Intel cpu on board motherboard suggestion
02 May 2015 16:18 #58313
by vre
Intel cpu on board motherboard suggestion was created by vre
I want a low cost bay trail (intel cpu on board ) mobo to run linuxcnc.
I want to have parallel port with low latency/jitter for software step generation and pci & pciE ports for a mesa card.
Any tested suggestion ?
thanks.
thanks.
02 May 2015 16:57 - 02 May 2015 16:59 #58314
by ArcEye
Replied by ArcEye on topic Intel cpu on board motherboard suggestion
These are your choices (chips at least, every board manufacturer will have a different flavour)
ark.intel.com/products/codename/55844/Bay-Trail#@Desktop
The one that keeps coming up from PCWs testing is the J1900 based board.
Search J1900 and his user name and you will come up with his precise recommendations
Just beware exactly what 'Intel HD Graphics' equates to.
There are lots of unhappy tales about boards with GMA video chips, because they are still not supported well in Linux
Last edit: 02 May 2015 16:59 by ArcEye.
02 May 2015 21:27 #58323
Replied by PCW on topic Intel cpu on board motherboard suggestion
The Baytrail CPUs (J1800, J1900, J2900 etc) luckily don't have the dreaded
PowerVR GPUs=GMA3600 that have such poor Linux support, but instead
have standard Intel HD graphics like their bigger brothers.
Intel HD graphics is well supported by Linux.
The PowerVR GPUs are in the previous generation Cedartrail CPUs
(D2500,D2550,D2700,N2600,N2800) These will work but have lots of video issues
with linux
with linux
03 May 2015 01:53 #58337
by vre
Replied by vre on topic Intel cpu on board motherboard suggestion
@PCW what mobo 1900 or 2900 you suggest from your experience?
03 May 2015 13:59 - 03 May 2015 14:12 #58349
by SrLange61
Replied by SrLange61 on topic Intel cpu on board motherboard suggestion
I can recommend the ASROCK Q1900B-ITX with a Gecko 540 on the latest Wheezy. No HDMI sound but every thing else is fine. Its even better now with a SSD.
I upgraded from a D525MW so I second PCW's post.
srl
srl
Last edit: 03 May 2015 14:12 by SrLange61.
04 May 2015 08:41 - 21 May 2015 08:45 #58364
by vre
I got this
this
and works very well on wheezy.
Last edit: 21 May 2015 08:45 by vre.
- eFalegname
- Thank you received: 30
04 Sep 2015 22:21 #62131
by eFalegname
could you tell me please, what is the latency test result you obtained from this mobo?
thanks
Replied by eFalegname on topic Intel cpu on board motherboard suggestion
Hi SrLange61,I can recommend the ASROCK Q1900B-ITX with a Gecko 540 on the latest Wheezy. No HDMI sound but every thing else is fine. Its even better now with a SSD.
srl
thanks
05 Sep 2015 09:19 #62139
by vre
16000 with all open from bios usb lan serial etc
Under 7000 with all closed from bios.
Warning in inputs you must put pull up resistors to breakout board
The following user(s) said Thank You: eFalegname
07 Sep 2015 08:03 #62177
by SrLange61
Here is the screenshot I took some time ago.
sr
sr
- eFalegname
07 Sep 2015 13:29 - 07 Sep 2015 14:13 #62183
by eFalegname
LinuxCNC on AsRock Q1900B-ITX Max Jitter 26666 ??? I'm in shock Sir
At this point the AsRock Q1900M Pro3 seems to be a better option for LinuxCNC
Last edit: 07 Sep 2015 14:13 by eFalegname.
Time to create page: 0.224 seconds
