Forum Header
Running a SIM configuration
06 Jul 2022 13:33 - 06 Jul 2022 13:37 #246713
by Elco
Running a SIM configuration was created by Elco
I have setup a small system (Biostar A68N 2100) to test some new hardware. Upgraded to Debian (4.19.249-2) and got the LinuxCNC test version from the Synaptic Package Mgr. I copied the config of my current working system (runs on an 2 Core intel), and got "unexpected realtime delay on task0 with period 65000". No problem as he Biostar is a slower system, but running the StepConf Wizard does not allow me to increase the period in the setup procedure. I can change the value in the ini file, but the next StepConf run shows the old value...
Do I need to invent a complete new configuration to get a larger period accepted?
Thanks, Elco
Edit: I also noticed that none of the SIM configurations are runnable, but will reinstall everything to check this.
Thanks, Elco
Last edit: 06 Jul 2022 13:37 by Elco. Reason: Forgot the footnote
- Thank you received: 5950
06 Jul 2022 13:40 #246715
Replied by tommylight on topic Running a SIM configuration
You can edit the .ini file in the configuration folder and set the base period to say 100000, save, start LinuxCNC.
06 Jul 2022 13:56 #246718
by Elco
Replied by Elco on topic Running a SIM configuration
That works, until you run stepconfig again.
Elco
Elco
12 Jul 2022 11:57 #247131
The HAL and INI are designed to be hand-editable, in fact early in in the history of LinuxCNC there was no other way.
Replied by andypugh on topic Running a SIM configuration
View Stepconf as a way to get a basic configuration set up. At some point it become more of a hindrance than a help, and you can tune directly in the config files.That works, until you run stepconfig again.
12 Jul 2022 12:49 #247133
Replied by cmorley on topic Running a SIM configuration
Stepconf calculates the base period, i beleive from the jitter and max velocity settings.
