Off thee shelf 2023 mini Pc single board computer
15 Aug 2023 19:38 #278069
by PaulQUE
Off thee shelf 2023 mini Pc single board computer was created by PaulQUE
Hello everyone
I'm beginning to retrofit an EMCO F1 cnc milling machine and I plan to integrate the computer inside the electronic enclosure, as the machine will be located in my very small workshop and I can not afford to have a regular computer hanging around.
I am looking for a single board computer or else a very small computer to which I can hook up my mesa 7i96s, something that doesn't require extensive work to just get the instal on there.
is anybody satisfied with a solution?
regards, Paul
regards, Paul
- Thank you received: 5945
15 Aug 2023 19:56 #278072
Replied by tommylight on topic Off thee shelf 2023 mini Pc single board computer
HP 8300 SFF
Used, had 6 and all but one are still in daily use.
15 Aug 2023 19:59 #278073
by PaulQUE
Replied by PaulQUE on topic Off thee shelf 2023 mini Pc single board computer
thanks for the input, I may not have been precise enough, But I'm looking for something much much smaller than that, I see a lot of SBCs like the latte panda, but I'm unsure of what is needed to make Linuxcnc run on them. I'm also considering mini computers like the gigabyte brix series
15 Aug 2023 20:47 #278079
by cornholio
Replied by cornholio on topic Off thee shelf 2023 mini Pc single board computer
Odroid has a new x86 sbc.
www.hardkernel.com/shop/odroid-h3-plus/
I’m running it’s predecessor and it’s a great little bit of kit. Great thing about it is the dual Ethernet ports. All you need to add is ram and either a ssd or nvme and off you go.
15 Aug 2023 22:42 #278091
Replied by rodw on topic Off thee shelf 2023 mini Pc single board computer
I also have an Odroid H2+ runung ethercat hardware.
You need Debian Bullseye or above to get NIC driver support
Some people have complained about latency on the H3+. I can't see why it could not be solved.
Otherwise, the Gigabyte BRIX J1900 or N3160 are great. Mine are still going strong after 7 years...
Alternatively look for an Industrial PC preferably with an Intel NIC Celeron J1900 4 core and above
17 Aug 2023 20:31 #278296
by PaulQUE
Thanks for the input, I'm also looking at lenovos 93z Aio integrated pc with touch screen and a core i5, would these be suitable?
18 Aug 2023 07:20 #278327
by RotarySMP
Replied by RotarySMP on topic Off thee shelf 2023 mini Pc single board computer
I have both a Gigabyte Brix N3160 and an HP elitedesk 800 g2 mini on my two lathes. Both work fine with Mesa cards, but the HP is way faster, boots fast etc. The Brix is solid but slow.
16 Nov 2023 17:38 #285637
by Unlogic
Replied by Unlogic on topic Off thee shelf 2023 mini Pc single board computer
Just a little heads up to anyone using this thread for reference as I did when purchasing hardware. The kernel that currently ships with Debian 12.2 contains a broken driver for the Intel i219-LM network card in the HP Elitedesk 800 G2 mini making it unusable with LinuxCNC 2.9 at the moment.
16 Nov 2023 19:47 #285645
by spumco
Thanks again for researching the i219 fiasco. I'm wondering how RotarySMP (Mark) is getting on with his G2... I think he's on 2.8 on both his lathes and probably using a 4.x RT kernel.
I'm going to try MX and/or Mint on my backup mini PC tonight, and I also purchased an 800 G1 mini last night from fleabay. That one has a i217 NIC - the same thing PCW's reported to be useable.
Replied by spumco on topic Off thee shelf 2023 mini Pc single board computer
16 Nov 2023 20:21 #285650
by Unlogic
I suspect LinuxCNC 2.8 users are fine as I don't think the driver bug was present in the kernel that shipped with that version of Debian.
It seems like the fix has been included in the Ubuntu kernel but not the Debian one from what I've read online. The best approach here would possibly be to see if we could get Debian to also include it.
Time to create page: 0.174 seconds
