Joystick
- garthnoakes
30 Oct 2019 20:24 #149213
by garthnoakes
Joystick was created by garthnoakes
Has anyone successfully installed a joystick on Debian Wheezy?
- garthnoakes
31 Oct 2019 22:13 #149314
by garthnoakes
Replied by garthnoakes on topic Joystick
That didn't work - even after an apt-get update, the apt-get install usbutils tells me the package is not available
- garthnoakes
01 Nov 2019 03:20 #149330
by garthnoakes
Thats using LinuxCNC 2.7.0 (and of course internet access)
01 Nov 2019 12:00 #149346
by pl7i92
hi
you do not need anything
open a terminal type command
lsusb
my output -> Bus 004 Device 002: ID 0079:0006 DragonRise Inc. PC TWIN SHOCK Gamepad
so gamepad is there
now the input name
in terminal type
less /proc/bus/input/devices close the view with q =quit
it is usaly the last entry
so the name is Joystick of the Gamepad
open a mashine can be also a SIM mashine
home the mashine
goto MASHINE in top bar HAL_View
type in the entryfield offcause your name "Joystick"
loadusr -W hal_input -KARL Joystick
it shoudt say HAL_input started
close the HAL_VIEW
reopen Hal_view
PINS -> input ->0
take the VIEW to discover not SHOW on the right side
click all BTN ### only the not NOT
NOW hit the Butons on the joystick
all clear
lsusb
so gamepad is there
now the input name
in terminal type
I: Bus=0003 Vendor=0079 Product=0006 Version=0110
N: Name="DragonRise Inc. Generic USB Joystick "
P: Phys=usb-0000:00:04.0-5/input0
S: Sysfs=/devices/pci0000:00/0000:00:04.0/usb4/4-5/4-5:1.0/0003:0079:0006.0001/input/input11
U: Uniq=
H: Handlers=event10 js0
home the mashine
close the HAL_VIEW
reopen Hal_view
PINS -> input ->0
all clear
- garthnoakes
01 Nov 2019 12:45 #149348
by garthnoakes
lsusb is not available- because usbutils package is not installed. Which cannot be found - an apt-get tells me it is not available
06 Nov 2019 13:03 #149705
You can probably get lsusb from the archive repositories.
The problem you have is likely to be due to Wheezy being end-of-line and out of support (it is really very old)
forum.linuxcnc.org/29-forum-announcement...-repositories#135195
Time to create page: 0.219 seconds
