- Hardware & Machines
- Computers and OS's
- ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
- Online
- Thank you received: 5934
05 Mar 2024 13:09 #295227
Replied by tommylight on topic ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
Moved to "Computers and OS's".
Thank you.
Thank you.
The following user(s) said Thank You: wez
05 Mar 2024 19:21 #295250
by wez
Replied by wez on topic ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
Thanks Tom!
Testing PCNT high speed was fun, been several weeks of effort. To ensure maximum signal integrity and without using a scope based signal generator (as direct as possible for DUT) to not skew results it took:
Plan to publish results eventually but it's part of certifying the module for future commercial use. It has to be tested in order to claim it's capabilities
- MOPA Fibre lasering a dual sided copper clad board for two ESP32-S3s modules with smallest possible track sizes including VIA stitching and ground planes
- One runs the ESP-DSP & its PIE extensions to generate a perfect and consistent waveforms in hardware
- Direct GPIO on the generator to rule out any mux related issues
- Tracking PCNT overflows on the receiver (Device Under Test) at high speeds whilst keeping interrupt load as low as possible
- Able to generate multiple simultaneous waveforms and route to various GPIOs on the receiver to test multi-channel capabilities
The following user(s) said Thank You: aparecido
05 Mar 2024 20:35 - 05 Mar 2024 20:40 #295255
by wez
Another shameless plug...
400khz output on the ESP32-S3 (dual core) across two axes has now been tested and confirmed as being reliable and precise. Video proof of steppers at 32x microstepping (25600ppr) eventually, just have quite a bit going on still.
That's double the step pulse frequency output (with step tracking) of any previous microcontroller based solution and please do correctly me if I'm wrong - the highest for any microcontroller based solution out there? Would love to be corrected. Please!
EDIT: Must clarify: the 1Mhz step pulse output stated earlier is an experiment for a single axis and there remains a lot of work to get it in a usable state. The hardware is capable of it though. These tests and results are for the integrated all-in-one single MCU motion controller and so multi-axis speeds are lower.
Video of scope output:
Last edit: 05 Mar 2024 20:40 by wez.
- Online
07 Mar 2024 22:28 #295431
This can be freely called a gimmick, but imagine having this showing axis position, motor current and temperature, drive temperature, all voltages on the machine, my life expectancy ... hmmmm
08 Mar 2024 00:59 #295434
by wez
Who doesn't like a nice gimmick? See what you did there
The following user(s) said Thank You: tommylight, aparecido
08 Mar 2024 13:48 #295457
by meister
Replied by meister on topic ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
this is also awesome:
hackaday.io/project/161896-linux-espnow
The following user(s) said Thank You: tommylight, Mecanix
08 Mar 2024 15:11 - 08 Mar 2024 15:12 #295460
by wez
Yeah that's already built into my project by default. See my github repo regarding the parts about ESP-NOW
Last edit: 08 Mar 2024 15:12 by wez.
09 Mar 2024 11:26 #295501
by wez
This has been put on a bit of a back burner for now due to life priorities but I will pick it up again soon. I promise.
I'm very reluctant to release code that isn't optimised with all features and having been tested properly. Perception and quality matters, even for open source projects. Thanks to all of you for understanding and I truly value your patience!
09 Mar 2024 12:52 #295509
by Mecanix
Idea was inspired by this one . Got to give the guy some credit, the idea is brilliant. I've just took it a notch up and plugged PCNT, ESPNOW and a python serial interface for lcnc. Concept remains the same though, still a functional spindle encoder. Just WIFI lool
Replied by Mecanix on topic ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
Espnow is NOT a gimmick. Truly works. If you are able to strip it down to core functions it turns into some pretty wicked high performance comm stuff, I like it a lot. So much so that I engineered a whole spindle encoder for my parport mill's spindle. Can do rigid tapping at 4000RPM (if I wish) using a cheap 100ppr omron knockoff encoder. All wifi, no lost heartbeats, go figure!!this is also awesome:
09 Mar 2024 12:56 #295510
by wez
Nah I know it's not. It's capable of ridiculously low latency since it doesn't have the usual WiFi overhead and is point-to-point.
It's truly awesome. I'm really surprised more aren't using it tbf
Time to create page: 0.103 seconds
