A few ideas ( I can't sleep and few ideas popped up)
06 Jul 2018 08:17 #113544
Replied by rodw on topic A few ideas ( I can't sleep and few ideas popped up)
Tommy, I think you are the only user out there that builds working LinuxCNC systems on laptops
Sounds like we need to get ChrisM on the job again to get approval for mint to host a Linuxcnc meta package in their repo (or include ours)! That really would be a good outcome.
- InMyDarkestHour
- Topic Author
- User is blocked
- Thank you received: 111
06 Jul 2018 08:44 - 06 Jul 2018 08:49 #113548
by InMyDarkestHour
rodw wrote: Hmm, Sounds like you won't want to know that I am on the NBN with fibre to the house and a 100/40 Mb link. *places fingers in ears and says out loud lalalalalalalalalalalala
That's really unfair aren't you guys supposed to be 20 years behind NSW in the winter and 20 years and 1 hour in the summer ?
Stolen from askubuntu (cos I'm lazy)
Metapackages are a link to existing package or packages. So they are essentially a script that installs other packages.They keep the packages as dependencies
Eg: the package ubuntu-desktop installs all the packages needed for the Default UI for ubuntu. But uninstalling the same doesen't uninstall its dependencies
Maybe not totally techincally corerct but more or less the jist
Replied by InMyDarkestHour on topic A few ideas ( I can't sleep and few ideas popped up)
Hmm, Sounds like you won't want to know that I am on the NBN with fibre to the house and a 100/40 Mb link....
I don't understand meta packages.
Happy to receive snail mail contributions. Give me a couple of weeks as I have revised my freight arrangements today so when that goes live, I'll have overnight rates Australia wide but I'm not sure if that will apply to incoming freight or just outgoing.
Last edit: 06 Jul 2018 08:49 by InMyDarkestHour.
06 Jul 2018 09:39 #113550
Replied by cmorley on topic A few ideas ( I can't sleep and few ideas popped up)
One must think about the target audience.
Someone from windows world trying to get linuxcnc up and running.
This leads me to an ISO. Complete usable cnc package.
I would install:
rt kernel
linuxcnc
build essentials
GLADE editor 3.8.6
Mesaflash
I wouldn't uninstall anything unless I had to.
This is also aprox. what we asked permission for.
My 2 cents
Chris M
I would install:
rt kernel
linuxcnc
build essentials
GLADE editor 3.8.6
Mesaflash
My 2 cents
Chris M
- InMyDarkestHour
- Topic Author
- User is blocked
06 Jul 2018 11:02 - 06 Jul 2018 11:06 #113557
by InMyDarkestHour
Above is the script I used in remastering, openssh-server, midnight commander, geany & gftp are basically what I add when I do an install anyways. They are pulled from the official repos.
The linuxcnc packages & glade are what I put on google drive, the kernel is the same on as on google drive, but I had to patch it with aufs to work with the remastered live cd. (This has not been up loaded yet).
The mesaflash utilities are from the linuxcnc repos.
No build-essential, but the linuxcnc-dev package seems to pull in everything, I did a quick sudo apt-get install build-essential of the live iso and all that was installed was the build-essential pkg and nothing else. Prior to that I did a quick halcompile --install on a simple component and all went well.
If it wasn't removed or installed in the above script it wasn't removed or added (apart from the required deps).
#!/bin/sh
# Used for adding LCNC to Linux Mint 18.3 for respin
# Run from same directory linux kernel & lcnc debs are in
echo "Adding required repos"
sudo add-apt-repository 'deb http://mirrors.kernel.org/ubuntu precise main universe'
sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key 3cb9fd148f374fef
sudo add-apt-repository "deb http://linuxcnc.org/ precise base"
sudo apt-get update
echo "Removing ndiswrapper"
apt remove --purge ndiswrapper*
echo "Installing Linux Kerenl packages"
apt install ./linux-headers-4.11.12-rt16_4.11.12-rt16-2_amd64.deb
apt install ./linux-firmware-image-4.11.12-rt16_4.11.12-rt16-2_amd64.deb
apt install ./linux-image-4.11.12-rt16_4.11.12-rt16-2_amd64.deb
echo "Installing Linuxcnc packages"
apt install ./linuxcnc-uspace_2.7.14_amd64.deb
apt install ./linuxcnc-doc-en_2.7.14_all.deb
apt install ./linuxcnc-doc-fr_2.7.14_all.deb
apt install ./linuxcnc-uspace-dev_2.7.14_amd64.deb
sudo apt-get install hostmot2-firmware-all mesaflash
echo "Installing glade3-3.8.6"
apt install ./glade3_3.8.6-1_amd64.deb
echo "Installing devhelp"
apt-get install devhelp
# Packages below are optional and maybe commented out
echo "Installing openssh-server"
apt-get install openssh-server
echo "Installing Midnight Commander"
apt-get install mc
echo "Installing gftp"
apt-get install gftp
echo "Installing geany"
apt-get install geany
# Comment this out if being used to install LCNC on pre-installed Mint installation
# Kerenl can be removed after a reboot or left in place
# Leave uncommented if respinning ISO
echo "Removing old kernel"
apt remove --purge linux-image-4.10.0-38*
Last edit: 06 Jul 2018 11:06 by InMyDarkestHour.
06 Jul 2018 11:23 #113561
Don't forget a PREEMPT_RT version for us mesa ethernet users.
I would install:
rt kernel
linuxcnc
build essentials
GLADE editor 3.8.6
Mesaflash
My 2 cents
Chris M
- Thank you received: 5961
06 Jul 2018 13:54 #113569
Replied by tommylight on topic A few ideas ( I can't sleep and few ideas popped up)
@ ozzyrob
I will give that a try whenever i have some time to spare. I assume it is for Mint 18.n.
@rodw
that is the preempt rt kernel, and uspace version of Linuxcnc. The other version has RTAI in it's name.
@rodw
- InMyDarkestHour
- Topic Author
- User is blocked
06 Jul 2018 18:42 #113597
by InMyDarkestHour
The deb packages I compiled were specifically for 18.3, actually I originally compiled them for techno for his 18.3 install.
This is the link to my google drive:
drive.google.com/drive/folders/1EJFzxRqd...5gseRPXpWnpd-n0PoWuA
As I said the kernel on the google drive doesn't have aufs required for respinning a live cd, but will work on an already installed & running Mint-18.3 installation. Just only change the kernel related package names to suit eg:
becomes
linux-headers-4.11.12-rt16_4.11.12-rt16-1_amd64.deb
and so forth.
becomes
and so forth.
06 Jul 2018 20:23 #113603
I already have those form the first install, so on subsequent install i did not have to compile all over again, and it worked every time.
Still will try that tomorrow or on Sunday.
Thank you.
Thank you.
- InMyDarkestHour
- Topic Author
- User is blocked
07 Jul 2018 13:31 - 07 Jul 2018 14:29 #113665
by InMyDarkestHour
For those that have commented on this thread and are interested I have uploaded the iso to my google drive. If you would like the link please send me a message as I really don't want to cause any issues with the guys at Linux Mint due to branding with the link being made public at this time. For everyone else I apologise and hope you can understand due to the branding issues spoken about earlier.
SHARING HAS BEEN REMOVED, FILES ARE NO LONGER AVAILABLE
Last edit: 07 Jul 2018 14:29 by InMyDarkestHour.
07 Jul 2018 14:08 - 07 Jul 2018 14:14 #113668
No worries ! Thank you for your effort and you are right that was not such a good idea.
Aaaaand a miss ! Wrong thread but related to the same thing.
Last edit: 07 Jul 2018 14:14 by tommylight. Reason: explanation
Time to create page: 0.162 seconds
