Touchscreen Asus VT168
15 Nov 2018 10:24 #120743
by the_muck
Touchscreen Asus VT168 was created by the_muck
Hello,
i have bought the above Touchscreen and i try to use it under LinuxCNC with gmoccapy... but of course, it did not run under Linux...
I start with a fresh linuxcnc-2.7-wheezy.iso installation.
than install USB utilities.
OK Display is found there with Elan Microelectronics. I have checked it with disconnecting the Display
Ok then check the X11 Support
nothing..
I have googled a lot but have not find a solution
lsusb
mill@CNCMill:~$ lsusb
Bus 001 Device 005: ID 148f:2573 Ralink Technology, Corp. RT2501/RT2573 Wireless Adapter
Bus 003 Device 002: ID 04f3:249f Elan Microelectronics Corp.
Bus 004 Device 002: ID 413c:2003 Dell Computer Corp. Keyboard
Bus 004 Device 004: ID 1c4f:0003 SiGma Micro HID controller
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
mill@CNCMill:~$
xinput
mill@CNCMill:~$ xinput
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ SIGMACHIP Usb Mouse id=9 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Power Button id=7 [slave keyboard (3)]
↳ Dell Dell USB Keyboard id=8 [slave keyboard (3)]
↳ ACPI Virtual Keyboard Device id=10 [slave keyboard (3)]
mill@CNCMill:~$
16 Nov 2018 16:09 #120840
Replied by andypugh on topic Touchscreen Asus VT168
You might have more luck with this question on more generically Linux forums.
(we know a lot about LinuxCNC here, but we are not, in the main, computer experts).
Though it might be a bad sign that this thread comes 5th in Google when searching for VT168 Linux
16 Nov 2018 16:38 #120843
Replied by rodw on topic Touchscreen Asus VT168
Wheezy is a pretty old OS now. I'm not saying its going to fix it but I found that hardware that did not work with Wheezy just worked on Linux Mint without installing anything. Maybe try the stretch ISO install
www.linuxcnc.org/testing-stretch-rtpreempt/
16 Nov 2018 17:25 #120846
by the_muck
Replied by the_muck on topic Touchscreen Asus VT168
Hello,
i testet the Monitor on an old Laptop witch Linux Lite and every think works fine with a good touch feeling out of the box.
now i download this *.iso.
linuxcnc-stretch-uspace-i386.iso
this need a bit time, but it is possible to boot a live system from USB to test the Touchscreen?
16 Nov 2018 17:30 #120847
Yes
Yes
16 Nov 2018 17:35 - 16 Nov 2018 17:37 #120849
by the_muck
Thanks this what my laptop says with Linux Lite
and
The Touchscreen is listed... no MultiTouch but it is realy ok
lsusb
Bus 002 Device 002: ID 5986:01a6 Acer, Inc Lenovo Integrated Webcam
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 003: ID 0a5c:217f Broadcom Corp. BCM2045B (BDC-2.1)
xinput
⎜ ↳ ELAN Touchscreen id=10 [slave pointer (2)]
⎜ ↳ SynPS/2 Synaptics TouchPad id=13 [slave pointer (2)]
⎜ ↳ TPPS/2 IBM TrackPoint id=14 [slave pointer (2)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Power Button id=8 [slave keyboard (3)]
↳ Sleep Button id=9 [slave keyboard (3)]
↳ Integrated Camera id=11 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=12 [slave keyboard (3)]
↳ ThinkPad Extra Buttons
Last edit: 16 Nov 2018 17:37 by the_muck.
16 Nov 2018 21:21 #120865
by the_muck
It works! Thanks...
- Thank you received: 5942
17 Nov 2018 05:53 #120890
Replied by tommylight on topic Touchscreen Asus VT168
Nice !
- F4br1c4t3D
19 Feb 2019 12:06 #126765
by F4br1c4t3D
Replied by F4br1c4t3D on topic Touchscreen Asus VT168
I'm struggling to get a touchscreen to function with linuxcnc also. It's an elo touchscreen EL1519l, I'm runing Debian Wheezy.
if i run lsusb from terminal I can see the device listed device003 elo TouchSystems
it doesn't show in xinput though.
the_muck what was your solution in the end? did you install the mint distro, was that what got you up and running?
Cheers,
Steve
Cheers,
Steve
Time to create page: 0.295 seconds
