Error loading linuxcnc [solved]
11 Jul 2014 18:02 - 13 Jul 2014 05:46 #48647 by Lc1975
Error loading linuxcnc [solved] was created by Lc1975
Hello.
I need some help if possible please..
I'm still building my milling cnc but i want to use the program to start learning...
I'm a newbie on this but i really want to learn and use for future...
I have a Sony VPCEH3K1E and i used LiveCD Ubuntu version 10.04 and i have some issues of some hardware (mouse and graphics)
Tried with 12.04 version and works fine..
Follow the post to install linxcnc on fresh install of version 12.04 everytinhg fine, no errors..
But when i launch the "LinuxCNC" appears a file with erros and the program dosen't launch..
Can you help me?
And once again i'm a NEWBIE on this :)
Thanks.
File Name: ErroLinuxCNC.txt
File Size:43 KB
Last edit: 13 Jul 2014 05:46 by Lc1975. Reason: solved
11 Jul 2014 20:29 - 11 Jul 2014 22:32 #48653 by ArcEye
Replied by ArcEye on topic Error loading linuxcnc
Hi
Looks like this is a notebook, not a top Linuxcnc candidate unless just for simulations.
Xlib: extension "GLX" missing on display ":0.0".
File "/usr/bin/axis", line 3044, in <module>
o = MyOpengl(widgets.preview_frame, width=400, height=300, double=1, depth=1)
File "/usr/bin/axis", line 342, in __init__
Opengl.__init__(self, *args, **kw)
File "/usr/lib/pymodules/python2.7/rs274/OpenGLTk.py", line 164, in __init__
apply(RawOpengl.__init__, (self, master, cnf), kw)
File "/usr/lib/pymodules/python2.7/rs274/OpenGLTk.py", line 112, in __init__
Togl.__init__(self, master, cnf, **kw)
File "/usr/lib/pymodules/python2.7/rs274/OpenGLTk.py", line 38, in __init__
Widget.__init__(self, master, 'togl', cnf, kw)
File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 1977, in __init__
(widgetName, self._w) + extra + self._options(cnf))
_tkinter.TclError: Togl: X server has no OpenGL GLX extension
The error is because your video card or the driver does not support openGL.
Try this
wiki.linuxcnc.org/cgi-bin/wiki.pl?Troubl...oftware_based_OpenGL
Last edit: 11 Jul 2014 22:32 by ArcEye.
The following user(s) said Thank You: electrophile
11 Jul 2014 20:43 #48654 by Lc1975
Replied by Lc1975 on topic Error loading linuxcnc
B)
Only with 12.04 that happens.
I have tried with version 10.04 and works fine the program..
On this moment only the mouse does not work..
I have install the drivers from NVidia and for what i read is not advisable to install...
Have a message in linuxcnc
unexpected delay in the real-time system:
check dmesg for details
I will try to uninstall NVidia and use from system...
Thanks for the tip
11 Jul 2014 20:53 - 11 Jul 2014 20:54 #48655 by ArcEye
Correct, nvidia does GLX its own way which is not always compatable
The nouveau driver which is installed by default is very capable and works with linuxcnc well.
You should be able to revert by just uninstalling nvidia-glx in synaptic, just make sure that /etc/X11/xorg.conf.d/nvidiaxxx entry and the blacklist of nouveau in etc/modprobe.d/nvidiaxxxxxx is removed before rebooting
Last edit: 11 Jul 2014 20:54 by ArcEye.
The following user(s) said Thank You: Lc1975
Time to create page: 0.062 seconds
