Motherboad with PCI slot
11 Nov 2020 20:18 #189032
by BigJohnT
Motherboad with PCI slot was created by BigJohnT
Anyone buy a motherboard lately with a PCI slot that has decent latency for a Mesa 5i25 machine? I guess if need be the motherboard could have a PCIe slot and use a 6i25.
JT
JT
- Thank you received: 5984
11 Nov 2020 21:16 #189044
Replied by tommylight on topic Motherboad with PCI slot
See if you can find a used Fujitsu PC, some that have black cases with a red stripe are very good and they go for 70 to 150$ and am pretty sure both types i tested had a single PCI slot. The big one was Fujitsu ESPRIMO P700 E90+ 2nd gen Intel® Core™ i5 i5-2500.
icecat.biz/en/p/fujitsu/vfy-p0700pxp31de...+e90%2B-8540845.html
www.ebay.com/sch/i.html?_from=R40&_trksi...P700+E90%2B&_sacat=0
Have a look here, there are some older mobos i still use daily and some PC's.
forum.linuxcnc.org/18-computer/38838-har...ts-used-pc-s?start=0
forum.linuxcnc.org/18-computer/39371-res...or-use-with-linuxcnc
11 Nov 2020 22:44 #189059
by BigJohnT
Replied by BigJohnT on topic Motherboad with PCI slot
Thanks, I was hoping to find something new my customer can purchase from someone like NewEgg. Sorry I should have mentioned that.
Quite impressive all the testing you did, do you ever sleep LOL?
JT
JT
11 Nov 2020 23:32 - 11 Nov 2020 23:35 #189069
by 0x2102
Replied by 0x2102 on topic Motherboad with PCI slot
I have been using the ASUS Prime B360 Plus with a 5i25.
Last edit: 11 Nov 2020 23:35 by 0x2102.
The following user(s) said Thank You: BigJohnT, tommylight
11 Nov 2020 23:39 #189070
It is nearly 1 AM here and will be up for at least another hour or two.
Not really !Quite impressive all the testing you did, do you ever sleep LOL?
11 Nov 2020 23:42 #189072
Dang, that is a new-ish board with 2 PCI slots ! NiceI have been using the ASUS Prime B360 Plus with a 5i25.
12 Nov 2020 21:53 #189157
by BigJohnT
Thanks, my customer ordered one of those for me to setup.
JT
JT
13 Nov 2020 08:22 #189187
by ississ
Replied by ississ on topic Motherboad with PCI slot
Just for the future.
I have had no issues with a pcie->pci adapter, like this
My lathe is running with an Asrock Q1900B-ITX, asm1083 pcie-pci adapter and a 5i25.
