EMC2 running on Raspberry Pi?
13 May 2013 11:32 #33972
by otto_pjm
Replied by otto_pjm on topic EMC2 running on Raspberry Pi?
mungkie
I've been playing with the image, it seems pretty usable in sim anyway. Was the default LXDE windows manager to big / slow. I played with the stock rpi distro a bit and it's a nice windows manager?
I created an inch based .ini, and that's been about it so far. I looked about for the code you mentioned in earlier posts, but don't see the src. Is it not in the current distribution? Not that I'm likely to be able to interpret much of it, but I like to poke around and see what I can understand.
I also found that overclocking helps make everything a bit more responsive, what rate are others testing with?
Thanks again for all the work on this, I hope to be able to connect the rpi to some drivers and motors soon.
Pete
Pete
20 May 2013 07:49 - 20 May 2013 07:53 #34407
Just got round to trying this. startx gives me a blank screen with an underscore cursor, followed by a totally blank screen.
I can still ssh into the Pi, and it appears to be alive, though.
But ssh -X then launching the script causes an instant ssh disconnect.
Curious. I do have quite an early Pi.
Replied by andypugh on topic EMC2 running on Raspberry Pi?
Okay web page is updated with new download link, should be a 319Mb download, please let me know if there are any problems with it.
Last edit: 20 May 2013 07:53 by andypugh. Reason: more info
20 May 2013 09:09 #34411
by otto_pjm
Andy,
So after the screen goes blank, this doesn't work.
>>> Once you have left click and hold the menu should appear select debian->applications->shells->bash and then release the left mouse button.
? It's a very minimal X window system.
If not what kind of monitor are you using, for me with HDMI output it gives me a letter boxed screen, (1300 something my 700 something) but works quite well. I found some info on building an image, and plan to try and make one using the default lxde windows system. No idea if that will be successful.
Pete
Pete
21 May 2013 05:48 #34473
by wyzarddoc
Replied by wyzarddoc on topic EMC2 running on Raspberry Pi?
Hi All;
Been away for awile so trying to get caught up. Someone mentioned offloading the pulse generation. This should help if we can seperate the code to allow the M3 core on this board to generate step and direction along with checking for limit switchs etc. www.coocox.org/epi.html
I have done some work with the 72Mhz M3's and it should be fast enough for a 3 or 4 axis system. Boards are available from element 14 for $34.00. I have one on order. If someone can help seperate the code so I can run bench tests I'd appreciate it
thanks
Doc
thanks
Doc
21 May 2013 05:48 #34474
I read this, and then forgot it befor booting the Pi.
It all looks good apart from one minor problem, the default RPi config uses an IO pin that doesn't exist in the Series one RPi. (GPIO27). I changed to 17,18,22,23,9,25.
Next: see where I put my stepper drivers.
I think maybe the web page instructions are not so clear as I changed the window manager that X uses, the twm window manager which requires you to left click and hold down your mouse button for the menu to
21 May 2013 05:56 #34475
Are the other IO pins available as slower (servo-thread) GPIO?
I am thinking of designing and ordering a batch of breakout boards.
21 May 2013 06:25 #34477
Yes, and Mungkie has very cunningly offloaded step generation to the PWM hardware.
The following user(s) said Thank You: wyzarddoc
21 May 2013 07:04 #34479
by wyzarddoc
Thanks for the info about Mungkie. Where can I find out about his work? Most of the I/O pins on the M3 core are brought out to the Arduino style pin headers but double outputs per header row. I am still in learning phase so not and expert on
best use but looks like has 3 register out mode?
thanks
Doc
thanks
Doc
21 May 2013 07:09 #34480
by wyzarddoc
It would easily be possible to stack a Arduino prototyping board to the pins on this board and create a BoB that's programable and has diodes for the ultimate protection
Doc
Doc
21 May 2013 16:01 #34489
I am a bit confused by this question. He started this thread and has posted a link to what appears to be a fully functional RPi image with his stepper driver included in a sample config.
linuxcnc.org/index.php/english/forum/18-...y-pi?start=170#33848
Time to create page: 0.181 seconds
