Best motherboard for linuxcnc
16 Nov 2019 12:26 #150469
by Pantiak
Best motherboard for linuxcnc was created by Pantiak
Hi everyone, help me choose the motherboard for linuxcnc, I will use it with touch screen and mesa pci boards(so the motherboard must have pci).
choose from these options, read forum but so and not was able will be defined.
Gigabyte GA-J3455N-D3H or
Gigabyte GA-N3160N-D3V or
Gigabyte GA-E2500N-AMD E1-2500 or
ASRock AD2550B-ITX or
MINITOSTAR ITX-M58-D56L (D525, DDR3, PCE, mSATA, SIM) mini-ITX or ASUS J1800I-A or Gigabyte GA-E3000N or Intel D2700DC.
Please help me decide on the choice, I want the best. Thanks
16 Nov 2019 16:44 #150477
by pl7i92
Replied by pl7i92 on topic Best motherboard for linuxcnc
what is the mashine beond the bord gone be
as you say touchpanel ?? lathe use
why pci
use a eth board as it is the newest fastest safest technologie
why pci
17 Nov 2019 08:50 #150510
by Pantiak
Replied by Pantiak on topic Best motherboard for linuxcnc
A touch screen monitor will be used. PCI, because it is already purchased(what exactly boards I still do not know exactly, they are in the process of delivery).
17 Nov 2019 08:53 #150513
by Pantiak
I only need advice on choosing a motherboard from the suggestion above
- Dinuka_Shehan
- Thank you received: 26
17 Nov 2019 09:21 #150518
by Dinuka_Shehan
Replied by Dinuka_Shehan on topic Best motherboard for linuxcnc
Use a gigabyte mb
17 Nov 2019 09:55 #150519
by billykid
Replied by billykid on topic Best motherboard for linuxcnc
I'm sorry. not having tried any of these cards I can't even tell you if they work. I can tell you what I'm using if it can be useful.
mauro
forum.linuxcnc.org/18-computer/37743-hel...g-linuxcnc-pc#150047
mauro
20 Nov 2019 19:34 #150785
by ississ
Replied by ississ on topic Best motherboard for linuxcnc
No experience with any of the boards.
But a PCI slot is not a real requirement.
PCI-PCIe adapter works at least in my setup with Asrock J1900B-ITX (with one PCIe x1 slot) and Mesa 5i25 (see here ).
Any other similar adapter should work too if it has a common supported bridge chip.
I'd choose GA-J3455N-D3H from that list of boards and give it a try.
At least on my J1900 memory modules affect latency, two identical modules seems to perform better than single or different modules. Size may also matter, I had mainly 8G modules for testing...
20 Nov 2019 19:49 #150788
by pl7i92
the D525 and J1800 are proved but in older configuration
theefor i did ask on what hardware you expect to run
the newer GA will probably work on MESA ETH stuff as noone has latency values on them
if you plan Stappers dirct on Parport PCI you might get into trouble
Time to create page: 0.127 seconds
