Can the OPI5 be Configured to Run LCNC?
07 Apr 2023 23:03 - 08 Apr 2023 00:08 #268561
by royka
Replied by royka on topic Can the OPI5 be Configured to Run LCNC?
I see, they froze the master branch, so won't fix, you could build the master branch with EXTRAWIFI=no
[/code]
./compile.sh KERNEL_CONFIGURE=yes BOARD=orangepi5 BRANCH=legacy EXTRAWIFI=no
[code]It's pretty bad at the moment indeed, the old branch is not getting fixed and the new branch is under development.
Edit: Sorry I'm also getting errors on both of them, but the kernel did compile, upload it in a moment, it needs a little fix because the rt kernel has another name.
Last edit: 08 Apr 2023 00:08 by royka.
08 Apr 2023 01:04 #268570
by royka
Here is the kernel. If you install an image from armbian first you could install this one.
filebin.net/lpleuciilara5q60/linux-image...c222-Be9aa_arm64.deb
To isolate cores you could add the following line to /boot/armbianEnv.txt
extraargs="isolcpus=5,7"
08 Apr 2023 01:31 #268573
by royka
The kernel I'd uploaded is with the rtl8192cu driver.
Here are the deb packages for LinuxCNC:
filebin.net/lpleuciilara5q60/linuxcnc-debs.zip
For gpu hw accelaration you could follow something like:
forum.armbian.com/topic/26450-accelerate...talling-and-running/
Except the udev rules, the lines in rc.local and the lib linking. Instead you could install rockchip-multimedia-config from apt at that point
08 Apr 2023 01:37 #268574
Its good to see others getting familiar with Armbian..
Replied by rodw on topic Can the OPI5 be Configured to Run LCNC?
You really should be sharing the deb for the matching headers to support DKMS drivers the user may need.Here is the kernel. If you install an image from armbian first you could install this one.
08 Apr 2023 02:03 #268576
by royka
You're right about that, was already busy with remaking that deb package. It was looking for version 5.10.110 instead of 5.10.110-rt, I guess because the rt name is in a config file in the kernel (not the kernel config in armbian).
filebin.net/lpleuciilara5q60/linux-heade...c222-Be9aa_arm64.deb
08 Apr 2023 03:09 #268581
If you use EXPERT="yes" as a parameter to compile.sh, you can select EDGE where you can build for Debian Bookworm.
Doing that lets you use the Bookworm Linuxcnc-uspace repos.
Its not really necessary to build an image with a graphical environment. This takes a very long time.
It is faster and more reliable to install that afterwards. Just enter this command on the initial command prompt when logged in as root:
Good luck...
apt install task-xfce-desktop firefox-esr linuxcnc-uspace linuxcnc-uspace-dev mesaflash geany
Good luck...
08 Apr 2023 03:26 #268583
by royka
Wouldn't it compile the non rt 6.2 half mainline kernel then? (Unless you change that source too).
That would make it easier indeed to install LinuxCNC, but then you'll need to compile mesa, mpp, Chromium, v4l2, ffmpeg configurated to use the Rockchip gpu and manually add the rules to have gpu acceleration.
08 Apr 2023 05:42 #268588
Chromium is included in the Debian Repositories and worked for me on another platform.
Take the time to familiarise yourself with the Armbian build environment, user configurations, userpatches and config files etc. I would expect you could configure the build environment to apply your customisations if you know whats is going on.Wouldn't it compile the non rt 6.2 half mainline kernel then? (Unless you change that source too).
08 Apr 2023 09:45 #268595
by royka
I think I know a bit how the armbian build system works, it would be a ton of work for me to automate these things and maintain. It's not something I'd really love to do and this works already, just trying to help to make them start a bit more easy.
For Chromium I was talking about hw acceleration/hw decoding, it does work without but the CPU usage will be high.
But you're absolutely free to do whatever you like.
If you could make something like this for Debian Bookworm, would be awesome
launchpad.net/~liujianfeng1994/+archive/ubuntu/panfork-mesa
launchpad.net/~liujianfeng1994/+archive/.../rockchip-multimedia
08 Apr 2023 12:15 - 08 Apr 2023 12:18 #268603
by royka
Oops made a typo in the headers package. so to keep it a bit organized:
After you've booted an Armbian Jammy image/installation, you could install these packages.
Kernel:
Kernel headers:
filebin.net/lpleuciilara5q60/linux-heade...c222-Be9ac_arm64.deb
LinuxCNC packages:
Kernel:
Kernel headers:
LinuxCNC packages:
Last edit: 08 Apr 2023 12:18 by royka.
Time to create page: 0.363 seconds
