- Hardware & Machines
- Computers and Hardware
- Remora - Rpi Software Stepping Using External Microcontroller via SPI
19 Jul 2023 07:28 - 19 Jul 2023 07:28 #275794
by meister
Replied by meister on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
but i think remora also supports W5500 modules (or similar) via SPI !?!?!
Last edit: 19 Jul 2023 07:28 by meister.
19 Jul 2023 08:15 #275799
by kzali
Replied by kzali on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
Hi Cornholio
Thanks for your offer! I already have WT32-ETH01 however I am new to LinuxCNC. I need to order an encoder, preferably from Aliexpress, trying to understand which one to get!
Your advise will be much appreciated.
I think private messaging is not working at the moment- would love to be in touch in Sydney to learn more.
19 Jul 2023 08:16 #275800
by kzali
Many thanks
Great work
Great work
19 Jul 2023 09:38 #275805
by cornholio
Replied by cornholio on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
Hi kzali,
I've sent a message by what I may think is your github handle from a msg you left on the linuxcnc-RIO project.
20 Jul 2023 00:32 #275840
by cakeslob
Yeah kinda, it will at least, soon
Replied by cakeslob on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
20 Jul 2023 04:05 #275854
by cornholio
Just thinking out loud, wouldn't having the ethernet-spi bridge take the a lot of load off the Remora MCU and reduce the MCU code base ? I'd imagine once the WT32-ETH01 was sorted it would be good for SPI on a variety of boards ?
The MCU I presume is pretty agnostic as the source of the SPI signals as long as they are correct ? Would that open up Ethernet connectivity to more remora boards and allow any platform Rpi\Orange Pi\ x86\64 to work as well.
Just thinking out loud.
20 Jul 2023 07:25 #275866
by meister
Maybe a little less code, but I can't say whether it's faster.
and you have to flash 2 boards and the FTP/flexi stuff will not work
The following user(s) said Thank You: cornholio
21 Jul 2023 11:31 #275949
by cornholio
21 Jul 2023 17:16 #275967
by cakeslob
It can be made to work most likely, with SPI. I dont know about the ethernet though, or if the GD-407 will work.
21 Jul 2023 22:29 #275981
by scotta
github.com/scottalford75/Remora-EC500
Replied by scotta on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
The STM32 Remora-EC500 code base would be a very close starting point. The EC500 uses a different version of the F407 so pin assignments would need to be checked.Would Remora work with this ?
www.olimex.com/Products/ARM/ST/STM32-E407/open-source-hardware
Time to create page: 0.294 seconds
