Script for automated testing of computer latency.
23 Feb 2022 22:08 #235656
by arvidb
Replied by arvidb on topic Script for automated testing of computer latency.
Glad to hear it!
25 Feb 2022 19:49 #235818
by seuchato
Replied by seuchato on topic Script for automated testing of computer latency.
Grin
19 Mar 2022 17:46 #237727
by Roguish
Replied by Roguish on topic Script for automated testing of computer latency.
hello all.
where can one find the latest, greatest version of this script....
thanks.
thanks.
20 Mar 2022 15:39 #237818
by seuchato
Roguish
Haha! Thanks for the flours!
In short: here , a bit farther away, on my desktop computer
But: It really needs to be updated in several aspects:
greez
chris
- Latency is not added to the hw file due to change of latency-test output format (solved, but not yet publically available)
- Cannot read AMD based temperature data (partially solved)
- struggles on raspberry pi at several places (partially solved)
- Sometimes fails to invoke vimeo video streaming (not solved yet)
- Needs an extension to do some heavy disc io (draft ready, but really not yet alpha state)
greez
chris
The following user(s) said Thank You: Roguish, tommylight
20 Mar 2022 22:05 #237857
by Roguish
seuchato,
tried it out. very interesting.
when the latency test is run, is it running with both base and servo threads?
My system is pure servo without a base thread.
would be nice if there could be a fairly easy way to run only a servo thread, even if it means modifying the code a bit......
just a thought.
thanks.
just a thought.
thanks.
21 Mar 2022 14:12 #237920
by seuchato
Roguish
You can run just servothread. There is an option in a dialog at the beginning of the script. Check again, I am pretty sure you'll find the drill. But I really should write a short manual. However I am trying in vain to stretch a day to 48 hours.
Greez
chris
Greez
chris
21 Mar 2022 15:05 #237927
by Roguish
thanks for the reply. I will read closer.....
N
N
22 Apr 2022 02:20 - 22 Apr 2022 02:24 #240848
by Kilohertz
Replied by Kilohertz on topic Script for automated testing of computer latency.
Hi guys,
I am just getting going with LinuxCNC and am enjoying the journey so far. I have been building PCs for a good part of my life, but this is my first foray into Linux.
Forgive me if this has been answered, but can this latency script be run in LinuxCNC Live or does it have to be an installed version on hard drive? I have about a dozen computers sitting on the floor of my office waiting for testing, hoping not to have to install it 12 times to run the tests.
The reason I ask is that it seems to run fine on Live, but I get no latency results in either log file.
Cheers
Cheers
Last edit: 22 Apr 2022 02:24 by Kilohertz.
- ALittleOffTheRails
- User is blocked
- Thank you received: 65
22 Apr 2022 03:20 #240849
by ALittleOffTheRails
Replied by ALittleOffTheRails on topic Script for automated testing of computer latency.
Generally all I do is boot with the Live version on USB stick, then run the included latency test with Linuxcnc and mess around with it for a bit.
If you want to use the script in this thread, do a full install on one HDD\SSD and use the same HDD\SDD on each computer. Mostly once Linux is installed on a HDD it's pretty agnostic to being swapped from machine to machine. Unlike windows that will at best tie itself in knots or not boot.
The only issue is you have a mix of machines that boot from BIOS vs UEFI.
I'd rather install Linuxcnc on 12 machines than Windows 10 on one....I know which is the quicker way to go.
22 Apr 2022 03:31 - 22 Apr 2022 03:34 #240850
by Kilohertz
Too funny!
Awesome, thank you for the quick reply, I love Linux more every day. That's good info, I have many 7200 RPM drives here and a nice 240G SSD on the way, for now I'll try the HDDs.
I do have quite a mix of machines but most are 2005-2009, I have weeded out out the really old ones with less than 2G processors and BIOS from 2000 or so.
Now the fun begins!
Cheers
Now the fun begins!
Cheers
Last edit: 22 Apr 2022 03:34 by Kilohertz.
Time to create page: 0.428 seconds
