BeagleBone with LinuxCNC to replace old PC?
15 Aug 2020 06:22 #178236
by berntd
BeagleBone with LinuxCNC to replace old PC? was created by berntd
I just read that LinuxCNC runs on BeagleBoneBlack.
I see it is named Machinekit but is it the same as this here LinuxCNC ?
If same, is it not covered by linuxcnc.org?
Can such a BeagleBone computer be used to interface with an existing Gecko CNC driver that has a parallel/printer port input?
Regards
berntd
Regards
berntd
- Thank you received: 5956
15 Aug 2020 07:57 #178244
Replied by tommylight on topic BeagleBone with LinuxCNC to replace old PC?
They are essentially the same thing with some differences, and it is not covered by LinuxCNC as they do have their website and forum, but there is plenty of info about BBB and Machinekit here also.I just read that LinuxCNC runs on BeagleBoneBlack.
It should work, but i do not know how as i never used a BBB.Can such a BeagleBone computer be used to interface with an existing Gecko CNC driver that has a parallel/printer port input?
- BeagleBrainz
- User is blocked
- Thank you received: 570
15 Aug 2020 09:25 #178253
by BeagleBrainz
Replied by BeagleBrainz on topic BeagleBone with LinuxCNC to replace old PC?
Machine kit works, you'll have to ask on the MK google group regarding which image to use.
You will also have to hunt around for a 3.3v to 5v converter board to sit between the BBB & the Gecko interface.
Personally unless you want a controller with a small foot print I'd go with a x86 PC.
The BBB was fun.
Linuxcnc has better support IHMO.
In actual fact what you spend faffing around with a BBB, time & money, you'll have a better experience with a suitable MESA card and x86 Platform connected to your gecko setup.
Plus if the BBB goes belly up you will either have to find another BBB or jump to another platform.
The BBB was fun.
15 Aug 2020 09:42 #178254
by berntd
Replied by berntd on topic BeagleBone with LinuxCNC to replace old PC?
True true. But the parallel port's days have been numbered for some time.
I have had heaps of issues recently with the CNC PC. Power supply, memory, keyboard PS2 port, harddrive.
It will have to go eventually and replacement will be hard.
- BeagleBrainz
- User is blocked
15 Aug 2020 09:54 #178255
by BeagleBrainz
I'd look at something such as below, it has a Ethernet connection, I don't think Ethernet will go the way of the Parallel Port. (Although don't quote me on that, Bill Gates did once say 640K was enough memory for a PC)
store.mesanet.com/index.php?route=produc...oduct&product_id=311
And grab a x86 PC, Tommy has the low down on what's good surplus wise.
Another thing to be aware of I think the Wheezy image of MK was off the last images to include X. The MK guys seem to be splitting the GUI from the motion control. Development appears to be a little slow with MK.
15 Aug 2020 11:54 #178263
That has been said for the last 20 years, it is still here and still works properly.But the parallel port's days have been numbered for some time.
15 Aug 2020 13:24 #178274
by berntd
Well, No new PC has one. Worse, new PCs are mostly laptops these days. They do not have any ports except USB.
I am not sure what I will do next.
- Thank you received: 1370
15 Aug 2020 14:53 #178291
Replied by Todd Zuercher on topic BeagleBone with LinuxCNC to replace old PC?
Few new pcs have them. But I think it is still possible to find one with a parallel port. True, no laptops do, but you don't really want one of those for a cnc anyway.
15 Aug 2020 14:56 #178292
Ethernet is very nice, check the Mesa 7i92 and while you're at it, also check the Mesa 5i25 for PCI or 6i25 for PCI-E.
They are very cheap and very flexible and extremely fast, and they have the best support.
- BeagleBrainz
- User is blocked
15 Aug 2020 23:40 #178335
by BeagleBrainz
I'm a little confused about your statement "new PCs are mostly laptops these days", could you expand on that a bit more.
Time to create page: 0.148 seconds
