Forum Header
moving problem
- Thank you received: 5988
17 Sep 2019 17:53 #145416
Replied by tommylight on topic moving problem
Change the power supply, it seems to be to weak for what you need it.
17 Sep 2019 17:58 - 17 Sep 2019 18:53 #145419
by RoberCNC
Replied by RoberCNC on topic moving problem
Hi Tommy, I currently have them powered with 36V and I have one of 12V too for the 7i76 and both wired together to power the spindle with 48V. Should I have several power supplies, such as one for every two drivers, more voltage or what do you recommend?
Last edit: 17 Sep 2019 18:53 by RoberCNC.
17 Sep 2019 20:31 #145432
Replied by PCW on topic moving problem
I would check the power supply voltages and step drive status LEDs
when you get a fault.
If all Axis stall at once, (and there are no errors from LinuxCNC) it does
suggest a power supply issue.
17 Sep 2019 20:46 #145437
by RoberCNC
No they don't stall at once and I never get errors from linuxCNC. What do you mean with check the voltages?
17 Sep 2019 20:51 #145438
I mean for example put a voltmeter on the stepper supply voltage to see if it is sagging/dropping out when you get a stall
17 Sep 2019 20:59 - 17 Sep 2019 21:01 #145441
by RoberCNC
I have the fault especially in the Y axis, the dual, I hear a strange noise and stops one of the steppers or both, occasionally in X, but very rarely. Before I tried to disconnect everything except the Y axis to dedicate the entire 36V source to both drivers but it does the same. I will try to measure voltage as you tell me. Thank you.
Last edit: 17 Sep 2019 21:01 by RoberCNC.
18 Sep 2019 06:52 #145484
When the motors stall do they continue to make noise ?
18 Sep 2019 07:03 #145485
by RoberCNC
The strange noise they do when stopping. The process would be as follows: I run the program (or perform continuous jogging), everything goes well and suddenly the steppers emits the noise, stops briefly and usually continues with the execution of the program, but of course with the corresponding loss of correct position and their respective disaster in the piece. It is a kind of slowdown. In the Linuxcnc screen everything is normal, there is no error message and the trajectories are continuous but it is not real.
18 Sep 2019 07:07 #145486
That sounds like normal stall so there are two things you can try:
Set the step time and step space in the ini file to a higher value
Lower the velocity in the ini file to where you get no stalls, and then lower it a bit more to be on the safe side and to have some room for the cutting forces.
18 Sep 2019 07:40 #145488
by RoberCNC
The Step Time parameter does not figure me, should I write it ?. Attached INI file.
Time to create page: 0.460 seconds
