× Forum Header
moving problem
25 Aug 2019 11:39 #143134 by rodw
Replied by rodw on topic moving problem
That is strange. Ages ago I had no trouble with adding an A axis and had a rotary table turning on my gantry machine under V2.8. There must be something missing.
25 Aug 2019 11:51 - 25 Aug 2019 15:17 #143135 by RoberCNC
Replied by RoberCNC on topic moving problem
Yes, I think equal, in fact one of the threads I have followed was yours, with a plasma Torch, I compared the Ini and Hal and I think I have it equal, saving the obvious differences.
I found this diving in the documentation:
"for trivial kinematics, X is always joint 0, A is always joint 3, and U is always joint 6"
What do you think about Rod, this could be the mistake?
Last edit: 25 Aug 2019 15:17 by RoberCNC.
26 Aug 2019 01:33 #143182 by phillc54
Replied by phillc54 on topic moving problem
Some interesting pics of a display with with the A in geometry in different places.
www.wallacecompany.com/machine_shop/LinuxCNC/fourth_axis/
26 Aug 2019 01:56 - 26 Aug 2019 01:57 #143183 by rodw
That does not sound right in a joint axis world. I think its a typo.
I was running on joint 4 of a 7i76e (Version 2.8)
I found my A xis Config dated back to 2017. hal and Ini files are attached. There needs to be a change to the newer multispindle format for this to load.
File Name: Spaceship_...8-25.ini
File Size:8 KB
File Name: Spaceship_...8-25.hal
File Size:22 KB
Last edit: 26 Aug 2019 01:57 by rodw.
26 Aug 2019 02:14 - 26 Aug 2019 03:17 #143184 by dgarrett
Replied by dgarrett on topic moving problem
If you quote a document, please cite
a link or exactly how you found the document.
That quote is found at 2.10 [TRAJ]Section in the
"INI Configuration" Chapter of the 2.7 branch:
linuxcnc.org/docs/2.7/html/config/ini-config.html
But does not appear in the *unreleased* 2.8 branch:
linuxcnc.org/docs/2.8/html/config/ini-config.html
nor in the *unreleased* master branch:
linuxcnc.org/docs/master/html/config/ini-config.html
or its equivalent:
linuxcnc.org/docs/devel/html/config/ini-config.html
Numerous things change between branches.
Last edit: 26 Aug 2019 03:17 by dgarrett.
26 Aug 2019 07:36 - 26 Aug 2019 07:39 #143195 by RoberCNC
or its equivalent:
My apologies dgarrett, you're absolutely right, I'm sorry.
Rod, thank you very much for attaching the files, I will compare them to see what I have different, thanks.
Hello Phill, thanks a lot for this info, I dont ser nothing similar ok my display :( .
Last edit: 26 Aug 2019 07:39 by RoberCNC.
26 Aug 2019 10:11 #143200 by RoberCNC
Summary of situation:
The jamming of the linear axes in continuous jogging seems to be solved by reducing the speed, I will have to assume limitations of working with motors without pulleys.
Regarding the A axis (at the moment it is only a stepper for tests) I have observed several things:
1-If I work with linear speeds in the Preview window it is the tool that rotates.
2-If I work with angular speeds the tool remains static but in the coordinates if it acts as it should (rotations from 0 to 360 degrees and so on) from what I understand it would be correct.
Is an advance!! although in neither case do I get movement in the engine. On the other hand, I do not know if it will have something to do, but for giving the maximum possible data, when making a new configuration, arriving at the A axis, when I give test / tune axis an error window appears, attached copied text of the error.
17 Sep 2019 15:50 #145399 by RoberCNC
Hello friends, I would need help to understand the problem I have and know what I am doing wrong, I comment:
Finally I was able to install the DQ860MA drivers but the blocking problems persist. Both continuously jogging and using MDI commands or running a program suddenly the motors are randomly blocked, with its catastrophic consequences :(.
From my ignorance and by elimination I think there can be two things:
1-some type of PC failure
2-section of insufficient cable (I am using 4-wire USB cable)
Since the rest of the components I understand that they are of a respectable quality, MESA cards and the mentioned drivers.
I would appreciate any help, I'm starting to despair.
17 Sep 2019 16:00 #145401 by andypugh
Replied by andypugh on topic moving problem
What are you using USB cable for? If you are using it to connect the stepper motors then I would suspect that it is far too small.
Even high-power USB cable tends to have smaller wires for data (24AWG for power, 28AWG for data) and 28AWG is only really usable to 0.5A.
17 Sep 2019 16:35 - 17 Sep 2019 17:46 #145408 by RoberCNC
Precisely for that, from 7i76 onwards (from 7i76 to the drivers and from the drivers to the steppers) it is all USB cable, except power. What cable section would be recommended? They are 3A steppers, I guess it better be too much to fall short.
I have wired from the drivers to the stepper with section 1.5 and the problem persists.
Last edit: 17 Sep 2019 17:46 by RoberCNC.
Time to create page: 0.156 seconds
