Wireless USB suggestion
06 Jul 2016 14:31 #77084 by fc60
Replied by fc60 on topic Wireless USB suggestion
Greetings All,
I purchased an SMCWUSB-G wireless adapter and it works great!
The case is rather large and bulky; but, the adapter came with a USB extension cable and I am able to plug it into the back of my machine.
Again, many thanks to those who responded.
Cheers,
Dave
24 Oct 2018 13:12 #119335 by CrewDiver
Replied by CrewDiver on topic Wireless USB suggestion
Good day, everyone.
I`m very new to Linux and looking for solution to just plug USB wifi adapter and work with it.
I use live CD installation of LinuxCNC 2.7.14 with Debian Wheezy.
Anyone can recommend some USB wifi adapter to use with it?
24 Oct 2018 14:52 #119339 by tightmopedman9
I use a Alfa AWUSO36NH and it was plug and play.
24 Oct 2018 16:03 #119345 by OT-CNC
Replied by OT-CNC on topic Wireless USB suggestion
If you are just looking to upgrade linuxcnc via internet you can easily do that by tethering a cell phone. I have done that a few times. It was just plug and play.
24 Oct 2018 16:13 #119346 by CrewDiver
Im looking for solution to have a sharing folder between cnc machine and pc with CAD. Usb stick is useful but sometimes need a lot of movements.
Alfa looks like 90s products, sorry :)
Maybe somebody has expiriense with some small Chinese stick's
24 Oct 2018 16:33 - 24 Oct 2018 16:41 #119347 by eFalegname
Replied by eFalegname on topic Wireless USB suggestion
I would advise Alfa AWUSO36NH, which is a powerful solution with a driver for Linux. I personally use Edimax as Pathpilot does, as someone recommended me here. But the Edimax nano USB stick mounts the Realtek RTL8188CUS, RTL8192CU chipsets and you need to patch the driver to make it work with linux. Otherwise, the connection is intermittently; the problem also may afflicts the following sticks:
- ASUSTek USB-N13 **rev. B1** (0b05:17ab)
- Belkin N300
- Edimax EW-7811Un (7392:7811)
- TP-Link TL-WN822N (0bda:8178)
- TP-Link TL-WN823N
- TRENDnet TEW-648UBM N150
Last edit: 24 Oct 2018 16:41 by eFalegname.
24 Oct 2018 16:46 #119348 by fc60
25 Oct 2018 11:30 #119386 by andypugh
Replied by andypugh on topic Wireless USB suggestion
One common recommendation is the TP-Link N150. However, the chipset has changed and now it does _not_ seem to work with Linux. Certainly not with the LinuxCNC ISO.
So that is one to avoid (which might be more useful than a recommendation)
26 Oct 2018 16:31 - 26 Oct 2018 16:35 #119459 by CrewDiver
Its hard to find in local stores SMC or Alfa...
So I buy locally TP-link TL-WN821N V6
Download drivers from TP-link, unpack it and got error on compilation =)
On this forum got instructions:
On line 7 of the make file change
CONFIG_IOCTL_CFG80211=y
to
CONFIG_IOCTL_CFG80211=n
type in console in driver folder:
make modules
sudo make install
And Got SUCCESS also :)
Thank all for support!
Last edit: 26 Oct 2018 16:35 by CrewDiver.
23 Dec 2020 22:25 #193033 by faeluke
Replied by faeluke on topic Wireless USB suggestion
Reviving an old thread to understand if the answer would be the same. What is the best wireless USB dongle that is supported today? Has anyone bought one recently that did not require a driver to be installed?
Any new recommendations from those that were previously posted?
Thanks in advance!
Time to create page: 0.272 seconds
