Parallel Port Tester
- shortcircuit48
- Thank you received: 3
27 Aug 2020 15:01 #179691
by shortcircuit48
Replied by shortcircuit48 on topic Parallel Port Tester
Yes. Have just this moment installed Mint 20 and now going to follow procedure to install.
Thanks will keep you updated
- shortcircuit48
27 Aug 2020 15:39 #179697
by shortcircuit48
That is Linuxcnc now running on Mint 20 which was no bother to install following instructions. Unfortunately I still can not get ptest to work as it still cant find port. Ahead but no further forward.
- Thank you received: 1369
27 Aug 2020 15:44 #179698
Replied by Todd Zuercher on topic Parallel Port Tester
If your pc only has 1 parallel port, have you tried just using the line
Or if you have 2 ports you might need to useto access the "other" port.
loadrt hal_parport cfg="0"
loadrt hal_parport cfg="1"
27 Aug 2020 15:49 #179699
What does the following command show at a command line?
cat /proc/ioports |grep parport
- shortcircuit48
27 Aug 2020 16:13 #179702
by shortcircuit48
Only have one parallel port
~$ loadrt hal_parport cfg="0"
bash: loadrt: command not found
hamish@hamish-HP-500B-Microtower:~$ sudo loadrt hal_parport cfg="0"
[sudo] password for hamish:
sudo: loadrt: command not found
hamish@hamish-HP-500B-Microtower:~$ cat /proc/ioports |grep parport
Looks like I have a problem with commands. Will look in "packages"?
- Thank you received: 5932
27 Aug 2020 20:54 #179739
Did you try lspci -v on Mint 20?
Replied by tommylight on topic Parallel Port Tester
That means no parallel port !hamish@hamish-HP-500B-Microtower:~$ cat /proc/ioports |grep parport
- shortcircuit48
27 Aug 2020 23:59 #179759
by shortcircuit48
I have reinstalled Mint 20 and have as yet to install cnc. From lspci -v I get
03:04.0 Parallel controller: Device 1c00:2170 (rev 0f) (prog-if 01 [BiDir])
Subsystem: Device 1c00:2170
Flags: medium devsel, IRQ 10
I/O ports at ec00
I/O ports at e880
Which suggest there is a parport.
Will try later today. Thanks
I/O ports at ec00
I/O ports at e880
- shortcircuit48
28 Aug 2020 09:25 #179796
by shortcircuit48
I cleaned system out and installed Mint 20 Ulyana along with 2.8test, which appear ok. Latency test has come down but appears a bit high.
I have run the parport tester but it still fails to find port with
Note: Using POSIX realtime
config string '0xec00 out'
Linux parallel port @60416 not found
When I run lspci - vv I get
Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 10
Region 0: I/O ports at ec00
Region 1: I/O ports at e880
Does this suggest I do have a parport?
Thanks for help
Thanks for help
28 Aug 2020 11:41 #179819
'0 out'
instead of the port address, then if that does not work try
config string '0xe880 out'
Restart the PC between tries.
tryconfig string '0xec00 out'
'0 out'
- shortcircuit48
28 Aug 2020 13:02 #179827
by shortcircuit48
When I used"0 out" I now get
Note: Using POSIX non-realtime
config string '0 out'
Linux parallel port #0 not found
hal_parport: rtapi_app_main: No such file or directory (-2)
ptest.hal:1: waitpid failed /usr/bin/rtapi_app hal_parport
ptest.hal:1: /usr/bin/rtapi_app exited without becoming ready
ptest.hal:1: insmod for hal_parport failed, returned -1
halcmd:
Using"0xe880" was as previously listed
halcmd:
Time to create page: 0.149 seconds
