contour shuttle pro as EMC pendant
16 Apr 2013 01:17 #32765
by m8298
Replied by m8298 on topic contour shuttle pro as EMC pendant
I found this in the wiki:
hidcomp.sourceforge.net/
It looks like this would work for me(once I understand it.)
18 Apr 2013 05:52 #32854
by m8298
I downloaded and installed hidcomp. I have it recognizing my Contour Shuttle Pro. Can anyone explain to me how to set pins in hal so I can link them in hidcomp? I want the following functions assigned to hal pins to be used on the buttons:
One pin/button for each axis (xyza) to jog enable.
One pin/button to set a parallel port output.
One pin/button for program run.
One pin/button for program stop.
One pin/button for program rewind.
One pin/button for estop.
One pin/button to zero A axis.
One pin/button to switch in/mm.
One pin/button to set a position offset. (I still need to learn how to do this in EMC. It is to set X and Y position based on a laser pointer.)
18 Apr 2013 05:56 #32855
by m8298
I forgot to mention the wheel and dial. I would like to use the wheel to jog (similar to mpg), and if possible, the dial for feed rate override.
18 Apr 2013 06:06 #32856
There is absolutely no way that anyone without a Shuttle Pro can help you without more info.
At the very least we need a list of the pins that the hidcomp creates, and what they do when you twiddle the device.
Even then a major problem might remain, in that Seb only wrote the Shuttle Express driver because the jog shuttle behaviour in the Express is just plain weird.
If you can describe _exactly_ what the effect is of manipulating each control on the shuttle pro is on the associated HAL pin, and how you want LinuxCNC to interpret that, then we can tell you how to configure the HAL.
Replied by andypugh on topic contour shuttle pro as EMC pendant
18 Apr 2013 06:51 - 18 Apr 2013 06:52 #32857
by m8298
But if I understand correctly, hidcomp recognizes USB devices (including Shuttle Pro) and their controls with associated data types. It does recognize my Shuttle Pro by product ID and Vendor ID and places the 13 buttons, wheel, and dial in it's table. In the table each row corresponds to a control. The last column in each row is where I name the hal pin. If I understand, all I should have to do is edit hal to include these hal pin names and assign their functions. Am I wrong here?
Last edit: 18 Apr 2013 06:52 by m8298.
18 Apr 2013 07:02 #32858
No, but (If I recall correctly) the Express jog wheel does wierd stuff, hence the special driver. If the pro does not do wierd stuff, then just connect it up in HAL.
But as you are currenlty the only guy in the world who knows what pins hidcomp creates with a shuttle pro, we can't advise without more info.
Am I wrong here?
18 Apr 2013 07:12 #32859
by m8298
Can you tell me where I find the pins it creates?
18 Apr 2013 07:30 #32862
If, (and only if) LinuxCNC is currently starting without an error, you can see them all in the Machine->Show Hal Config screen of Axis (Other GUIs will vary).
That is not easy to share, though. So, iff Linuxcnc is starting without errors, then with it open, you can open a terminal window and type
halcmd show pin
and copy/paste the output.
Or, to be properly geeky
halcmd show pin > pin.txt
to put the pin names into a new file called pins.txt
halcmd show pin
18 Apr 2013 07:47 #32863
by m8298
EMC loads without error. But hid comp isn't generating the pins?
18 Apr 2013 08:01 #32865
This is really hard to help with.
What made you think that hidcomp was working?
Time to create page: 0.323 seconds
