No Input on parallel port PCI card
- Steffen 2.0
31 Jul 2020 09:46 #176626
by Steffen 2.0
No Input on parallel port PCI card was created by Steffen 2.0
Let me introduce me first. My name is Steffen, I am a nearly 30 year old mechanical engineer, working in the research industries in Germany. I recently bought the most crappiest CNC router one could imagine (I think there are more than 3 broken tread tabs in the machine remaining), but it was cheap and I will get it mechanically get to work.
I also purchased an old PC (core 2 Quad Q6600), on that I was able to install wheezy and linux cnc, jitter is with some tweaking (thank you Linux CNC forum!) about 18 000ns.
The mainboard has no parallel port, so I bought a PCI card (2 different ones by now). Both seem to work, except they do not show any response to inputs. I can control the machine, in stepconf and in the machine control, but I can not get any response on the inputs.
I tried various things, including a different PCI card, but nothing seems to help.
My test procedure is to short wire pin 1 and 10 on the paralleport. I expect the pin 10 input to change, corresponding to the output number one (I control it with the paralleport tester).
The card seems to be recognized as parport 0.
Any ideas on why my pc does not recognize inputs but all outputs work fine? Or even better, has someone a solution to that
31 Jul 2020 10:02 - 31 Jul 2020 10:04 #176629
by Clive S
Replied by Clive S on topic No Input on parallel port PCI card
Are you using a brake-out board. Also post your config files ie HAL and INI file will help
I you are using the Chinese bob with a relay on it . It requires 12-24v as well as 5V
Last edit: 31 Jul 2020 10:04 by Clive S.
- Thank you received: 5956
31 Jul 2020 10:34 #176637
Wire the input pin to the ground or the shield of the parallel port, while checking the LED on the tester. That should work.
Also, you can do the same test you did but with the pin 2 as output.
Parallel port has 8 data pins that can do enough current to drive plenty of stuff, but the 5 control pins can not provide the same amount of current and might not be push-pull configuration as the data pins. Also some ports have no pull up resistors on the inputs, but yours seems to have them.
Replied by tommylight on topic No Input on parallel port PCI card
That procedure might and might not work, depending on the parallel port electronics.My test procedure is to short wire pin 1 and 10 on the paralleport. I expect the pin 10 input to change, corresponding to the output number one (I control it with the paralleport tester).
- Steffen 2.0
31 Jul 2020 16:57 #176681
by Steffen 2.0
Replied by Steffen 2.0 on topic No Input on parallel port PCI card
thanks for the quick replay. Attached you find the ini and hal file.
I am currently using/measuring only directly the port. I have also the ability to measure voltages if this could be helpful?
For the stepper drivers, I am using a cheap chinese TB6560 Stepper board.
Currently I have a pci-e Card to parallel installed (only this card, no other parallel card), no luck as well.
31 Jul 2020 17:34 #176683
Start from the beginning:
Are you using the LinuxCNC port tester?
Did you edit the hal file to change the port address ?
What does
sudo lspci -v
in a terminal say?
If you have done all the above, connect pin 2 to pin 10 and test, then connect pin 10 to ground or port shield and check the LED.
What does
sudo lspci -v
in a terminal say?
The following user(s) said Thank You: Steffen 2.0
- Steffen 2.0
31 Jul 2020 18:15 #176689
by Steffen 2.0
yeah, so starting from the beginning was the trick, I did not change the port in the ptest.hal file. Sorry I was not aware that I had to do this, I thought it would use parport0. I can check tomorrow if the detection of the inputs work now, I will give you final feedback.
Thank you very much for the quick reply!
31 Jul 2020 19:11 #176692
You are welcomed, always.
MFG
Tom.
MFG
Tom.
- Thank you received: 1370
02 Aug 2020 02:19 #176845
That is something that should maybe be changed. I think the little parallel port testing configuration was made before the option of simply using 0 as the port address was an option in Linuxcnc.
Replied by Todd Zuercher on topic No Input on parallel port PCI card
Time to create page: 0.181 seconds
