Forum Header
moving problem
02 Aug 2019 13:33 #141184
Replied by PCW on topic moving problem
Those basically look OK, so I'm not really sure whats going on
I do think I would remove the parallel port driver and read/write commands
Did you run a latency test on the PC?
Have you had any other errors from LinuxCNC?
What version of LinuxCNC are you running?
02 Aug 2019 14:55 #141190
by RoberCNC
Replied by RoberCNC on topic moving problem
remove the parallel port driver?
Yes i didDid you run a latency test on the PC?
No, nothing else at the momentHave you had any other errors from LinuxCNC?
2.7 wheezyWhat version of LinuxCNC are you running?
02 Aug 2019 15:38 #141192
I dont see anything obvious wrong in the hal/ini files
Could you plot the following error with halscope? something very strange
is going on here to get such huge following errors at such slow speeds
(maybe something wrong with the PC clock)
Are you using a 5I25 or 6I25? (wrong jumpering on a 6I25 might cause
this type of an error by selecting an unexpected clock frequency)
02 Aug 2019 15:48 #141193
by RoberCNC
I am very new to this Linuxcnc, how do I follow the error? My card is a 5i25 + 7i76. if I leave the speed at 10 there is no following error, only that while machining I lose the Y for no apparent reason, the engine ceases to exist, restart and I have it again, but it happens again
02 Aug 2019 16:16 #141197
Ok so are you saying that the hal/ini files you posted
(with 8.33 mm/s maximum per axis velocities)
Does not cause following errors?
02 Aug 2019 16:23 #141199
by RoberCNC
The files are those, the following errors comes when I increase max_vel over 10, for example with max_velocity=12 and stepgen_maxvel=15
02 Aug 2019 16:25 - 02 Aug 2019 16:25 #141200
That's probably expected unless you also raise the PID output limit
(probably best to just set it to 0 so its not used)
Last edit: 02 Aug 2019 16:25 by PCW.
02 Aug 2019 16:27 - 02 Aug 2019 16:43 #141201
by RoberCNC
P=0, I=0 and D=0?
Tried and nothing, the same, if I increase velocity over 10 the following errors appears.
Last edit: 02 Aug 2019 16:43 by RoberCNC.
02 Aug 2019 16:43 #141202
No, the PID parameters are OK but
set all MAX_OUTPUT = 0 in the ini file
02 Aug 2019 17:04 #141205
by RoberCNC
It works!!! You are a crack PCW, thank you very much, now I'm moving at 30 without problema, tried 50 too but the motor stalls after a while, doesn't matters, 30 is enough for me
On the other hand, losing the Y axis after a while of machining can be x driver heating? coincidentally in both tests is the axis that works the most, maybe is silly what I am saying
Time to create page: 0.187 seconds
