Will either of these work?
- Thank you received: 5957
26 Jul 2020 20:38 #175967
For everything else i use mint. For older PC/Laptops use the XFCE version of Mint, it is a bit lighter on resources.
Replied by tommylight on topic Will either of these work?
I do, i use Debian only on industrial retrofits that do only machine work and nothing else.hey tommylight do you recommend Mint19.3 over Debian for general experimentation.
The following user(s) said Thank You: my1987toyota
- my1987toyota
- Topic Author
- Thank you received: 271
27 Jul 2020 00:26 - 27 Jul 2020 00:37 #175995
by my1987toyota
Replied by my1987toyota on topic Will either of these work?
then I guess that is what I will use then. My new SSD should come in a few days.
Do you recommend sticking with 19.3 or is it better to install the 20 ?
Last edit: 27 Jul 2020 00:37 by my1987toyota.
27 Jul 2020 09:15 #176029
I am sticking to 19.3 till 20.1 gets out, then slowly upgrade.
- my1987toyota
- Topic Author
28 Jul 2020 02:02 #176203
by my1987toyota
WOW Amazon must have had my SSD at a local warehouse . I ordered it yesterday and got it today. Looks like my to do list just got longer.
- my1987toyota
- Topic Author
01 Aug 2020 01:47 #176721
by my1987toyota
well I am currently installing Linux Mint xfce on the lap top. Looks like I need to get it a battery. I will install Linuxcnc on it in a few days
and try the max jitter test ( and probably cringe at the results ). I will let everyone know the results when compleated.
- my1987toyota
- Topic Author
02 Aug 2020 13:01 - 02 Aug 2020 19:29 #176888
by my1987toyota
well this is going to be harder then I thought . I can run the Mint 19.3 install disk in safe mode and all is fine but when I try to load in the regular mode the screen shows overlapping images and the side edge alignment is almost in the middle of the screen .
It probably doesn't help that this is a 2008 lap top with AMD and Nvidia graphics . as an aside the same thing happens when I tried the Debian wheezy install disk.
To me this looks like a graphics driver error, however I don't know what the regular mode runs that the safe mode does not.
at least I can get linuxcnc 2.8 loaded
Last edit: 02 Aug 2020 19:29 by my1987toyota.
03 Aug 2020 03:21 #176992
by seuchato
Replied by seuchato on topic Will either of these work?
There might be hope, if you blacklist nouveau. would be interesting to see pre and post blacklis latency effects.
Also: check your bios settings. there might be an option to play with regarding grafics
- my1987toyota
- Topic Author
04 Aug 2020 01:30 #177151
by my1987toyota
I will defiantly check into that
09 Aug 2020 08:37 #177738
by Reinhard
If you want to use realtime kernels, you need to use nouveau x-server.
Replied by Reinhard on topic Will either of these work?
Are you aware, that nvidia-x-server does not work with realtime kernels?There might be hope, if you blacklist nouveau. would be interesting to see pre and post blacklis latency effects.
