# supported from D0 D3hot D3cold
[ 0.247900] pci 0000:00:1d.0: [8086:1e26] type 00 class 0x0c0320
[ 0.247920] pci 0000:00:1d.0: reg 10: [mem 0xf7917000-0xf79173ff]
[ 0.247990] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.248014] pci 0000:00:1f.0: [8086:1e46] type 00 class 0x060100
[ 0.248123] pci 0000:00:1f.2: [8086:1e02] type 00 class 0x010601
[ 0.248140] pci 0000:00:1f.2: reg 10: [io 0xf0b0-0xf0b7]
[ 0.248148] pci 0000:00:1f.2: reg 14: [io 0xf0a0-0xf0a3]
[ 0.248155] pci 0000:00:1f.2: reg 18: [io 0xf090-0xf097]
[ 0.248163] pci 0000:00:1f.2: reg 1c: [io 0xf080-0xf083]
[ 0.248170] pci 0000:00:1f.2: reg 20: [io 0xf060-0xf07f]
[ 0.248178] pci 0000:00:1f.2: reg 24: [mem 0xf7916000-0xf79167ff]
[ 0.248208] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.248225] pci 0000:00:1f.3: [8086:1e22] type 00 class 0x0c0500
[ 0.248239] pci 0000:00:1f.3: reg 10: [mem 0xf7915000-0xf79150ff 64bit]
[ 0.248259] pci 0000:00:1f.3: reg 20: [io 0xf040-0xf05f]
[ 0.248305] pci 0000:01:00.0: [10de:0611] type 00 class 0x030000
[ 0.248312] pci 0000:01:00.0: reg 10: [mem 0xf6000000-0xf6ffffff]
[ 0.248318] pci 0000:01:00.0: reg 14: [mem 0xc0000000-0xdfffffff 64bit pref]
[ 0.248325] pci 0000:01:00.0: reg 1c: [mem 0xf4000000-0xf5ffffff 64bit]
[ 0.248330] pci 0000:01:00.0: reg 24: [io 0xe000-0xe07f]
[ 0.248335] pci 0000:01:00.0: reg 30: [mem 0xf7000000-0xf701ffff pref]
[ 0.256349] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.256353] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.256358] pci 0000:00:01.0: bridge window [mem 0xf4000000-0xf70fffff]
[ 0.256363] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xdfffffff 64bit pref]
[ 0.256449] pci 0000:02:00.0: [168c:0032] type 00 class 0x028000
[ 0.256475] pci 0000:02:00.0: reg 10: [mem 0xf7800000-0xf787ffff 64bit]
[ 0.256538] pci 0000:02:00.0: reg 30: [mem 0xf7880000-0xf788ffff pref]
[ 0.256576] pci 0000:02:00.0: supports D1 D2
[ 0.256577] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.264345] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.264353] pci 0000:00:1c.0: bridge window [mem 0xf7800000-0xf78fffff]
[ 0.264440] pci 0000:03:00.0: [1b21:1080] type 01 class 0x060401
[ 0.264572] pci 0000:00:1c.4: PCI bridge to [bus 03-04] (subtractive decode)
[ 0.264583] pci 0000:00:1c.4: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.264584] pci 0000:00:1c.4: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.264586] pci 0000:00:1c.4: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.264588] pci 0000:00:1c.4: bridge window [mem 0x000d0000-0x000d3fff] (subtractive decode)
[ 0.264589] pci 0000:00:1c.4: bridge window [mem 0x000d4000-0x000d7fff] (subtractive decode)
[ 0.264591] pci 0000:00:1c.4: bridge window [mem 0x000d8000-0x000dbfff] (subtractive decode)
[ 0.264592] pci 0000:00:1c.4: bridge window [mem 0x000dc000-0x000dffff] (subtractive decode)
[ 0.264594] pci 0000:00:1c.4: bridge window [mem 0x000e0000-0x000e3fff] (subtractive decode)
[ 0.264596] pci 0000:00:1c.4: bridge window [mem 0x000e4000-0x000e7fff] (subtractive decode)
[ 0.264597] pci 0000:00:1c.4: bridge window [mem 0xbfa00000-0xfeafffff] (subtractive decode)
[ 0.264742] pci 0000:03:00.0: PCI bridge to [bus 04-04] (subtractive decode)
[ 0.264768] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.264770] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.264771] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.264773] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.264774] pci 0000:03:00.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.264776] pci 0000:03:00.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.264778] pci 0000:03:00.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.264779] pci 0000:03:00.0: bridge window [mem 0x000d0000-0x000d3fff] (subtractive decode)
[ 0.264781] pci 0000:03:00.0: bridge window [mem 0x000d4000-0x000d7fff] (subtractive decode)
[ 0.264783] pci 0000:03:00.0: bridge window [mem 0x000d8000-0x000dbfff] (subtractive decode)
[ 0.264784] pci 0000:03:00.0: bridge window [mem 0x000dc000-0x000dffff] (subtractive decode)
[ 0.264786] pci 0000:03:00.0: bridge window [mem 0x000e0000-0x000e3fff] (subtractive decode)
[ 0.264787] pci 0000:03:00.0: bridge window [mem 0x000e4000-0x000e7fff] (subtractive decode)
[ 0.264789] pci 0000:03:00.0: bridge window [mem 0xbfa00000-0xfeafffff] (subtractive decode)
[ 0.264865] pci 0000:05:00.0: [10ec:8168] type 00 class 0x020000
[ 0.264884] pci 0000:05:00.0: reg 10: [io 0xd000-0xd0ff]
[ 0.264917] pci 0000:05:00.0: reg 18: [mem 0xf0004000-0xf0004fff 64bit pref]
[ 0.264938] pci 0000:05:00.0: reg 20: [mem 0xf0000000-0xf0003fff 64bit pref]
[ 0.264995] pci 0000:05:00.0: supports D1 D2
[ 0.264997] pci 0000:05:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.272339] pci 0000:00:1c.5: PCI bridge to [bus 05-05]
[ 0.272345] pci 0000:00:1c.5: bridge window [io 0xd000-0xdfff]
[ 0.272356] pci 0000:00:1c.5: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.272439] pci 0000:06:00.0: [1415:c110] type 00 class 0x070102
[ 0.272459] pci 0000:06:00.0: reg 10: [io 0xc010-0xc017]
[ 0.272473] pci 0000:06:00.0: reg 14: [io 0xc000-0xc003]
[ 0.272575] pci 0000:06:00.0: supports D1 D2
[ 0.272576] pci 0000:06:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.280331] pci 0000:00:1c.6: PCI bridge to [bus 06-06]
[ 0.280336] pci 0000:00:1c.6: bridge window [io 0xc000-0xcfff]
[ 0.280373] pci_bus 0000:00: on NUMA node 0
[ 0.280377] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.280579] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[ 0.280615] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP05._PRT]
[ 0.280647] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP05.PE2P._PRT]
[ 0.280693] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP06._PRT]
[ 0.280724] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP07._PRT]
[ 0.280756] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEG0._PRT]
[ 0.280881] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.285665] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.285705] ACPI: PCI Interrupt Link [LNKB] (IRQs *3 4 5 6 10 11 12 14 15)
[ 0.285744] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.285781] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.285819] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.285858] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.285896] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 10 11 12 14 15)
[ 0.285934] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.285986] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.285989] vgaarb: loaded
[ 0.285990] vgaarb: bridge control possible 0000:01:00.0
[ 0.286005] PCI: Using ACPI for IRQ routing
[ 0.287431] PCI: pci_cache_line_size set to 64 bytes
[ 0.287495] reserve RAM buffer: 000000000009d800 - 000000000009ffff
[ 0.287497] reserve RAM buffer: 0000000040004000 - 0000000043ffffff
[ 0.287499] reserve RAM buffer: 00000000b90c0000 - 00000000bbffffff
[ 0.287500] reserve RAM buffer: 00000000b98c7000 - 00000000bbffffff
[ 0.287502] reserve RAM buffer: 00000000ba155000 - 00000000bbffffff
[ 0.287504] reserve RAM buffer: 00000000babe4000 - 00000000bbffffff
[ 0.287505] reserve RAM buffer: 00000000bb000000 - 00000000bbffffff
[ 0.287587] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.287593] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.289608] Switching to clocksource hpet
[ 0.289649] pnp: PnP ACPI init
[ 0.289655] ACPI: bus type pnp registered
[ 0.289864] pnp 00:00: [bus 00-3e]
[ 0.289866] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.289868] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.289869] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.289871] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.289872] pnp 00:00: [mem 0x000c0000-0x000c3fff window]
[ 0.289874] pnp 00:00: [mem 0x000c4000-0x000c7fff window]
[ 0.289875] pnp 00:00: [mem 0x000c8000-0x000cbfff window]
[ 0.289877] pnp 00:00: [mem 0x000cc000-0x000cffff window]
[ 0.289878] pnp 00:00: [mem 0x000d0000-0x000d3fff window]
[ 0.289879] pnp 00:00: [mem 0x000d4000-0x000d7fff window]
[ 0.289881] pnp 00:00: [mem 0x000d8000-0x000dbfff window]
[ 0.289882] pnp 00:00: [mem 0x000dc000-0x000dffff window]
[ 0.289884] pnp 00:00: [mem 0x000e0000-0x000e3fff window]
[ 0.289885] pnp 00:00: [mem 0x000e4000-0x000e7fff window]
[ 0.289886] pnp 00:00: [mem 0x000e8000-0x000ebfff window]
[ 0.289888] pnp 00:00: [mem 0x000ec000-0x000effff window]
[ 0.289889] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 0.289891] pnp 00:00: [mem 0xbfa00000-0xfeafffff window]
[ 0.289892] pnp 00:00: [mem 0x00010000-0x0001ffff window]
[ 0.289923] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.289940] pnp 00:01: [mem 0xfed40000-0xfed44fff]
[ 0.289963] system 00:01: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.289965] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.289973] pnp 00:02: [io 0x0000-0x001f]
[ 0.289975] pnp 00:02: [io 0x0081-0x0091]
[ 0.289976] pnp 00:02: [io 0x0093-0x009f]
[ 0.289977] pnp 00:02: [io 0x00c0-0x00df]
[ 0.289979] pnp 00:02: [dma 4]
[ 0.289992] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.289997] pnp 00:03: [mem 0xff000000-0xffffffff]
[ 0.290010] pnp 00:03: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.290062] pnp 00:04: [mem 0xfed00000-0xfed003ff]
[ 0.290076] pnp 00:04: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.290084] pnp 00:05: [io 0x002e-0x002f]
[ 0.290086] pnp 00:05: [io 0x004e-0x004f]
[ 0.290087] pnp 00:05: [io 0x0061]
[ 0.290088] pnp 00:05: [io 0x0063]
[ 0.290089] pnp 00:05: [io 0x0065]
[ 0.290090] pnp 00:05: [io 0x0067]
[ 0.290092] pnp 00:05: [io 0x0070]
[ 0.290093] pnp 00:05: [io 0x0080]
[ 0.290094] pnp 00:05: [io 0x0092]
[ 0.290095] pnp 00:05: [io 0x00b2-0x00b3]
[ 0.290097] pnp 00:05: [io 0x0680-0x069f]
[ 0.290098] pnp 00:05: [io 0x1000-0x100f]
[ 0.290099] pnp 00:05: [io 0xffff]
[ 0.290100] pnp 00:05: [io 0xffff]
[ 0.290102] pnp 00:05: [io 0x0400-0x0453]
[ 0.290103] pnp 00:05: [io 0x0458-0x047f]
[ 0.290104] pnp 00:05: [io 0x0500-0x057f]
[ 0.290105] pnp 00:05: [io 0x164e-0x164f]
[ 0.290133] system 00:05: [io 0x0680-0x069f] has been reserved
[ 0.290135] system 00:05: [io 0x1000-0x100f] has been reserved
[ 0.290136] system 00:05: [io 0xffff] has been reserved
[ 0.290138] system 00:05: [io 0xffff] has been reserved
[ 0.290140] system 00:05: [io 0x0400-0x0453] has been reserved
[ 0.290141] system 00:05: [io 0x0458-0x047f] has been reserved
[ 0.290143] system 00:05: [io 0x0500-0x057f] has been reserved
[ 0.290145] system 00:05: [io 0x164e-0x164f] has been reserved
[ 0.290147] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.290152] pnp 00:06: [io 0x0070-0x0077]
[ 0.290158] pnp 00:06: [irq 8]
[ 0.290171] pnp 00:06: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.290190] pnp 00:07: [io 0x0454-0x0457]
[ 0.290213] system 00:07: [io 0x0454-0x0457] has been reserved
[ 0.290214] system 00:07: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.290254] pnp 00:08: [io 0x0000-0xffffffff disabled]
[ 0.290257] pnp 00:08: [io 0x0290-0x029f]
[ 0.290258] pnp 00:08: [io 0x0000-0xffffffff disabled]
[ 0.290282] system 00:08: [io 0x0290-0x029f] has been reserved
[ 0.290284] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.290459] pnp 00:09: [io 0x0010-0x001f]
[ 0.290460] pnp 00:09: [io 0x0022-0x003f]
[ 0.290461] pnp 00:09: [io 0x0044-0x005f]
[ 0.290463] pnp 00:09: [io 0x0062-0x0063]
[ 0.290464] pnp 00:09: [io 0x0065-0x006f]
[ 0.290465] pnp 00:09: [io 0x0072-0x007f]
[ 0.290466] pnp 00:09: [io 0x0080]
[ 0.290468] pnp 00:09: [io 0x0084-0x0086]
[ 0.290469] pnp 00:09: [io 0x0088]
[ 0.290470] pnp 00:09: [io 0x008c-0x008e]
[ 0.290471] pnp 00:09: [io 0x0090-0x009f]
[ 0.290472] pnp 00:09: [io 0x00a2-0x00bf]
[ 0.290474] pnp 00:09: [io 0x00e0-0x00ef]
[ 0.290475] pnp 00:09: [io 0x04d0-0x04d1]
[ 0.290501] system 00:09: [io 0x04d0-0x04d1] has been reserved
[ 0.290503] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.290509] pnp 00:0a: [io 0x00f0-0x00ff]
[ 0.290513] pnp 00:0a: [irq 13]
[ 0.290527] pnp 00:0a: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.290666] pnp 00:0b: [io 0x03f8-0x03ff]
[ 0.290669] pnp 00:0b: [irq 4]
[ 0.290671] pnp 00:0b: [dma 0 disabled]
[ 0.290707] pnp 00:0b: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.290892] pnp 00:0c: [mem 0xfed1c000-0xfed1ffff]
[ 0.290893] pnp 00:0c: [mem 0xfed10000-0xfed17fff]
[ 0.290895] pnp 00:0c: [mem 0xfed18000-0xfed18fff]
[ 0.290896] pnp 00:0c: [mem 0xfed19000-0xfed19fff]
[ 0.290897] pnp 00:0c: [mem 0xf8000000-0xfbffffff]
[ 0.290899] pnp 00:0c: [mem 0xfed20000-0xfed3ffff]
[ 0.290900] pnp 00:0c: [mem 0xfed90000-0xfed93fff]
[ 0.290901] pnp 00:0c: [mem 0xfed45000-0xfed8ffff]
[ 0.290903] pnp 00:0c: [mem 0xff000000-0xffffffff]
[ 0.290904] pnp 00:0c: [mem 0xfee00000-0xfeefffff]
[ 0.290905] pnp 00:0c: [mem 0xbfa00000-0xbfa00fff]
[ 0.290945] system 00:0c: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.290947] system 00:0c: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.290948] system 00:0c: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.290950] system 00:0c: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.290952] system 00:0c: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.290954] system 00:0c: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.290956] system 00:0c: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.290958] system 00:0c: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.290960] system 00:0c: [mem 0xff000000-0xffffffff] has been reserved
[ 0.290962] system 00:0c: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.290964] system 00:0c: [mem 0xbfa00000-0xbfa00fff] has been reserved
[ 0.290966] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.291085] pnp 00:0d: [mem 0x20000000-0x201fffff]
[ 0.291086] pnp 00:0d: [mem 0x40004000-0x40004fff]
[ 0.291126] system 00:0d: [mem 0x20000000-0x201fffff] has been reserved
[ 0.291127] system 00:0d: [mem 0x40004000-0x40004fff] has been reserved
[ 0.291129] system 00:0d: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.291151] pnp: PnP ACPI: found 14 devices
[ 0.291152] ACPI: ACPI bus type pnp unregistered
[ 0.291154] PnPBIOS: Disabled by ACPI PNP
[ 0.326985] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.326987] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.326990] pci 0000:00:01.0: bridge window [mem 0xf4000000-0xf70fffff]
[ 0.326992] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xdfffffff 64bit pref]
[ 0.326995] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.327000] pci 0000:00:1c.0: bridge window [mem 0xf7800000-0xf78fffff]
[ 0.327008] pci 0000:03:00.0: PCI bridge to [bus 04-04]
[ 0.327030] pci 0000:00:1c.4: PCI bridge to [bus 03-04]
[ 0.327041] pci 0000:00:1c.5: PCI bridge to [bus 05-05]
[ 0.327044] pci 0000:00:1c.5: bridge window [io 0xd000-0xdfff]
[ 0.327051] pci 0000:00:1c.5: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.327056] pci 0000:00:1c.6: PCI bridge to [bus 06-06]
[ 0.327059] pci 0000:00:1c.6: bridge window [io 0xc000-0xcfff]
[ 0.327101] pci 0000:03:00.0: setting latency timer to 64
[ 0.327119] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.327121] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.327122] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.327124] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff]
[ 0.327125] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff]
[ 0.327126] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff]
[ 0.327128] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff]
[ 0.327129] pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff]
[ 0.327131] pci_bus 0000:00: resource 12 [mem 0x000e4000-0x000e7fff]
[ 0.327132] pci_bus 0000:00: resource 13 [mem 0xbfa00000-0xfeafffff]
[ 0.327134] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.327135] pci_bus 0000:01: resource 1 [mem 0xf4000000-0xf70fffff]
[ 0.327137] pci_bus 0000:01: resource 2 [mem 0xc0000000-0xdfffffff 64bit pref]
[ 0.327139] pci_bus 0000:02: resource 1 [mem 0xf7800000-0xf78fffff]
[ 0.327140] pci_bus 0000:03: resource 4 [io 0x0000-0x0cf7]
[ 0.327142] pci_bus 0000:03: resource 5 [io 0x0d00-0xffff]
[ 0.327143] pci_bus 0000:03: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.327144] pci_bus 0000:03: resource 7 [mem 0x000d0000-0x000d3fff]
[ 0.327146] pci_bus 0000:03: resource 8 [mem 0x000d4000-0x000d7fff]
[ 0.327147] pci_bus 0000:03: resource 9 [mem 0x000d8000-0x000dbfff]
[ 0.327149] pci_bus 0000:03: resource 10 [mem 0x000dc000-0x000dffff]
[ 0.327150] pci_bus 0000:03: resource 11 [mem 0x000e0000-0x000e3fff]
[ 0.327152] pci_bus 0000:03: resource 12 [mem 0x000e4000-0x000e7fff]
[ 0.327153] pci_bus 0000:03: resource 13 [mem 0xbfa00000-0xfeafffff]
[ 0.327155] pci_bus 0000:04: resource 8 [io 0x0000-0x0cf7]
[ 0.327156] pci_bus 0000:04: resource 9 [io 0x0d00-0xffff]
[ 0.327158] pci_bus 0000:04: resource 10 [mem 0x000a0000-0x000bffff]
[ 0.327159] pci_bus 0000:04: resource 11 [mem 0x000d0000-0x000d3fff]
[ 0.327161] pci_bus 0000:04: resource 12 [mem 0x000d4000-0x000d7fff]
[ 0.327162] pci_bus 0000:04: resource 13 [mem 0x000d8000-0x000dbfff]
[ 0.327164] pci_bus 0000:04: resource 14 [mem 0x000dc000-0x000dffff]
[ 0.327165] pci_bus 0000:04: resource 15 [mem 0x000e0000-0x000e3fff]
[ 0.327167] pci_bus 0000:04: resource 16 [mem 0x000e4000-0x000e7fff]
[ 0.327168] pci_bus 0000:04: resource 17 [mem 0xbfa00000-0xfeafffff]
[ 0.327170] pci_bus 0000:05: resource 0 [io 0xd000-0xdfff]
[ 0.327171] pci_bus 0000:05: resource 2 [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.327173] pci_bus 0000:06: resource 0 [io 0xc000-0xcfff]
[ 0.327234] NET: Registered protocol family 2
[ 0.327270] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.327380] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.327510] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.327569] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.327571] TCP: reno registered
[ 0.327574] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.327577] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.327634] NET: Registered protocol family 1
[ 0.365567] pci 0000:01:00.0: Boot video device
[ 0.365585] PCI: CLS 64 bytes, default 64
[ 0.365635] Unpacking initramfs...
[ 0.553117] Freeing initrd memory: 13708k freed
[ 0.554717] audit: initializing netlink socket (disabled)
[ 0.554729] type=2000 audit(1490131603.448:1): initialized
[ 0.563313] highmem bounce pool size: 64 pages
[ 0.563317] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.563486] VFS: Disk quotas dquot_6.5.2
[ 0.563505] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.563551] msgmni has been set to 1698
[ 0.563667] alg: No test for stdrng (krng)
[ 0.563689] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.563691] io scheduler noop registered
[ 0.563692] io scheduler deadline registered
[ 0.563710] io scheduler cfq registered (default)
[ 0.563910] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.563920] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.563921] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.564249] GHES: HEST is not enabled!
[ 0.564257] isapnp: Scanning for PnP cards...
[ 0.918675] isapnp: No Plug & Play device found
[ 0.918705] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.939104] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.959764] 00:0b: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.959917] Linux agpgart interface v0.103
[ 0.959992] agpgart-intel 0000:00:00.0: Intel Ivybridge Chipset
[ 0.960042] agpgart-intel 0000:00:00.0: detected gtt size: 2097152K total, 262144K mappable
[ 0.960723] agpgart-intel 0000:00:00.0: detected 65536K stolen memory
[ 0.960801] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xe0000000
[ 0.960886] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 0.963775] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.963784] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.963861] mousedev: PS/2 mouse device common for all mice
[ 0.963893] rtc_cmos 00:06: RTC can wake from S4
[ 0.964016] rtc_cmos 00:06: rtc core: registered rtc_cmos as rtc0
[ 0.964042] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 0.964126] TCP: cubic registered
[ 0.964178] NET: Registered protocol family 10
[ 0.964313] Mobile IPv6
[ 0.964315] NET: Registered protocol family 17
[ 0.964318] Registering the dns_resolver key type
[ 0.964353] Using IPI No-Shortcut mode
[ 0.964420] PM: Hibernation image not present or could not be loaded.
[ 0.964428] registered taskstats version 1
[ 0.964807] rtc_cmos 00:06: setting system clock to 2017-03-21 21:26:44 UTC (1490131604)
[ 0.964882] Freeing unused kernel memory: 416k freed
[ 0.964978] Write protecting the kernel text: 3496k
[ 0.964994] Write protecting the kernel read-only data: 984k
[ 0.971839] udevd[58]: starting version 175
[ 0.981702] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 0.981706] usbcore: registered new interface driver usbfs
[ 0.981724] usbcore: registered new interface driver hub
[ 0.982010] r8169 0000:05:00.0: eth0: RTL8168evl/8111evl at 0xf801a000, bc:5f:f4:6a:38:c3, XID 0c900800 IRQ 17
[ 0.982013] r8169 0000:05:00.0: eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 0.982401] usbcore: registered new device driver usb
[ 0.982695] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.982742] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[ 0.982746] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[ 0.982764] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 0.982787] ehci_hcd 0000:00:1a.0: debug port 2
[ 0.986681] ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported
[ 0.986703] ehci_hcd 0000:00:1a.0: irq 16, io mem 0xf7918000
[ 0.989731] microcode: CPU0 sig=0x306a9, pf=0x2, revision=0x12
[ 0.992338] SCSI subsystem initialized
[ 0.996975] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 0.996998] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.997001] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.997004] usb usb1: Product: EHCI Host Controller
[ 0.997006] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 0.997008] usb usb1: SerialNumber: 0000:00:1a.0
[ 0.997705] hub 1-0:1.0: USB hub found
[ 0.997710] hub 1-0:1.0: 2 ports detected
[ 0.997824] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 0.997828] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[ 0.997836] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.997859] ehci_hcd 0000:00:1d.0: debug port 2
[ 1.002161] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
[ 1.002182] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xf7917000
[ 1.005012] libata version 3.00 loaded.
[ 1.013177] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 1.013201] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.013203] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.013206] usb usb2: Product: EHCI Host Controller
[ 1.013207] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.013210] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.014105] hub 2-0:1.0: USB hub found
[ 1.014111] hub 2-0:1.0: 2 ports detected
[ 1.014240] xhci_hcd 0000:00:14.0: setting latency timer to 64
[ 1.014244] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.014253] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 1.014343] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 1.014376] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.014379] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.014381] usb usb3: Product: xHCI Host Controller
[ 1.014383] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.014385] usb usb3: SerialNumber: 0000:00:14.0
[ 1.014462] xHCI xhci_add_endpoint called for root hub
[ 1.014464] xHCI xhci_check_bandwidth called for root hub
[ 1.014491] hub 3-0:1.0: USB hub found
[ 1.014499] hub 3-0:1.0: 4 ports detected
[ 1.014563] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.014569] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[ 1.014591] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.014593] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.014595] usb usb4: Product: xHCI Host Controller
[ 1.014597] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 1.014599] usb usb4: SerialNumber: 0000:00:14.0
[ 1.014664] xHCI xhci_add_endpoint called for root hub
[ 1.014666] xHCI xhci_check_bandwidth called for root hub
[ 1.014692] hub 4-0:1.0: USB hub found
[ 1.014699] hub 4-0:1.0: 4 ports detected
[ 1.023930] microcode: CPU0 updated to revision 0x1b, date = 2014-05-29
[ 1.023941] microcode: CPU1 sig=0x306a9, pf=0x2, revision=0x12
[ 1.024992] ahci 0000:00:1f.2: version 3.0
[ 1.025730] microcode: CPU1 updated to revision 0x1b, date = 2014-05-29
[ 1.025738] microcode: CPU2 sig=0x306a9, pf=0x2, revision=0x12
[ 1.027518] microcode: CPU2 updated to revision 0x1b, date = 2014-05-29
[ 1.027529] microcode: CPU3 sig=0x306a9, pf=0x2, revision=0x12
[ 1.029072] microcode: CPU3 updated to revision 0x1b, date = 2014-05-29
[ 1.029129] microcode: Microcode Update Driver: v2.00 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba
[ 1.040925] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x3f impl SATA mode
[ 1.040930] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo pio slum part ems apst
[ 1.040938] ahci 0000:00:1f.2: setting latency timer to 64
[ 1.081217] scsi0 : ahci
[ 1.081299] scsi1 : ahci
[ 1.081349] scsi2 : ahci
[ 1.081398] scsi3 : ahci
[ 1.081449] scsi4 : ahci
[ 1.081495] scsi5 : ahci
[ 1.081777] ata1: SATA max UDMA/133 abar m2048@0xf7916000 port 0xf7916100 irq 19
[ 1.081780] ata2: SATA max UDMA/133 abar m2048@0xf7916000 port 0xf7916180 irq 19
[ 1.081783] ata3: SATA max UDMA/133 abar m2048@0xf7916000 port 0xf7916200 irq 19
[ 1.081785] ata4: SATA max UDMA/133 abar m2048@0xf7916000 port 0xf7916280 irq 19
[ 1.081788] ata5: SATA max UDMA/133 abar m2048@0xf7916000 port 0xf7916300 irq 19
[ 1.081790] ata6: SATA max UDMA/133 abar m2048@0xf7916000 port 0xf7916380 irq 19
[ 1.308634] usb 1-1: new high-speed USB device number 2 using ehci_hcd
[ 1.400564] ata2: SATA link down (SStatus 0 SControl 300)
[ 1.400592] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.400622] ata5: SATA link down (SStatus 0 SControl 300)
[ 1.400640] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.400656] ata4: SATA link down (SStatus 0 SControl 300)
[ 1.400678] ata6: SATA link down (SStatus 0 SControl 300)
[ 1.401628] ata3.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.401633] ata3.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.401638] ata3.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.439742] ata3.00: ATA-7: ST3320620AS, 3.AAK, max UDMA/133
[ 1.439746] ata3.00: 625142448 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 1.440812] usb 1-1: New USB device found, idVendor=8087, idProduct=0024
[ 1.440815] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.441080] hub 1-1:1.0: USB hub found
[ 1.441180] hub 1-1:1.0: 6 ports detected
[ 1.465284] ata3.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.465289] ata3.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.465294] ata3.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.497991] ata3.00: configured for UDMA/133
[ 1.498094] scsi 2:0:0:0: Direct-Access ATA ST3320620AS 3.AA PQ: 0 ANSI: 5
[ 1.500733] sd 2:0:0:0: [sda] 625142448 512-byte logical blocks: (320 GB/298 GiB)
[ 1.500797] sd 2:0:0:0: [sda] Write Protect is off
[ 1.500800] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.500821] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.552407] Refined TSC clocksource calibration: 3300.022 MHz.
[ 1.552412] usb 2-1: new high-speed USB device number 2 using ehci_hcd
[ 1.552420] Switching to clocksource tsc
[ 1.563140] sda: sda1 sda2 sda3 sda4 < sda5 sda6 >
[ 1.563445] sd 2:0:0:0: [sda] Attached SCSI disk
[ 1.564392] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 1.684697] usb 2-1: New USB device found, idVendor=8087, idProduct=0024
[ 1.684702] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.684969] hub 2-1:1.0: USB hub found
[ 1.685067] hub 2-1:1.0: 8 ports detected
[ 1.852105] usb 3-3: new low-speed USB device number 2 using xhci_hcd
[ 1.872493] usb 3-3: New USB device found, idVendor=046d, idProduct=c016
[ 1.872498] usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.872501] usb 3-3: Product: Optical USB Mouse
[ 1.872504] usb 3-3: Manufacturer: Logitech
[ 1.872589] usb 3-3: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 1.876059] input: Logitech Optical USB Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.0/input/input0
[ 1.876129] generic-usb 0003:046D:C016.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-0000:00:14.0-3/input0
[ 1.876143] usbcore: registered new interface driver usbhid
[ 1.876144] usbhid: USB HID core driver
[ 1.944077] usb 1-1.5: new full-speed USB device number 3 using ehci_hcd
[ 2.038851] usb 1-1.5: New USB device found, idVendor=046d, idProduct=c52b
[ 2.038856] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.038860] usb 1-1.5: Product: USB Receiver
[ 2.038863] usb 1-1.5: Manufacturer: Logitech
[ 2.044342] logitech-djreceiver 0003:046D:C52B.0004: hiddev0,hidraw1: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:1a.0-1.5/input2
[ 2.048184] input: Logitech Unifying Device. Wireless PID:400e as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.5/1-1.5:1.2/0003:046D:C52B.0004/input/input1
[ 2.048237] logitech-djdevice 0003:046D:C52B.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:400e] on usb-0000:00:1a.0-1.5:1
[ 2.112036] usb 2-1.5: new full-speed USB device number 3 using ehci_hcd
[ 2.209435] usb 2-1.5: New USB device found, idVendor=2687, idProduct=fb01
[ 2.209440] usb 2-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.209444] usb 2-1.5: Product: Fitbit Base Station
[ 2.209447] usb 2-1.5: Manufacturer: Fitbit Inc.
[ 2.209449] usb 2-1.5: SerialNumber: \xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf\xffffffef\xffffffbf\xffffffbf\xffffffbf\xffffffbf
[ 2.212272] generic-usb 0003:2687:FB01.0006: hiddev0,hidraw3: USB HID v1.11 Device [Fitbit Inc. Fitbit Base Station] on usb-0000:00:1d.0-1.5/input0
[ 2.214768] generic-usb 0003:2687:FB01.0007: hiddev0,hidraw4: USB HID v1.11 Device [Fitbit Inc. Fitbit Base Station] on usb-0000:00:1d.0-1.5/input1
[ 2.283862] usb 2-1.6: new full-speed USB device number 4 using ehci_hcd
[ 2.438091] usb 2-1.6: New USB device found, idVendor=0a12, idProduct=0001
[ 2.438095] usb 2-1.6: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 7.205384] PM: Starting manual resume from disk
[ 7.205386] PM: Hibernation image partition 8:6 present
[ 7.205388] PM: Looking for hibernation image.
[ 7.205561] PM: Image not found (code -22)
[ 7.205564] PM: Hibernation image not present or could not be loaded.
[ 7.236837] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
[ 8.765306] udevd[440]: starting version 175
[ 9.033353] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 9.033358] ACPI: Power Button [PWRB]
[ 9.033405] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 9.033409] ACPI: Power Button [PWRF]
[ 9.289261] acpi device:42: registered as cooling_device0
[ 9.289406] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input4
[ 9.289410] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 9.600576] [drm] Initialized drm 1.1.0 20060810
[ 9.642661] iTCO_vendor_support: vendor-support=0
[ 9.643338] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 9.643401] iTCO_wdt: Found a Panther Point TCO device (Version=2, TCOBASE=0x0460)
[ 9.643629] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 9.683219] PCI parallel port detected: 1415:c000, I/O at 0xc010(0xc000), IRQ 18
[ 9.683367] parport0: PC-style at 0xc010 (0xc000), irq 18 [PCSPP,TRISTATE,EPP]
[ 9.716554] Bluetooth: Core ver 2.16
[ 9.716565] NET: Registered protocol family 31
[ 9.716566] Bluetooth: HCI device and connection manager initialized
[ 9.716568] Bluetooth: HCI socket layer initialized
[ 9.716569] Bluetooth: L2CAP socket layer initialized
[ 9.716573] Bluetooth: SCO socket layer initialized
[ 9.759193] cfg80211: Calling CRDA to update world regulatory domain
[ 9.806670] usbcore: registered new interface driver btusb
[ 9.937116] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5
[ 9.937181] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[ 9.937223] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 9.937294] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 9.937335] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 9.937374] input: HDA Intel PCH Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 9.937414] input: HDA Intel PCH Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 9.937456] input: HDA Intel PCH Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 9.937495] input: HDA Intel PCH Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[ 9.937782] ACPI Warning: 0x0000f040-0x0000f05f SystemIO conflicts with Region \_SB_.PCI0.SBUS.SMBI 1 (20120320/utaddress-251)
[ 9.937790] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 9.938175] i915 0000:00:02.0: setting latency timer to 64
[ 9.953258] mtrr: type mismatch for e0000000,10000000 old: write-back new: write-combining
[ 9.953260] [drm] MTRR allocation failed. Graphics performance may suffer.
[ 9.953377] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 9.953379] [drm] Driver supports precise vblank timestamp query.
[ 9.967883] [drm] Enabling RC6 states: RC6 on, RC6p on, RC6pp off
[ 10.146208] ath: EEPROM regdomain: 0x3a
[ 10.146210] ath: EEPROM indicates we should expect a direct regpair map
[ 10.146212] ath: Country alpha2 being used: CA
[ 10.146214] ath: Regpair used: 0x3a
[ 10.192000] No connectors reported connected with modes
[ 10.192007] [drm] Cannot find any crtc or sizes - going 1024x768
[ 10.196055] Console: switching to colour frame buffer device 128x48
[ 10.197337] fb0: inteldrmfb frame buffer device
[ 10.197338] drm: registered panic notifier
[ 10.197342] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 10.208367] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 10.208541] Registered led device: ath9k-phy0
[ 10.208547] ieee80211 phy0: Atheros AR9485 Rev:1 mem=0xf8c80000, irq=16
[ 10.216117] udevd[491]: renamed network interface wlan0 to wlan1
[ 10.963252] cfg80211: World regulatory domain updated:
[ 10.963256] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 10.963258] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 10.963259] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 10.963261] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 10.963262] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 10.963263] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 10.963265] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[ 10.963266] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 10.963268] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[ 10.963275] cfg80211: Calling CRDA for country: CA
[ 10.975709] cfg80211: Regulatory domain changed to country: CA
[ 10.975711] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 10.975713] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[ 10.975715] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 1700 mBm)
[ 10.975716] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2400 mBm)
[ 10.975718] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2400 mBm)
[ 10.975719] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[ 12.155724] Adding 1922044k swap on /dev/sda6. Priority:-1 extents:1 across:1922044k
[ 12.163468] EXT4-fs (sda5): re-mounted. Opts: (null)
[ 12.326016] EXT4-fs (sda5): re-mounted. Opts: errors=remount-ro
[ 12.375548] loop: module loaded
[ 13.146852] RPC: Registered named UNIX socket transport module.
[ 13.146855] RPC: Registered udp transport module.
[ 13.146856] RPC: Registered tcp transport module.
[ 13.146857] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 13.174528] FS-Cache: Loaded
[ 13.194946] NFS: Registering the id_resolver key type
[ 13.194957] FS-Cache: Netfs 'nfs' registered for caching
[ 13.198920] Installing knfsd (copyright (C) 1996 This email address is being protected from spambots. You need JavaScript enabled to view it.).
[ 15.003832] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input14
[ 15.525073] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 15.525076] Bluetooth: BNEP filters: protocol multicast
[ 15.551690] Bluetooth: RFCOMM TTY layer initialized
[ 15.551694] Bluetooth: RFCOMM socket layer initialized
[ 15.551696] Bluetooth: RFCOMM ver 1.11
[ 16.096508] lp0: using parport0 (interrupt-driven).
[ 16.182385] ppdev: user-space parallel port driver
[ 17.793520] ADDRCONF(NETDEV_UP): wlan1: link is not ready
[ 18.137235] r8169 0000:05:00.0: eth0: link down
[ 18.137319] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 19.673612] usb 2-1.6: USB disconnect, device number 4
[ 19.879831] mtrr: base(0xf5000000) is not aligned on a size(0xe00000) boundary
[ 19.934614] usb 2-1.6: new full-speed USB device number 5 using ehci_hcd
[ 20.333105] usb 2-1.6: New USB device found, idVendor=0a12, idProduct=0001
[ 20.333111] usb 2-1.6: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 20.566460] wlan1: authenticate with 00:ac:e0:94:54:d0
[ 20.574516] wlan1: send auth to 00:ac:e0:94:54:d0 (try 1/3)
[ 20.581141] wlan1: authenticated
[ 20.585526] wlan1: associating with AP with corrupt probe response
[ 20.585925] wlan1: associate with 00:ac:e0:94:54:d0 (try 1/3)
[ 20.591519] wlan1: RX AssocResp from 00:ac:e0:94:54:d0 (capab=0xc31 status=0 aid=6)
[ 20.595955] ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[ 20.595988] wlan1: associated
[ 20.596006] cfg80211: Calling CRDA for country: US
[ 20.598574] cfg80211: Regulatory domain changed to country: US
[ 20.598576] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 20.598578] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[ 20.598580] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 1700 mBm)
[ 20.598581] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[ 20.598582] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[ 20.598584] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[ 26.824625] wlan1: deauthenticated from 00:ac:e0:94:54:d0 (Reason: 15)
[ 26.832328] cfg80211: Calling CRDA to update world regulatory domain
[ 26.834742] cfg80211: World regulatory domain updated:
[ 26.834745] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 26.834747] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 26.834748] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 26.834750] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 26.834751] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 26.834752] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 26.834754] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[ 26.834755] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 26.834757] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[ 27.551565] wlan1: authenticate with 00:ac:e0:94:54:d0
[ 27.555879] wlan1: send auth to 00:ac:e0:94:54:d0 (try 1/3)
[ 27.560096] wlan1: authenticated
[ 27.564516] wlan1: associating with AP with corrupt probe response
[ 27.567145] wlan1: associate with 00:ac:e0:94:54:d0 (try 1/3)
[ 27.582025] wlan1: RX AssocResp from 00:ac:e0:94:54:d0 (capab=0xc31 status=0 aid=6)
[ 27.586497] wlan1: associated
[ 27.586515] cfg80211: Calling CRDA for country: US
[ 27.588966] cfg80211: Regulatory domain changed to country: US
[ 27.588969] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 27.588971] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[ 27.588972] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 1700 mBm)
[ 27.588974] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[ 27.588975] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[ 27.588977] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[ 120.492240] I-pipe: head domain RTAI registered.
[ 120.492244] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 120.492288] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 120.492290] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6249599, CLK_FREQ 3300142000, CPU_FREQ 3300142000
[ 120.492292] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 120.492294] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6249599, 6249599, 2087000
[ 121.401266] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 121.401294] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 121.401297] RTAI[sched]: hard timer type/freq = APIC/6249599(Hz); default timing: oneshot; linear timed lists.
[ 121.401299] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3300142000 hz.
[ 121.401300] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 121.454302] RTAI[math]: loaded.
[ 121.917033] config string 'c010 out'
[ 127.350174] RTAI[math]: unloaded.
[ 127.351168] SCHED releases registered named ALIEN PEDV$D
[ 127.354176] RTAI[malloc]: unloaded.
[ 127.450174] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 127.451322] I-pipe: head domain RTAI unregistered.
[ 127.451374] RTAI[hal]: unmounted.
[ 233.524590] I-pipe: head domain RTAI registered.
[ 233.524594] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 233.524637] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 233.524639] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6249599, CLK_FREQ 3300142000, CPU_FREQ 3300142000
[ 233.524641] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 233.524643] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6249599, 6249599, 6180000
[ 233.528082] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 233.528103] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 233.528105] RTAI[sched]: hard timer type/freq = APIC/6249599(Hz); default timing: oneshot; linear timed lists.
[ 233.528108] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3300142000 hz.
[ 233.528109] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 233.532104] RTAI[math]: loaded.
[ 233.659978] config string 'c010 out'
[ 236.255256] RTAI[math]: unloaded.
[ 236.256203] SCHED releases registered named ALIEN PEDV$D
[ 236.258652] RTAI[malloc]: unloaded.
[ 236.356427] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 236.357724] I-pipe: head domain RTAI unregistered.
[ 236.357773] RTAI[hal]: unmounted.
[ 605.704915] I-pipe: head domain RTAI registered.
[ 605.704919] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 605.704962] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 605.704965] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6249599, CLK_FREQ 3300142000, CPU_FREQ 3300142000
[ 605.704967] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 605.704970] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6249599, 6249599, 5649500
[ 605.708411] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 605.708433] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 605.708436] RTAI[sched]: hard timer type/freq = APIC/6249599(Hz); default timing: oneshot; linear timed lists.
[ 605.708439] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3300142000 hz.
[ 605.708441] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 605.714741] RTAI[math]: loaded.
[ 605.742287] config string 'c010 out'
[ 608.321477] RTAI[math]: unloaded.
[ 608.322422] SCHED releases registered named ALIEN PEDV$D
[ 608.325160] RTAI[malloc]: unloaded.
[ 608.423216] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 608.424431] I-pipe: head domain RTAI unregistered.
[ 608.424482] RTAI[hal]: unmounted.
- parishwolfe
22 Mar 2017 01:41 #90043
by parishwolfe
Replied by parishwolfe on topic Linux CNC just stopped working!
When I test the axes on stepconfig it works fine. So I dont know whats wrong and Im hoping someone with more knowledge than myself can help me fix this.
22 Mar 2017 03:16 #90046
Replied by PCW on topic Linux CNC just stopped working!
- Thank you received: 5928
22 Mar 2017 09:47 #90054
Replied by tommylight on topic Linux CNC just stopped working!
Double post !!!!
23 May 2017 18:35 #93559
by kd5de
Replied by kd5de on topic Linux CNC just stopped working!
Well I upgraded from 2.7.6 to 2.7.8 , also with the kernel upgrade from 3.2.0-4 to 3.4.9. Upgrade was made following web site instructions. If I boot to the previous kernel all is fine. Maybe need to start from scratch on the config???
25 May 2017 10:49 #93608
by rotwang
Replied by rotwang on topic Linux CNC just stopped working!
I think the clue is here -
Debug file information:
note: MAXV max: 1.000 units/sec 60.000 units/min
note: LJOG max: 1.000 units/sec 60.000 units/min
note: LJOG default: 0.100 units/sec 6.000 units/min
note: jog_order='XYZ'
note: jog_invert=set([])
Xlib: extension "GLX" missing on display ":0.0".
and you need to investigate your xorg setup to find out why your previous installation supported GLX and your current one doesn't. Maybe the driver for your video card is not installed by default? This is I think a linux problem, nothing to do with linuxcnc.
Roger
Roger
Time to create page: 0.277 seconds
