Help choosing LinuxCNC PC
- renatofmpinheiro
03 Nov 2019 16:55 #149498
by renatofmpinheiro
Help choosing LinuxCNC PC was created by renatofmpinheiro
I need some help to choose the best PC to use with the linuxCNC and this kit: www.ebay.de/itm/-Best-Offer-Free-4Axis-N...-Wantai/183265631829
I see some posts mencioning the j1800, j1900 and j4005 but don't find any latency test results for that boards.
In your opinion what PC I should buy. Don't need to be an mini itx board, can be any size or an ready desktop.
Best regards,
Renato Pinheiro
Best regards,
Renato Pinheiro
03 Nov 2019 17:22 #149499
by pl7i92
Replied by pl7i92 on topic Help choosing LinuxCNC PC
hi
we use alot of this PC
its very cheep and runs like hell on that set of drivers
www.ebay.de/itm/FUJITSU-SIEMENS-ESPRIMO-...-DVD-RW/254284503451
if you decide to go for separate components you will be some what cheeper
4Drivers a 8Euros
1 5Axis board at 10 euro
and the powersup 36V at 12A 22Euros
4Drivers a 8Euros
- renatofmpinheiro
03 Nov 2019 18:52 #149504
by renatofmpinheiro
Replied by renatofmpinheiro on topic Help choosing LinuxCNC PC
Thanks pl7i92,
You have any information of the latency test for that PC?
Where you get the drivers at that price?
- renatofmpinheiro
04 Nov 2019 10:57 #149536
by renatofmpinheiro
What do you think about this one: www.ebay.co.uk/itm/Cheap-Dell-Optiplex-3...Options/362797914851
Best regards,
Renato Pinheiro
Best regards,
Renato Pinheiro
- renatofmpinheiro
05 Nov 2019 18:36 #149630
by renatofmpinheiro
The PC need to be that or any PC with that CPU works fine?
- renatofmpinheiro
08 Nov 2019 21:59 #149943
by renatofmpinheiro
I'm thinking building one with the ASRock J4005B-ITX, any advice?
09 Nov 2019 01:06 #149953
Replied by andypugh on topic Help choosing LinuxCNC PC
Unfortunately it is hard to say unless someone else has the exact same PC.
But most things work OK, it is just that some are better.
Don't get too hung-up on the latency numbers.
- Thank you received: 5932
09 Nov 2019 01:40 #149955
Replied by tommylight on topic Help choosing LinuxCNC PC
Had 5 of those, they do work nicely with RTAI and they do work quite good with Preempt-RT with something like 70000 to 80000 latency, with Debian Stretch.What do you think about this one: www.ebay.co.uk/itm/Cheap-Dell-Optiplex-3...Options/362797914851
Best regards,
Renato Pinheiro
10 Nov 2019 10:49 #150047
by billykid
Replied by billykid on topic Help choosing LinuxCNC PC
I was lucky enough to find an "iei kino DH610 R10" with cpu i5 and 2 gb ram at € 100 and I must say that it goes perfectly. I have 2 ssd with wheezy and stretch goes well with both in closed loop at 8 khz.
latency wheezy rtai = less than 20000 never latency errors
latency stretch rt-preempt = about 30000 some case of error always at 8 khz however never fails.
It is an industrial card that costs a lot but is excellent.
Mauro
Mauro
Time to create page: 0.186 seconds
