Forum Header
MESSAGE: "Simulator: Hardware will not run"
- Schneiderman
20 Aug 2021 17:26 #218248
by Schneiderman
MESSAGE: "Simulator: Hardware will not run" was created by Schneiderman
HI guys!
I am new to LinuxCnc,
I am having some problems with StepConf Wizard. When i try to test the axis, the motors does not move at all.
I already checked all the wires and apparently every thing is fine. Also on the final page of the stepconf appears a big message in red "Simulator: Hardware will not run". I am thinking both are connected.
Some body could give me a light on this issue?
Thank you all in advance!
20 Aug 2021 17:45 #218249
by Clive S
Replied by Clive S on topic MESSAGE: "Simulator: Hardware will not run"
I don't think that a simulator will actually run real hardware.HI guys!
- Schneiderman
20 Aug 2021 18:01 #218251
by Schneiderman
Replied by Schneiderman on topic MESSAGE: "Simulator: Hardware will not run"
Thank you Clive, I already check ou the box of simulator mode,
But my motor still wont run, do you have any ideas?
- Thank you received: 5945
20 Aug 2021 18:11 #218255
Replied by tommylight on topic MESSAGE: "Simulator: Hardware will not run"
On the first or second page of StepConf, untick the "simulated something or another".
23 Aug 2021 11:00 - 23 Aug 2021 11:03 #218489
by bevins
Replied by bevins on topic MESSAGE: "Simulator: Hardware will not run"
In a terminal type: uname -a and report what it returns here...... I don't know if stepconf will work without realtime kernel but your going to need it anyway.
Last edit: 23 Aug 2021 11:03 by bevins.
23 Aug 2021 11:51 #218496
by Clive S
Just for clarity is the box ticked or un-ticked
- Schneiderman
23 Aug 2021 14:02 #218509
by Schneiderman
Hi clive, the box was un-ticked.
I already resolved the problem.
Linux wasnt recognizing the paralel port that i had installed, now everything is working fine!
Thank you for your help!
23 Aug 2021 17:05 #218530
by Clive S
Ok that's great. It always helps if you post the config files hal and ini from the config folder when asking for help.
Time to create page: 0.642 seconds
