Forum Header
Configuring A rotary axis to substitute for the Y axis
29 Jan 2019 19:26 #125198
by dgarrett
You also need to make sure the number of joints is specified
correctly, example:
(Using kinstype=both is helpful in seeing what goes on
prior to homing for the axis gui)
Recommendations for consistency:
Ref: linuxcnc.org/docs/master/html/getting-st..._axes_specifications
trivkins man page:
linuxcnc.org/docs/devel/html/man/man9/trivkins.9.html
Replied by dgarrett on topic Configuring A rotary axis to substitute for the Y axis
If using trivkins in the development version then the only
change you need to make is from...
correctly, example:
[KINS]
KINEMATICS=trivkins coordinates=xazy kinstype=both
JOINTS = 4
trivkins man page:
29 Jan 2019 19:27 #125199
by Chris401
Replied by Chris401 on topic Configuring A rotary axis to substitute for the Y axis
May try that if I am not happy with the code Vcarve pro generates for the cylindrical projects. On my config problem I punted and used the XYZA in stepconfig and just defined A to be on my normal Y driver and Y using pins not really connected to anything. Runs manually now. Naturally with a phantom Y I need to run without my limit/home switches and its has been a long time since I have run without so need to figure out how to past that now. First attempt was manually adding home_search_vel=0 to axis section and still got the “cant run MDI commen...” message.
01 Feb 2019 20:32 #125491
by Chris401
Leon,
I figured out how to get Vcarvepro to output angular movements and and am running an XYZA with a nonexistent Y axis. It now works but the A axis seems to be turning at the same magnitude in degrees/min that the linear axis moves in inches/min. Obviously the rotation is pretty darned slow. Moving the right amount just getting there slowly. Is that just something that needs overcome in the G code or is there a linuxcnc end fix?
01 Feb 2019 20:35 #125493
by Chris401
Andy,
I have Vcarve ouputing A moves now and the machine is moving the right amounts. But the feed for the A axis is the same in deg/min as the linear is in inches/min. Obviously kind of slow. Is there a linuxcnc fix for rotational moves or does that just have to be a G code fix?
01 Feb 2019 20:53 #125494
by Grotius
Replied by Grotius on topic Configuring A rotary axis to substitute for the Y axis
In rotary files, the feed rates are up to 30000 mm/min when rotating without G1 commands.
So you need to add fast command's in your gcode file, like
Y5 Z68 A-220 F35000
Y5 Z68 A-220 F35000
- OttoDidact
- Thank you received: 3
01 Feb 2019 20:54 #125495
by OttoDidact
Replied by OttoDidact on topic Configuring A rotary axis to substitute for the Y axis
I think what you are looking for is inverse time mode.
01 Feb 2019 21:32 - 01 Feb 2019 21:33 #125499
by Leon82
Yes. Inverse time or TCP would feed correctly
In mastercam you can set the machine definition to post this. So there should be a setting in the cam software
Replied by Leon82 on topic Configuring A rotary axis to substitute for the Y axis
Last edit: 01 Feb 2019 21:33 by Leon82.
02 Feb 2019 15:02 #125541
Replied by andypugh on topic Configuring A rotary axis to substitute for the Y axis
Try inverse time mode.
There is a filter file somewhere on this forum to automatically convert to inverse time.
Time to create page: 0.098 seconds
