- Hardware & Machines
- Computers and Hardware
- ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
25 Feb 2024 23:38 #294467
by wez
Replied by wez on topic ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
Love it!
25 Feb 2024 23:40 #294468
by Mecanix
Replied by Mecanix on topic ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
Nothing fancy, trust. Just a machine screw compensation tool. I had the scale (re)calibrated by a metrology lab domestically, and they asked for an interface to perform their tests, and so I made one with a c driver for it. Turned out I use it to interface it to Lcnc for when I carry out those screws error/linearity calibrations too. i.e install the scale on the axis, run the python script and it outputs a 'within-tolerance' validated *.comp file for the joint. Effortless, the mill sees the world through +/- 5microns...Thanks Mecanix. That's cool. Interested to know more but its classified
25 Feb 2024 23:46 #294470
by Mecanix
Strangely look-alike those Augmented Reality PCD design tools we we're toying with 2~3 years ago. Few apps you can try, some literally free... google this up, Tommy.I have a 3D printed pendant that is begging for this and, not sure how useful this is but i bumped into it a while back
26 Feb 2024 00:58 #294478
by wez
Ingenious! Nice work
26 Feb 2024 09:21 #294486
by meister
Replied by meister on topic ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
Nice Project !
do you have a link to your github repo ?
- Thank you received: 5962
26 Feb 2024 11:46 #294503
26 Feb 2024 12:23 #294507
by meister
THX !
@wez
have an error while running 'pio run'
* Looking for Eth.h dependency? Check our library registry!
* CLI > platformio lib search "header:Eth.h"
* Web > registry.platformio.org/search?q=header:Eth.h
#include "Eth.h"
compilation terminated.
please use ETH.h than it works also on non Windows systems
@wez
#include "Eth.h"
26 Feb 2024 12:28 #294508
Replied by tommylight on topic ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
Eth.h should be in the src directory, so check if the letter case is the same, Linux makes a distinction between upper and lower case letters, Eth.h is not the same as eth.h and not the same as ETH.h.
This happens often.
This happens often.
26 Feb 2024 12:31 #294509
by meister
i know, all works with ETH.h
Environment Status Duration
esp32-rmii-ethernet SUCCESS 00:00:04.218
esp32-spi-ethernet SUCCESS 00:00:05.536
esp32-wokwi-simulator SUCCESS 00:00:04.293
==================================== 3 succeeded in 00:00:14.048 ====================================
26 Feb 2024 13:49 #294517
by wez
Good news!
Motor encoder positional feedback into LinuxCNC works a treat.
Low latency and fast. Lose 1 count every so often on high speed moves due to noise (unshielded cables) but its very very repeatable and precise.
Can support up-to 8 axis encoders or 6 + 2 spindles.
Take a look...
Take a look...
Time to create page: 0.174 seconds
