Intel cpu on board motherboard suggestion
16 Oct 2015 04:13 #63792 by andypugh
If you unplug the Parallel port card does the "Serial Controller" go away?
16 Oct 2015 04:27 #63793 by eFalegname
Yes,the serial controller is gone...
efalegname@eF-900:~$ lspci -vv
00:00.0 Host bridge: Advanced Micro Devices [AMD] Device 1510
	Subsystem: ASRock Incorporation Device 1510
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap- 66MHz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
00:01.0 VGA compatible controller: ATI Technologies Inc Device 9802
	Subsystem: ASRock Incorporation Device 9802
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0, Cache Line Size: 64 bytes
	Interrupt: pin A routed to IRQ 11
	Region 0: Memory at fc000000 (32-bit, prefetchable) [size=32M]
	Region 1: I/O ports at f000 [size=256]
	Region 2: Memory at feb00000 (32-bit, non-prefetchable) [size=256K]
	Capabilities: <access denied>
00:04.0 PCI bridge: Advanced Micro Devices [AMD] Device 1512
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
	I/O behind bridge: 00001000-00001fff
	Memory behind bridge: f0000000-f01fffff
	Prefetchable memory behind bridge: 00000000f0200000-00000000f03fffff
	Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
	BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
		PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
	Kernel driver in use: pcieport
	Kernel modules: shpchp
00:11.0 SATA controller: ATI Technologies Inc SB700/SB800 SATA Controller [IDE mode] (rev 40) (prog-if 01)
	Subsystem: ASRock Incorporation Device 4390
	Status: Cap+ 66MHz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 32
	Interrupt: pin A routed to IRQ 19
	Region 0: I/O ports at f190 [size=8]
	Region 1: I/O ports at f180 [size=4]
	Region 2: I/O ports at f170 [size=8]
	Region 3: I/O ports at f160 [size=4]
	Region 4: I/O ports at f150 [size=16]
	Region 5: Memory at feb47000 (32-bit, non-prefetchable) [size=1K]
	Kernel driver in use: ahci
	Kernel modules: ahci
00:12.0 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI0 Controller (prog-if 10)
	Subsystem: ASRock Incorporation Device 4397
	Status: Cap- 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 32, Cache Line Size: 64 bytes
	Interrupt: pin A routed to IRQ 18
	Region 0: Memory at feb46000 (32-bit, non-prefetchable) [size=4K]
	Kernel driver in use: ohci_hcd
00:12.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller (prog-if 20)
	Subsystem: ASRock Incorporation Device 4396
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Interrupt: pin B routed to IRQ 17
	Region 0: Memory at feb45000 (32-bit, non-prefetchable) [size=256]
	Kernel driver in use: ehci_hcd
00:13.0 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI0 Controller (prog-if 10)
	Region 0: Memory at feb44000 (32-bit, non-prefetchable) [size=4K]
00:13.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller (prog-if 20)
	Region 0: Memory at feb43000 (32-bit, non-prefetchable) [size=256]
00:14.0 SMBus: ATI Technologies Inc SBx00 SMBus Controller (rev 42)
	Subsystem: ASRock Incorporation Device 4385
	Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
	Kernel driver in use: piix4_smbus
	Kernel modules: i2c-piix4
00:14.1 IDE interface: ATI Technologies Inc SB700/SB800 IDE Controller (rev 40) (prog-if 8a [Master SecP PriP])
	Subsystem: ASRock Incorporation Device 439c
	Latency: 32
	Region 0: I/O ports at 01f0 [size=8]
	Region 1: I/O ports at 03f4 [size=1]
	Region 2: I/O ports at 0170 [size=8]
	Region 3: I/O ports at 0374 [size=1]
	Region 4: I/O ports at f100 [size=16]
	Kernel driver in use: pata_atiixp
	Kernel modules: pata_atiixp
00:14.3 ISA bridge: ATI Technologies Inc SB700/SB800 LPC host controller (rev 40)
	Subsystem: ASRock Incorporation Device 439d
	Control: I/O+ Mem+ BusMaster+ SpecCycle+ MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Latency: 0
00:14.4 PCI bridge: ATI Technologies Inc SBx00 PCI to PCI Bridge (rev 40) (prog-if 01)
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop+ ParErr- Stepping- SERR- FastB2B- DisINTx-
	Latency: 64
	Bus: primary=00, secondary=02, subordinate=02, sec-latency=64
	Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
00:14.5 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI2 Controller (prog-if 10)
	Subsystem: ASRock Incorporation Device 4399
	Interrupt: pin C routed to IRQ 18
	Region 0: Memory at feb42000 (32-bit, non-prefetchable) [size=4K]
00:15.0 PCI bridge: ATI Technologies Inc Device 43a0
	Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
00:15.1 PCI bridge: ATI Technologies Inc Device 43a1
	Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
	I/O behind bridge: 0000e000-0000efff
	Prefetchable memory behind bridge: 00000000fe000000-00000000fe0fffff
00:15.2 PCI bridge: ATI Technologies Inc Device 43a2
	Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
	Memory behind bridge: fea00000-feafffff
00:16.0 USB Controller: ATI Technologies Inc SB700/SB800 USB OHCI0 Controller (prog-if 10)
	Region 0: Memory at feb41000 (32-bit, non-prefetchable) [size=4K]
00:16.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller (prog-if 20)
	Region 0: Memory at feb40000 (32-bit, non-prefetchable) [size=256]
00:18.0 Host bridge: Advanced Micro Devices [AMD] Device 1700 (rev 43)
	Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
00:18.1 Host bridge: Advanced Micro Devices [AMD] Device 1701
	Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
00:18.2 Host bridge: Advanced Micro Devices [AMD] Device 1702
00:18.3 Host bridge: Advanced Micro Devices [AMD] Device 1703
00:18.4 Host bridge: Advanced Micro Devices [AMD] Device 1704
00:18.5 Host bridge: Advanced Micro Devices [AMD] Device 1718
00:18.6 Host bridge: Advanced Micro Devices [AMD] Device 1716
00:18.7 Host bridge: Advanced Micro Devices [AMD] Device 1719
04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 06)
	Subsystem: ASRock Incorporation Device 8168
	Interrupt: pin A routed to IRQ 28
	Region 0: I/O ports at e000 [size=256]
	Region 2: Memory at fe004000 (64-bit, prefetchable) [size=4K]
	Region 4: Memory at fe000000 (64-bit, prefetchable) [size=16K]
	Kernel driver in use: r8169
	Kernel modules: r8169
05:00.0 USB Controller: Device 1b6f:7023 (rev 01) (prog-if 30)
	Subsystem: ASRock Incorporation Device 7023
	Region 0: Memory at fea00000 (64-bit, non-prefetchable) [size=32K]
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci
16 Oct 2015 04:34 #63794 by eFalegname
LinuxCNC latency-test : "ASRock E350M1 mini-itx - AMD Dual-Core Zacate E350/E350D APU 1.6GHz"
The following user(s) said Thank You: jtc, Pegaskrs
16 Oct 2015 04:53 - 16 Oct 2015 04:54 #63795 by andypugh
It might still work as a parallel card. Try the parallel port tester with 0x1c00 and e000 as the base address.
It will work, or it won't.
Last edit: 16 Oct 2015 04:54 by andypugh.
16 Oct 2015 13:12 #63802 by ArcEye
Unfortunately you have chosen to install a Sunnix PCIe card which is known to be flaky under linux
There was a patch to get the parports recognised, but don't know which kernel versions that got applied to
www.spinics.net/lists/linux-serial/msg14301.html
I should buy a MosChip based card
such as
www.iocrest.com/en/product_details85.html
16 Oct 2015 16:18 #63809 by andypugh
How did you work out that it is a Sunix card? it would be very irritating if he bought another card and that was an incompatible one too.
eFalegname: Your latency looks excellent. I think it is probably worth trying again with another Parallel port card.
Apart from anything else apparently PCI / PCIe parallel ports are faster than motherboard ones, according to PCW.
This one claims to be Moschip:
www.ebay.it/itm/InLine-Scheda-parallela-...9:g:~jsAAOSwBahVaXOG
The card you have did not specify that it was Linux compatible, but you may still be able to get your money back. Unfortunately there is no way to get the wasted time back.
16 Oct 2015 18:16 - 16 Oct 2015 18:20 #63816 by eFalegname
:( Hi guys,
two days ago I bought this one on eBay:
PCI-e one chip solution(OXFORD OXPCIe952)
Fully compliant with PCI Express Base Specification 1.1
* Single port IEEE 1284 Parallel ports with communication speeds up to 1.5 Mbps
* Supper IEEE 1284 Parallel ports standard
ECP(Enhance Capacity Port)/ EPP(Enhance Parallel Port)
SPP(Standard Parallel Port)
* Easy Plug and Play Installation
* This high performance SPP/EPP/ECP parallel card adds one DB25 parallel port,
perfect for connecting printers, scanners CD-R/RW drives, memory card readers,
printers, scanners, bar code readers and more
* Supports Windows® 2000, XP, Server 2003 ,Vista, Win7, Win8
System Requirements:
* Windows® 2000, XP, Server 2003 ,Vista, Win7, Win8 , linux
* PCI Express Card-enabled system with an available PCIe slot
We have customer has been test working in
- LabView
- Mach3 cnc
- an (older) pc oscilloscope (Velleman PSC32)
- SBIG ST237A CCD Camera Imager/Autoguider
Last edit: 16 Oct 2015 18:20 by eFalegname.
16 Oct 2015 19:01 - 16 Oct 2015 19:06 #63818 by andypugh
That should work. I have found threads and emails with that chipset working in EPP mode for the Mesa 7i43, and if it will work in EPP mode then it will definitely work in basic mode.
Last edit: 16 Oct 2015 19:06 by andypugh.
The following user(s) said Thank You: eFalegname
16 Oct 2015 21:17 #63826 by ArcEye
Device 1c00:3250 (Vendor:Model)
25 Oct 2015 21:31 - 26 Oct 2015 22:49 #64253 by eFalegname
The PP Pci-e card with the OXFORD OXPCIe952 chip works very well with LinuxCNC.
My problem right now (a week trying to solve it) is to set the proper resolution of the monitor to the integrated graphics ATI HD 6310. A NIGHTMARE!!
Last edit: 26 Oct 2015 22:49 by eFalegname.
Time to create page: 0.159 seconds
