Parallel Port Tester
- Thank you received: 5932
20 Aug 2020 20:23 #178872
Replied by tommylight on topic Parallel Port Tester
Why are you running as root ?Refusing to run as root without fallback UID specified
- shortcircuit48
- Thank you received: 3
20 Aug 2020 22:46 #178882
by shortcircuit48
Replied by shortcircuit48 on topic Parallel Port Tester
Not sure why. I have managed to get ptest to work and it outputs
Note: Using POSIX realtime
config string '0xdcb0 out'
Linux parallel port @56496 not found
halcmd:
When I do lspci I get
03:01.0 Parallel controller: Device 1c00:2170 (rev 0f)
03:02.0 Parallel controller: Device 1c00:2170 (rev 0f)
which I have assumed that as I have two cards in that I should have a parallel port.
Will look to see if I have the correct port address .I also had thgis
3:01.0 Parallel controller: Device 1c00:2170 (rev 0f) (prog-if 01 [BiDir])
Subsystem: Device 1c00:2170
Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 10
Region 0: I/O ports at dca0
Region 1: I/O ports at dca8
Thanks again
halcmd:
Thanks again
21 Aug 2020 06:13 #178899
That will happen as the assignment of resources in BIOS is set to Auto, so check if the BIOS has such a setting and set it to manually assign them.
The address has changed to dca0.config string '0xdcb0 out'
- shortcircuit48
21 Aug 2020 06:35 - 21 Aug 2020 06:47 #178902
by shortcircuit48
"Why are you running as root ?"
When I used Nano I had to go into su to save file and should have come out back into where ptest is
Modified file today and ran ptest and got
hamish@Hamish:~/Downloads$ halrun -I -f ptest.hal
config string '0xdca0 out'
Linux parallel port @56480 not found
"That will happen as the assignment of resources in BIOS is set to Auto, so check if the BIOS has such a setting and set it to manually assign them. " Thats today occupied once I figure out but ???
Last edit: 21 Aug 2020 06:47 by shortcircuit48.
21 Aug 2020 07:02 #178903
Try
dca8
dca8
- shortcircuit48
21 Aug 2020 07:56 - 21 Aug 2020 11:28 #178909
by shortcircuit48
Before I go any further on another wild goose chase i have found the following
1 I can run the latency test on its own and its about 50000, however I cannot abuse the system as nothing will load.
2 I can open my browser and then launch the latency test and I loose control as mouse darts all over the place
3 I am using an old Dell Dimension 3100 and when I look at the Linuxcnc section "Hardware that works" it indicates ""No Built in Serial or Parallell Ports!!!"
In view of the above am I wasting my time with the Dell and if so any recommendations as to which hardware to get?
I can get a refurbished unit off ebay for way under £50
Last edit: 21 Aug 2020 11:28 by shortcircuit48.
21 Aug 2020 13:18 #178920
That is old, so most of the issues are due to very limited RAM memory.
As for the parallel port, just have a look on the back side, there should be a female DB25 connector, violet colour, it is the biggest connector on the back.
- shortcircuit48
21 Aug 2020 13:56 #178921
by shortcircuit48
Yes , there was one card and I added another, neither of which were violet in colour. I think I will look for a replacement either new or from ebay. I have noted a thread on this topic and will now read through it. I did increase RAM but will find out to what.
- shortcircuit48
27 Aug 2020 10:49 - 27 Aug 2020 12:43 #179678
by shortcircuit48
Back again. I now have a HP 500B MT desktop. My first problem came as it only had one port able to take the parallel port card and this was occupied by an Ethernet card even although there was an onboard Ethernet connection. After much trial and error freed up the port and internet now connected to onboard. Parallel port card now fitted and if enter lspci --vv the card appears with port reference. I change the reference in the tester but port is not found when attempting to run.
Screen shot
03:04.0 Parallel controller: Device 1c00:2170 (rev 0f) (prog-if 01 [BiDir])
Region 0: I/O ports at ec00
Region 1: I/O ports at e880
hamish@debian:~/Downloads$ halrun -I -f ptest.hal
config string '0xec00 out'
Linux parallel port @60416 not found
I am sure it must be simple but any advise would be appreciated.
Screen shot
Last edit: 27 Aug 2020 12:43 by shortcircuit48.
- Thank you received: 1369
27 Aug 2020 14:35 #179688
Replied by Todd Zuercher on topic Parallel Port Tester
Did you try it with the 0xe880 address?
Time to create page: 0.101 seconds
