- Hardware & Machines
- Computers and Hardware
- Results of latency test, list of computers tested for use with LinuxCNC
18 Dec 2023 13:18 #288483
by seuchato
Replied by seuchato on topic Results of latency test, list of computers tested for use with LinuxCNC
Hi all
Got all the data given in this thread now entered in a libre office table, see here .
Compiling this table helped me also to get an overview of what the script needs urgently. So hold on
Greez
chris
Greez
chris
31 Dec 2023 14:15 #289431
by Ismacr63
Replied by Ismacr63 on topic Results of latency test, list of computers tested for use with LinuxCNC
Hello, I have tested these kernel parameters, and I have managed to lower the latency to a stable 12k, but I have the problem that the screen resolution remains at 1028x768 instead of 1920x1080. I have removed the "nomodeset" and the resolution is set to 1920x1080 but the latency skyrockets.That's pretty high indeed, did you try to disable as many as possible energy saving settings in the bios? Adding kernel parameters?
Perhaps there is a bad ram chip, you could try to remove 2 of them, 32gb is a lot for LinuxCNC, 4gb is enough most of the times. To keep dual channel, you probably need to have one in slot 1 and 3.
The kernel parameters that worked for my machine and you could try:
isolcpus=3 intel_pstate=disable processor.max_cstate=0 idle=poll cpufreq.default_governor=performance i915.enable_dc=0 ahci.mobile_lpm_policy=1 irqaffinity=0 nomodeset quiet
- routerman22
- Thank you received: 8
01 Mar 2024 13:02 - 01 Mar 2024 14:15 #294841
by routerman22
Replied by routerman22 on topic Results of latency test, list of computers tested for use with LinuxCNC
Dell optiplex 7050 micro (SFF?) I5-6500 + ssd + 1x8gb ram (2 ram stick would be higher performance)
Old pic:
forum.linuxcnc.org/18-computer/39371-res...cnc?start=330#271103
added these gub parameters:
forum.linuxcnc.org/18-computer/39371-res...cnc?start=330#271127
+ this IRQ schipt mod (had to manually install irqbalancer) : forum.linuxcnc.org/38-general-linuxcnc-q...ead-and-irq-affinity
= giant improvement :
8khz servo loop + 1 yt + 4x glx running @400-500fps
Old pic:
Last edit: 01 Mar 2024 14:15 by routerman22.
The following user(s) said Thank You: seuchato, tommylight
- spicybagel
- Thank you received: 3
14 Mar 2024 01:33 #295864
by spicybagel
Replied by spicybagel on topic Results of latency test, list of computers tested for use with LinuxCNC
New here and thought I would share a test from an older gaming pc I plan to use after getting some good results with it. This test was done from the bootable usb iso. Took lots of bios fiddling to get it this low.
pc specs:
https://imgur.com/a/71leQnJ
pc specs:
- cpu: amd ryzen 5 3600x
- mobo: asrock b450 pro4
- ram: 16gb ddr4
- gpu: amd rx570
- some random brand pcie wifi card
14 Mar 2024 01:42 #295865
by cornholio
Replied by cornholio on topic Results of latency test, list of computers tested for use with LinuxCNC
Looks good, great for software stepgen, you going to go with Mesa or Parallel Port setup ?
If you are going with Mesa there should be no need to isolate a cpu and you'll only need the servo thread,no base thread required.
If not make sure to search the forums regarding PCIe Parallel Port cards, there's a lot of info there and no need to start a new thread.
- Topic Author
- Thank you received: 5986
14 Mar 2024 02:12 #295867
Replied by tommylight on topic Results of latency test, list of computers tested for use with LinuxCNC
2 cores????
How did you do that?
Ryzen 5 3600X has 6 cores and 12 threads
Did you by any chance limit processors to 1 in BIOS?
14 Mar 2024 03:39 #295872
by seuchato
Did you move and/or resize the glxgears / browser window while runing the test?
greeez
chris
Thx for sharing this!New here and thought I would share a test from an older gaming pc I plan to use after getting some good results with it. This test was done from the bootable usb iso. Took lots of bios fiddling to get it this low.
pc specs:
- ram: 16gb ddr4
- gpu: amd rx570
greeez
chris
- spicybagel
14 Mar 2024 04:09 #295875
by spicybagel
I picked up a mesa 7i96s after reading about that which is nice.
In the overclocking section there was an option to reduce it to either 2 or 4 cores and I only tested with 2. The setting that actually gave the most improvement from my testing was setting a custom core pstate frequency and changing the cpu frequency/voltage from auto to a set value. There were a bunch of other random suspicious power management setting I turned off and it wasn't a very scientific process sadly lol.
I did move the gears/browser around and let it run for a couple hours.
14 Mar 2024 11:50 #295893
by seuchato
spicybagel
Thx a ton! Also for the hints on
greez
chris
- overclocking section
- custom core pstate frequency
- cpu frequency/voltage
greez
chris
- spicybagel
14 Mar 2024 17:17 #295910
by spicybagel
drive.google.com/drive/folders/1Wh2qURfV...81yiwalk?usp=sharing
Feel free to look through my bios settings, I took pictures of most settings for my own references. If you google the asrock b450 pro4 manual it explain what each setting does I think.
Time to create page: 0.216 seconds
