Fixing Wheezy Repositories
28 May 2019 21:10 #135195
Fixing Wheezy Repositories was created by andypugh
The Wheezy repositories have been moved to the archive server now that Wheezy is EOL.
You will need to disable the updates repositories, as those no longer exist and change the base and security URIs to point to the archive server.
You can do this either by editing /etc/apt/sources or in the Synaptic package manager.
You also need to tell apt to ignore the fact that the release certificate is out of date, you can still update packages with this incantation:
sudo apt-get update -o Acquire::Check-Valid-Until=false
The following user(s) said Thank You: BigJohnT
31 May 2019 23:25 #135506
by BigJohnT
Replied by BigJohnT on topic Fixing Wheezy Repositories
Andy,
Can you copy your /etc/apt/sources and paste that here?
JT
JT
31 May 2019 23:33 - 13 Apr 2020 22:44 #135507
Replied by andypugh on topic Fixing Wheezy Repositories
deb http://archive.debian.org/debian wheezy main contrib non-free
deb-src http://archive.debian.org/debian wheezy main contrib non-free
# deb http://archive.debian.org/debian wheezy/updates main contrib non-free
# deb-src http://archive.debian.org/debian wheezy/updates main contrib non-free
deb http://archive.debian.org/debian-security wheezy/updates main contrib non-free
deb-src http://archive.debian.org/debian-security/ wheezy/updates main contrib non-free
Last edit: 13 Apr 2020 22:44 by andypugh.
Time to create page: 0.395 seconds
